Question about MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript
Where can i find the speed control switch for t55/40 prowler trolling motor
4 Suggested Answers
  • 5 Answers
SOURCE: i have a 37 lb thrust motor guide stealth 5forward
trolling motor parts.com
Posted on Apr 30, 2010
wentlanv
  • 710 Answers
SOURCE: motorguide wireless 24volt trolling motor,
Hi thommo5473,
Do you have your owner's manual? If not, here is a website with the document: http://www.motorguide.com/userfiles/file/Support/OwnersManuals/2011%20Wireless%20Manual.pdf
From what you've said, I'm not sure exactly what is going on. The instructions state that the control will beep when it's on and a button is pushed, then you'll get a longer beep when it goes off.
Now, the fact that you don't get a speed change... did you just push the button and let go or have you tried just holding the button down? Just pushing and letting go will give just a slight change, but holding the button down will give a greater speed change.
In the troubleshooting section, they give things to do if something doesn't work, such as reprogramming, the control doesn't have the serial number of the remote entered into its memory.
Other reasons for problems are weak batteries, etc.
Try the things in the troubleshooting section of the owner's manual, then if that doesn't work, call the service number in their. They should help you out. If something's wrong with the system, then they should replace it.
I hope this helps, if it does, I'd appreciate your vote. Thanks,
Handie Andie
Posted on Apr 14, 2011
SOURCE: Wire going to prop of Motorguide trolling motor shorted
Unless you are mechanically inclined, dont attempt this. Take the lower unit apart by removing the prop and removing the two bolts that hold the forward and aft housing to the center housing. Fwd being the cone shaped part. Pull the aft housing away from the motor so you can inspect the connections to the board that holds the brushes and the soldered wiring terminals. You should find the solder missing from at least one of the terminals that connects the wiring from the foot switch to the speed control windings inside the aft housing. Clean up the terminal and wiring and re-solder. Also re-flow the solder on the other terminals. Clean up the seals and the area where the seals meet the housing parts. Replace seals if damaged. Reassemble the lower unit and torque the bolts 45-50 in-lbs and no more otherwise you will fail the seals. This problem is due to a "cold" solder joint that creates a high resistance to elec current flow and heats enough to melt the solder. This is a result of poor quality control at the manufacturer. Good luck.
Posted on Dec 29, 2011
My bow mount 43lb thrust foot controlled trolling motor is only working in one speed. It must be in rapid speed be cause the motor only works with selector switch on the rabbit and not on troll.
needs to go to a repair shop for a new resistor unit in the motor .or one of the wires going thru the shaft has broken .they fail dueto the constant flex from turning
Dec 16, 2015 | Boating
Is there any way to modify in order to get more power/thrust out of a mk 30lb other than stock? or can you take a moto guide 80 lb., bow mount foot control, shaft and motor and combine it with transom...
Hey Chris,, you are starting a project (or wanting to) that is going to be problematic... It will be easier to go buy a new trolling motor with the money you are going to spend attempting this conversion... the newer trolling motors are so much more efficient...
Trolling Motors Fishing Motors Electric Boat Motors MotorGuide Trolling...
https://www.minnkotamotors.com/
Jul 15, 2017 | Minn Kota Endura 30 Freshwater Transom...
I don't have any slow trolling speeds. Only fast speeds on my Pro Series 6700 trolling motor. Any ideas? Also, it is a 24 volt system. How do I properly hook up the batteries. The two batteries are...
To hook up to 24 volts you need to join a positive cable from one battery to the source[motor or controller] and the the negative cable goes to the positive of the next of the next battery,then the negative [of battery #2] goes to ground,same for all 24 volt systems.If the slower speeds don't work then the rheostat in the accelerator handle could be at fault,but getting the 24 volts sorted out may fix everything.
Jul 22, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Trolling motor stays on same speed no matter where I set the speed 10 -100. It is at a mid range speed.
I just recently had a simialr problem. No speed control and motor only ran at 100. I talked to the minn kota tech rep and sent him my control board and he said it had a bad potentiometer...however, I had to buy a control board to fix the problem ($215). Hate to say it but sounds like you may need a new control board.
Jun 24, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
MotorGuide STANDARD MOTOR REPLACEMENT PARTS SWITCHES AND COMPONENTSDescript Logo
104 people viewed this question
Top MotorGuide Electrical Supplies Experts
jdthefixer
Mike
ken skalski
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
