Question about Video Cameras
Won't load tapes keeps beeping - Video Cameras
  • 2,509 Answers
Check the camera is dry and the tape path is clear. If the camera has not been used for a long time warm it gently with a hair-dryer and try again.
Posted on May 08, 2014
2 Suggested Answers
  • 57 Answers
SOURCE: tape not loading
Chances are it is in need of a major cleaning. Usually by the time this happens the cleaning tape will do no good. A good internal cleaning is usually the only thing that will help it........Has it been droped? If it has then you could need repairs
Posted on Jan 04, 2009
Toshiba dvr670ku - vhs tape won't play, shuts recorder off
look to see if tape will fully load and if FF or REWIND work, if not a transport problem, drive mechanism not moving the tape, unit will sense this and shut unit off----even a problem in the loading mechanism for the VHS tape not loading the tape all the way will do the same thing.
Oct 14, 2012 | Toshiba M754 VCR
Vhs is stuck in machine. Won't play and won't eject.
There are any number of reasons why it won't play. The loading basket is jammed, the video tape has got tangled up in the mechanical section of the vcr or the loading gears are stripped. Unplug machine and remove top, [screws side and back] if the tape is spewed carefully remove by cutting it and clean tape particles, for any other problem have a technician check it out.
Jun 28, 2012 | Sony RDR-VX530 DVD Recorder/VCR
The machine won't erase my tapes? Is there a chance it could be a faulty machine?
Does the erase light come on and the tape rewinds? Or does it just beep when you try? Could be a bad erase switch, sometimes pressing harder will do the trick. If it just beeps, try another tape.
Jul 18, 2011 | Sanyo TRC-7060 Desktop Cassette...
I have a canon MV 830.Please could you tell me when i put the cassette into the camcorder it keeps beeping then asks me to eject the cassette. Is this expensive to fix?
My MV830 would load without a cassette; but freeze, beep 3 times and eject if a cassette was inserted. I read the following thread with a great deal of scepticism and concern that I would damage my MV830 camcorder even more; but what did I have to lose? I loaded the compartment without a cassette, hit it firmly 3 times on the tape loading side and the issue was gone. It now works perfectly! Technology is fantastic...
http://www.fixya.com/support/t238707-will_not_load_tape
Dec 06, 2010 | Canon MV830 Mini DV Digital Camcorder
My video cam doesnt eject my cartridge once i played it.it turns off and never stops beeping
The short beep and shut off indicates that the camcorder is not loading up. it could be a faulty head cylinder motor / loading motor or the safety mechansim faulty. you will need a lot of expertise to open and check within as the job involves delicate touch. Check if the dew switch is on if so just keep the camcorder in a warm place for some time and try. If the cylinder is not rotating then it is the failure of the drive or the hall ics. check this out with a tech hand. Good day
Jun 24, 2010 | Sony 8mm Stantard Grade 120 Minute...
Tape not loading
Jan 03, 2009 | Video Cameras
Tape not loading
Drop it on a carpeted floor from half a metre
I got the solution fromFixYa on 3rd Feb 09 it worked for me
Dec 16, 2008 | Canon DV-MV830i Mini DV Digital Camcorder
GE Spacemaker Extra-Large Capacity Portable Washer
i was using a defective extension cord, the machine should trip when start it . and beep with no other message on the screen
Nov 08, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Video Cameras Logo
18 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
