Question about Cameras
What does the red blinking light under the battery
What does the red blinking light under the battery light
  • Harrie May 08, 2014
    Hi Stacey Calabrese, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? can you tell us what brand and what model camera this is?
2 Suggested Answers
SOURCE: red light blinking
i was filming, and i tripped and my gl2 hit the ground. it hit the battery kind of hard and now it wont work properly. now when i turn it on, the power light blinks red or green, depending on playback and recording mode. i want to know how i can fix this.
Posted on Jun 18, 2009
How do I stop the anti-theft device red blinking light? Car is off and locked and from the window can see the red light blinking.
the red light drain 0.001amp. from you battery.need 1000 hour to drain 1 amp. test the battery if is any good. do drain test on the car.rust and short will drain battery overnight.after market equipment,light in the trunk or glove box, under hood light etc. disconnect the battery and install amp meter. do the drain test. your computers uses 0.2-0.4amp when sleep.anything over 0.5-.6 amp is bad. after you connect the amp meter give 1min. to turn all systems to sleep mode.Is normal the first minute to be high drain.
ones you know something is wrong disconnect the fuses one at the time and note if any changes. if the fuse you disconnect turn the amps low note what system is connected to the fuse and you will know were is the problem
Oct 24, 2014 | 2003 Oldsmobile Alero
The red light on my mouse keeps on blinking
Here's a guide;
What do the battery lights mean on my mouse? Some keyboard and mouse models feature a battery light that shows the current status of the batteries. The following table describes the different lights and states.
Light
Device Model Status Single long green blink Rechargeable Batteries are good. This occurs when batteries are first installed or every time that the device is turned on. Slow green blink Rechargeable Device is docked in the charging station and is charging properly. Steady green Rechargeable Device is docked in the charging station and does not need additional charging. Steady green Presenter Mouse (Japanese version) Laser pointer is on. Red/green blink Wireless Device is discoverable (trying to connect to the transceiver). Slow red blink Non-rechargeable Batteries are low and need to be replaced. Slow red blink Rechargeable Batteries are low and need recharging. Fast red blink Rechargeable Device is docked in the charging station, but there is a charging error.
Reasons for errors: The wrong type of battery is installed; the battery or batteries are missing; or the battery connection is bad.
Solutions: Make sure that the correct battery or batteries are installed, and are installed correctly. If necessary, remove the batteries, wipe them with a clean cloth, and reinsert them. Steady red Presenter Mouse (Standard version) Laser pointer is on.
Oct 18, 2014 | Computers & Internet
Wii Remote lights blink, but don't stay on
Your remote either needs to be re-synced to your wii or batteries are dead.
if you have replaced the batteries then click on the red button inside the battery cover and then press the red button under the small cover by the sd card slot on the front of the unit under the cover should sync up again.
May 30, 2011 | Video Game Consoles & Games
Why does my gateway nv53 battery light blink while charging?
Hi, The LED light on your Gateway NV53 Blinks while charging because it was designed to do so. According to the user manual, if the battery light is:
Solid Orange: Battery is fully charged Blinking Orange: Battery is charging Blinking Red: Battery is critically low Solid Red: Battery problems, contact Gateway support immediately.
Hope this helps. If it does, please accept and rate the solution! Contact me with any more questions you may have. Thanks for using FixYa!
May 22, 2011 | Gateway Computers & Internet
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
There are two lights right under the turn-on bottom and one has a picture of a battery and the other is a picture of a light bulb and this light bulb is blinking red five times in about 3second intervals.
the blinking bulb is the speed or the utility of the ram memory ....if it is blinking then it means that ur pc is utilising memory of ram....if it blinks faster then its using more memory....
Jul 17, 2009 | HP Compaq d530 PC Desktop
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
Red light blinking
Dec 18, 2008 | Canon GL2 Mini DV Digital Camcorder
Cameras Logo
12 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
