Question about KitchenAid KBFS25EWWH Refrigeration : Refrigerator : Bottom Mount
Why is my freezer leaking water and not defrosting ?
A SHEET OF ICE HAS FORMED AT THE BOTTOM
Krazytech
  • 725 Answers
SOURCE: water leaking at bootom of freezer door
I would check the water connection under the toe plate....follow the water line that comes out of the freezer door.. check if that is where your leak is coming from..
Posted on Sep 01, 2008
  • 112 Answers
SOURCE: Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Posted on Oct 18, 2008
  • 1122 Answers
SOURCE: water inside bottom of freezer after defrost cycle
your freezer drain is either frozen or clogged,remove stuff from bottom of freezer and you should be able to see the drainhole..if frozen use a hair dryer to melt,then to make sure it 's not clogged use a wire hanger to clear it out and you should be ok,let me know-mike
Posted on Oct 31, 2008
woodchuck789
  • 4059 Answers
SOURCE: water leaking/freezing in bottom of freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help
Posted on Jul 12, 2009
imufo2
  • 3773 Answers
SOURCE: water is leaking from somewhere
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 16, 2011
Testimonial: "makes sense, but still need to test it out."
Whirlpool GX2SHBXVY05 refrigerator leaking from bottom freezer onto floor.
if it has an ice maker check the water feed hose for leaks.
also I have a freezer that ices up twice a year. poor design. have to defrost every now and then.
Jun 09, 2015 | Refrigerators
MAYTAG refrigerator
More then likely you have a clogged drain. This is a pain to get to, like most bottom freezer models. You will have to remove everything out of the freezer, remove the door and racks to access the rear freezer panel. Once you get there remove it. You will probably see solid ice forming below the evaporator coil. This is ice from the unit going into a defrost cycle like it should. That is not a problem. The problem is when the ice melts and turns to water it is suppose to drain threw a hole located right below the evaporator in the center. If you have a sheet of ice formed you will need to defrost it to get to the drain hole. You can use hot water. In the industry we de-ice the drain with hot water and then blow it out with a CO2 tank(compressed air tank). This is not my favorite job because it is messy and sometimes long. That ice does not melt fast. Any questions for me go to refrigerator repair and email me anytime.
Apr 09, 2013 | Maytag MFF2558VE Bottom Freezer French...
I have condensate leakes into the bottom of my freezer and ices up the bottom of the freezer
YOUR DEFROST DRAIN IS CLOG UP YOU WILL NEED TO PULL THE BACK COVER OFF IN THE FREEZER SIDE AND CLEAN THE DRAIN YOU WILL SEE IT AT THE BOTTOM BEHIND THE FREEZER COVER
Oct 31, 2012 | Maytag Refrigerators
A sheet of ice has formed on the bottom of the freezer. Why.
There is a drain port in the behind the freezer panel where all of the water drains when your evaporator coils defrost. It has gotten clogged with food, or ice. Thaw all of the ice and unplug the drain hole, and ice will stop forming on the bottom of your freezer.
Jan 30, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Sheet of ice forms in bottom of freezer
Frost free fidges are supposed to stay frost free because the automatically defrost regularly. When they do this they may drain water down to the bottom of your fridge. Look for a tray that catches this water underneath the unit. Make sure yo keep it emptied. If you live in a very warm climate you may be getting a lot of humidity inside. There may be a switch that you can change for lower moisture.
Jul 01, 2009 | Freezers
Water weeping out vents in lower back of freezer compartment
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 29, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Leaking water
In back of the refrigerator behind a removable panel you will find a hose going into the drain pan under the refrigerator. Check and make sure there is no obstruction in the hose which would back up water into the freezer. After the drain hose is cleared the freezer should be defrosted and ice cleared from the drain area in the back. You can direct some hot water with some bleach in it through the drain to insure it flows into the pan.
Jun 15, 2008 | GE Profile PSW26P Stainless Steel Side by...
KitchenAid KBFS25EWWH Refrigeration : Refrigerator : Bottom Mount Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
