Question about Electrical Supplies
What cause V350C SDMO generator shut down on engine underspeed
2 Suggested Answers
SOURCE: my sdmo generator keeps shutting down temperature
http://www.aa1car.com/library/overheat.htm
Troubleshooting advice above link.
Sometimes it is the head gasket, check, it can be, incorrect fuel mixture, far too lean, exhaust should be a light grey color. Check enough oil in sump. ensure free flow of air all around machine.
Posted on Mar 28, 2010
Keep getting under voltage fault. I have cleared fault several time. generator will run for short period then fail.sometimes the fault is underspeed.
See if reducing the number of things connected to the generator will stop your problem. Disconnect or turn off some things that are not totally necessary.
To properly generate electricity, the engine is required to maintain an rpm within a specific range. If you load down the generator with too many things pulling power, the engine will not have enough HP to turn the generator within the set rpm range. It goes under-speed or under-voltage and you get a fault.
Going to the extreme, if you disconnect everything from the generator and it still fails, you have a generator problem
Sep 19, 2017 | Electrical Supplies
My sdmo 1000 generator has no spark at the spark plug can anybody tell what is wrong and where I can get the parts to repair it regards Eric
If it has a ICU that would likely be the cause, check with the dealer of this product for parts. We are not a parts dealer for any product and can only suggest a likely source.
Oct 11, 2016 | Electrical Supplies
My sdmo generator writes "alarm: V High" what do I do what is the reason for that?
Could be too things.
Voltage too high.
Heat very high.
What does the manual say?
Feb 11, 2016 | Electrical Supplies
SDMO LX 4000 petrol generator manual
Try searching online. Most companies' product manuals are readily available. You can also call their sevice/parts department number.
Oct 03, 2014 | Electrical Supplies
Having SDMO genset V250 volvo engine with Leroy Somer Alt 60 hz.Having problem that engine Shut Down with the message Min U Alt. Can anybody help me to solve this problem
Min U is minimum voltage output. If it occurs when under load, check load types and for shorts. If it happens during no load, check voltage regulator and exciter, and diodes
Aug 17, 2014 | Electrical Supplies
Generator alarm underspeed
When you get the under speed alarm is the generator under load? Try manually starting the generator with no load and let it run for a while, if no alarm, then put it under your home load and measure current draw (maybe have an electrician check it) if the amp draw and in rush caused by compressors, pumps motors etc are within the generator rating, check your fuel pressure, on average 8-11 WC Nat gas. Pressure may test well under no load but drop starving the engine of fuel unde rload. Underspeed is just that engine cannot make RPM/Frequency
Nov 28, 2013 | Generac Power Systems Generac 5522 14 Kw...
My coleman powermate 1850 will run for about 15 to 30 min, then it shuts down. Then I have to wait 1 to 2 hours to start again. could it be the low oil switch has gone bad? or is it a plugged exhaust
Could be a bad magneto coil, check for spark right after it shuts down. If no spark you need a new coil, If you have a bad coil it will heat up and will not generate a spark but after it cools down it will work until it gets hot.
Oct 30, 2012 | Electrical Supplies
I need the maitenance manual for your sdmo 500kva generators
Regular maintenance for generator is necessary that can help prolong the service life of the generator.
Generator Maintenance Tips
Generators
Generator Set Maintenance Tips
Useful Maintenance Tips for Diesel Generator Set
Maybe You Are Interested VOLVO generator Volvo Generator Volvo Generator Set Supplier Manufacturer Factory in China
Aug 30, 2011 | Computers & Internet
My sdmo generator keeps shutting down temperature
Mar 28, 2010 | NEC Mitsubishi MGE 1800 Generator-Voltage...
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
