Question about Samsung Cell Phones
Samsung r610 cell phone display problem
I own a samsung r610 cell phone. Just the other day the display started acting wierd. The screen (with background picture) is blue adn there is a white bar across the bottom where the ''favourites/contacts'' are. Most times if I go to my mail, it gets scrambled and I can't see anything at all except for a bunch of horizontal wavy lines.
is it done?
thanks
SOURCE: Samsung Cell Phone Blue Screen
We had the same problem and found that if you press the 8 or 9 button while inserting the battery and then press the same key while turn the phone on and finally taking the battery out one more time. You should be able to turn the phone back on w/o any problems. Hope that made sense
Posted on Nov 30, 2007
STR8JCKTED
  • 42 Answers
SOURCE: samsung 340 cell phone
THIS WOULD PROBABLY BE AN INTERNAL PROBLEM YOU PROBABLY CANNOT FIX.SOME TYPE OF INTERNAL CONNECTION OR GROUND.YOU PROBABLY WILL NOT BE ABLE TO DO ANYTHING UNLESS IT IS UNDER WARRANTY
GOOD DAY
KZ
Posted on Feb 25, 2008
SOURCE: akai lct42z6tm
I had the same corner squares/scrambled display problem in a set just over a year old (of course). It became completely unusuable and I was not looking forward to a repair bill of hundreds of dollars. After reading these posts, I opened the back of the set and took out the board with the connections on it. (FYI, the cable connections were all hot glued down, but this did not present a problem - a little wiggling and they came free. I also took lots of digital pictures to make sure I reconnected it correctly.) This board had the four capacitors (C280, etc) mentioned in this section. Since I have not had any experience with soldering on electronic boards, I found a friend of a friend who was a techie and he agreed to look at the board. He replaced the 4 mentioned capacitors - although he said they seemed to be fine. He did, however, also notice that capacitor C336 in the same area of the board was bulging so he replaced it. SUCCESS. The TV is again working fine.
So if you are reasonably handy with a screwdriver, taking out the board is easy and makes transportation a lot easier than taking the TV to someone. The cost of replacing a few capacitors on a board was minor, and in fact, if I hadn't found someone with electronic soldering experience, I would have given it a try myself. You may, however, want to check for bulging capacitors (indicating a problem) rather than just replacing the ones mentioned.
Posted on Jun 10, 2008
SOURCE: FTM mode
Go into your phone's system settings (usually in tools and phone settings, something like that) NOT the service menu again, just the normal one that anybody can get to.
Look for a menu option that says "Standalone Mode." When you find it, turn that feature on, then turn it back off again. Hope that works, it did for me. Good luck!
Posted on Jun 30, 2008
  • 4234 Answers
SOURCE: Samsung HLS 5679W LED DLP TV Horizontal white lines jagged across screen.
What you are sseing is a convergence problem within the light engine of the set. This is not repairable in teh field other than replacing the light engine part. Since this unit is less than one year old, it should be covered under warranty. From the looks of it, one of the LCD panels has shifted internally. Call for warranty service and indicate that the light engine has a problem. With luck, the service company will show up with the part in hand. Replacement should not take more than an hour or so.
Dan
Posted on Aug 28, 2008
My Samsung Galaxy Y (GT-S5360) gets this wierd screensaver like thing with "FREE" across in and a red ribbon. After that "Samsung Galaxy Y GT-55360" appears in a static screen. This happens continu
it is a scansaver problem,you going to your extra scansaver setting portion and fixed your setting or it found your display setting portion there having a part "image change" you click that and set your problem.
Mar 26, 2013 | Samsung Galaxy Y Gt-s5360 - Black unlocked...
Hi, My Samsung Eternity touch screen started behaving weird. It doesnt click to the actual location where I touch. I tried everything I know but it doesnt work. Pls Advise
this is a screen problem in samsung.
The screen does behave wierd then it can not resond at all when phone is in hot humid weather.
Samsung must replace screen. I had the same problem with the Jet. There is a defect in the screens they used. They know it, this is a common problem.
Sep 28, 2010 | Samsung Eternity Cell Phone
Hi! The screen is acting weird, sometimes the
its the hardware problem of display slider chip, visit service center and get it resolve.
Feb 25, 2010 | Samsung SGH-J600 Cellular Phone
Guru series-SGHB-200 SAMSUNG MOBILE PHONE'SDisplay damaged
It is the LCD Screen which is to be replaced. In companys like Samsung, the LCD Screen can be costly. Thank you Sir, Have a nice day.
Sep 21, 2009 | Samsung SGH-D900 Cellular Phone
I locked my samsung r610 cell phone and i cant remeber the code
hi......... whats the lock code on the SAMSUNG R610 for messaging.. like when you go to the messaging "tab" and hit star
Jul 19, 2009 | Samsung Cell Phones
Music doesnt work
change the player mode and check shuffle is off is it is not off now off it and check in that loop is on keep on always ok buy
May 05, 2009 | Samsung SCH-U470 Juke Cellular Phone
Sep 25, 2007 | Cell Phones
Help me please with my phone!!!
Hi Ya! The problem could be with the bus that connects the key pad with the screen area. The way you open and use and the frequency of open-and-shut ruins the main contact data bus cable and evena single break can cause such phones to act the way you are describing. Take it to the Local Samsung Service Centre and get the Data Bus checked for damages and or else get the base s/w reloaded (Virus). Keep your phones BlueTooth OFF while you are moving in public, as viruses can be uploaded without YOU even noticing! Back up data and get the phone formatted. This should HELP solve!
Mar 26, 2007 | Samsung Dell Latitude D600 14.1 LCD SXGA+...
Cell Phones Logo
319 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
