Question about Electrical Supplies
I replaced a foyer light that is illuminated by a double light switch (switch 1 turns on the foyer light, switch 2 turns on the outdoor porch/garage lights) and have discovered that the wire from (I b
I am adding photos with captions in the comments below to help better illuminate my problem.
  • 1 more comment
  • Brett Ballantini May 08, 2014
    This is a shot of the current setup, both switches have top and bottom screws on the right side. The left switch is the one that works, intended to light outdoor lights but currently illuminating the foyer light as well!
    Everything I outlined above remains valid EXCEPT for the fact that I have found that while switch 1 (the foyer light) still buzzes and trips the fuse, switch 2 operates all three of the other lights (foyer, front door, and driveway)! This is a shot of the current setup, both switches have top and bottom screws on the right side. The left switch is the one that works, intended to light outdoor lights but currently illuminating the foyer light as well! Closeup of switch 1 on the right side, the one that is tripping the fuse instead of lighting the foyer light. Closeup of the right side of the second switch, which should illuminate the outside lights but now is lighting all three. A yellow wire enters from the top of the switch area and is attached to the top screw on the first (left) switch. An orange wire enters from the top of the switch area and is attached to the top screw on the second (right) switch. A red wire enters from the back of the switch area attaches to the bottom screw on the first (left) switch and loops over to the bottom screw on the second (right) switch. I hope that is some additional information that helps someone solve this odd problem. I'm not sure what I'm overlooking.
    OK, well, none of my pictures came up and I can't delete my question or comment to clean this up. I'll try to add my four photos here now.
  • 5,245 Answers
You have 2-gang switch.
Look at following illustration showing gang switches:
http://waterheatertimer.org/How-to-wire-switches.html#gang
Hot wire feeds one screw on first switch, and then jumpers to second switch.
Your jumper wire is connected wrong place.
Find hot wire... there will be 1 hot wire entering gang box.
Disconnect all wires, and separate for testing.
Turn power on and test each wire to bare ground wire... that will show the hot wire.
Sorry it is difficult to post question on fixya, or communicate with people answering free questions.
Gene h
Posted on May 26, 2014
  • 10865 Answers
SOURCE: 2-wire pull chain switch wiring in a ceiling fan light kit
If you removed a switch there should be two wires. Connect one of the wires to each of the switch wires or screws. good luck
Posted on Jan 22, 2009
  • 4090 Answers
SOURCE: putting outside lamps on exterior on timer
why not connevct them up to a movement sensor, that way they come on when you make a movement near them. So they dont fire off when cats or birds fly by make sure you set them to close to your height. Then you can see your way to the shed turn the lighjt on that you can now see where the switch is and then turn it back off when you leave. Most of these sensor lights can be set toa timed on period
cheap and easy to install
Posted on Jun 22, 2009
  • 45 Answers
SOURCE: How does the illuminated light work inside a
The neon lamp inside of the switch draws very little current (milli, or mico amps) so there is no significant current flowing to ground.
As for your real question, there are several various types of 3-way pilot switches:
Load on: Pilot on
Load off: Pilot on
Some 3-way pilot switches have an external lead which allows them to be configured either way.
If both of your switches are the same type and are wired correctly, they should work the same.
If you suspect that one is defective, try swapping them.
Posted on Aug 25, 2009
Testimonial: "Thank you very much. It turns out one of the two was simply dective. Thanks!"
SOURCE: Cooper Industries Cooper Wiring 274W Switch and
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Posted on Dec 08, 2010
gotgeek2
  • 565 Answers
SOURCE: IN THE OLD DOUBLE SWITCH I REPLACED WITH THE 5224,
The switch is wired backwards. Swap sides with the wires.
If you look closely at the switch you will see that one side has 2 screws that are joined together with a metal tab. _That_ is the side that gets the hot wire, pick a screw, it doesn't matter which one as long as you don't break off that tab.
On the other side of the switch you will see that the 2 screws are _not_ joined together with a metal tab. _Those_ are the screws that connect to each individual switch leg.
Posted on Dec 12, 2010
I need to buy replacement polls for 2 room dome tent with screen porch
try manufacturer for part replacement or thier customer service for assistance in part replacement
Jul 23, 2017 | Sport & Outdoor - Others
This is an edit of my original problem posted a few minutes ago. I'm replacing a foyer light that is operated by a double light switch ON THE WALL (switch 1 turns on the foyer light, switch 2 turns on...
Wiring is difficult to see without clear description of each wire inside the box... and more difficult when folks take wiring apart without taking photo of wiring before starting. Then they throw away the old switch,,, so comparison cannot be made to new switch.
That being said:
Did you install a new 3-way switch?
Is it a 3-way switch with 2 brass screws and 1 dark screw and 1 green screw? The dark-colored screw is common screw.
If you installed new 3-way switch, then it is probably wired wrong.
Or there is damage to a wire that is not covered with repair... or both bad wire and wrong wiring.
Look at OLD 3-way switch and identify which screw is the common screw. Should be marked on back of device.
Identify which wire went to common screw on OLD switch.
Look at NEW switch, and identify which is the common screw (dark-colored screw), and then attach OLD common wire to NEW common screw.
Otherwise, put old switch back into box... see if it works... take some photos... attach photos to comment to this thread ... take photo of new switch from back, showing all screws so I can see what is going on.
We can fix it it...and I will be here all evening to assist.
Gene
h
Sep 19, 2013 | Home
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
Aug 18, 2013 | Electrical Supplies
I have porch lights that are controlled by a switch in front entryway and also from garage. (3-way) I want to put a timer in entryway and by-pass the garage so lights come on from only one location.
10-24-12
Identify which of 2 switches has the Hot or Power wire.
Hot wire will be connected to dark screw on one of the switches.
If Hot wire is in garage box, then follow this Step 1-2-3 diagram for ST01C timer:
http://waterheatertimer.org/images/GE-15312-3-way-circuit-6-60.jpg
If Hot or power wire is in entryway box, then you have a '3-way no neutral,' so cap off 3 wires going to other switch. ..
http://waterheatertimer.org/How-to-wire-switches.html#3-way-a
And then wire ST01C timer as single pole no neutral.
http://waterheatertimer.org/images/ST01C-single-pole-284.jpg
Oct 23, 2012 | Intermatic Inc. ST01C Digital In-Wall...
I am replacing a programmable timer switch that controls exterior garage lights. This switch is in the same box as a ac switch that turns on the lights inside the garge. There are 3 rolmex wires inside the...
Project is not clear.
Are you replacing the timer with a switch?
I have complete files on timers, so if you are replacing the old timer with a new timer, then add a comment and say which timer you are installing.
You have 3 cables. Assuming 120Volts.
Each cable has 1 black and 1 white and 1 ground.
White wires are twisted together and pushed to back of box.
Ground wires are twisted together and pushed to back of box.
Black wires are next:
(A) Cable A:
One of the three cables will have a black wire that connects to both the switch and to the timer.
So look for the black wire that connects to both switch and to timer.
This is the hot wire from breaker box. Connect this black wire to both switches including new switch.
(B) Cable B: One cable goes to garage lights. Black wire going to garage lights connects to on-off switch.
So the garage light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
(C) Cable C: One cable goes to outdoor lights. Black wire going to outdoor lights connects to new on-off switch.
So the outdoor light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
Jun 27, 2011 | Hardware & Accessories
Just bought a x reg ford puma but the key fob does not work, bought a new battery and fitted it, needs re-programming but don't know how to do it.
Telephone: Fax: VAT Registration No.:
Infrared remote control
NOTE: Infrared emitter can be seen at front edge of key.
System operation
Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system.
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Ensure LED remains illuminated. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds.
NOTE: A maximum of 4 keys can be programmed. Fig. 1
Radio frequency remote control
System operation
Pressing tailgate release button twice within 3 seconds unlocks the tailgate - if fitted. Pressing key lock button once activates central locking and alarm. Pressing key lock button twice within 3 seconds activates double locking system. Interior lamp illuminates when disarming system.
Programming
When
How
Obtain all keys fitted with remote control. Fasten seat belts and close all doors. From position I, turn ignition switch as follows: To position II. To position I. To position II. To position I. To position II. To position I. Programming mode activated for approximately 20 seconds. LED or fog lamps ON warning lamp illuminates (some models) or the system will emit an acoustic signal to indicate start of programming mode. Proceed as follows: Type 1: Press and hold unlock button Fig. 1 [1]. Type 2: Press unlock button Fig. 2 [2]. Ensure clock LED or fog lamps ON warning lamp flashes (some models) or wait for acoustic signal (indicates correct programming). Wait 2 seconds. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode: Switch ignition ON. Wait 20 seconds.
Aug 25, 2010 | Ford Focus Cars & Trucks
Need a faceplate for the timer
this is a common item. I would try a home depot or lowes first then an electrical supply house. or go on line to intermatic.com
Jan 05, 2009 | Intermatic Inc. EJ500C Digital Wall Switch...
Electrical Supplies Logo
199 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
