Question about Microlife Health & Beauty
Where do I have my monitor calibrated?
I purchased a Microlife BP 3BT0-A monitor some years ago and can not find an agent to help me. I live in Pretoria, South Africa. Thank you for your time.
3 Suggested Answers
SOURCE: Program date and time
http://www.microlifeusa.com/files/manual/files/MLU3MQ1-IB.pdf
4.3. Setting the date and time
With the unit OFF, press the Time/Date button on the side of the monitor and hold for
three seconds until you see the icon start flashing in the upper left corner of the
monitor screen. The Memory button becomes your scroll button and the
Time/Date button moves you to the next time, date or user.
When the User icon is flashing, you can toggle between User 1 and
User 2 by pressing the M (Memory button). If you press the M
(Memory button) one time and the User changes to User 2, you can
press the Time/Date button to set your unit on User 2 or you can press
the M (Memory button) again to go back to User 1. Either way you
must press the Time/Date button on the side of the monitor to confirm
the setting and move on. The unit will automatically move on to the
Time/Date settings. If you don’t want to change the Time and Date
then just keep pressing the Time/Date button six times until nothing is
flashing on the monitor screen.
If you want to change the Date and Time, then press the Time/Date button once the correct
User is flashing on the screen so you can move on to set the correct year.
The unit will automatically move to the Year setting after the User has been set. To
change the year, press the M (Memory button) to scroll forward. Please note: You cannot
Time/Date button
on left side of
monitor.
scroll back so scroll slowly so you don’t miss the correct year. If you do pass the correct year
the unit will scroll all the way to 2050, then start again at the year 2000. Once you select the
correct year, press the Time/Date button to set it and move on to set the correct month.
Then the Month will begin flashing. Again, use the M (Memory button) to select the correct
month and press the Time/Date button to set it and move on to the day setting.
After you set the month, the Day will begin flashing. Again, use the M (Memory button) to
select the correct day and press the Time/Date button to set it and move on to the hour setting.
After you set the day, the Time hour will begin flashing. Again, use the M (Memory button) to
select the correct hour according to AM or PM and press the Time/Date button to set it and
move on to the minutes.
The last setting is the Time Minutes. The minutes will be flashing. Again, use the M (Memory
button) to select the correct minutes and press the Time/Date button to set it and complete
your setting.
Please NOTE: You can cancel out of setting the User/Time/Date by pressing the Start/Stop
button. If no operation occurs during the User/Time/Date setting process, the unit will automatically
cancel out of it. To re-initiate the setting process, press and hold the Time/Date button
for three seconds until the User icon begins flashing. Start the procedure all over again or
press the Time/Date button again and again until you reach the desired location to reset.
Posted on Feb 13, 2010
  • 6 Answers
SOURCE: where do I get my omron bp monitor calibrated
I assume you mean checked for accuracy - something that you should do every two years. I assume you live in Canada or the US, if so please contact OMRON at the number below. They will be able to direct you to a service centre near you.
CONSUMER SUPPORT TOLL FREE NUMBER: 1-877-216-1333
Customer Service Representatives are available
Monday through Friday - 8:30am to 4:30pm CT
Posted on May 07, 2010
How to set the date and time and calibrate monitor for 01-540
Google (brand)(01-540)(manual) without parens
Nov 08, 2016 | Health & Beauty
Cuff does not get full inflated even after getting it properly applying error3 appears,I m a Doctor
replace batteries,or there is a leak,you didnt say which bp machine it was so go here and find your machine to get the user manual for it, Microlife Manuals
Apr 02, 2015 | Microlife Health & Beauty
I have digital blood pressure monitor Model bp3bm1-3.it is not turn on, why ?
i have micro life bp aparatus since 3 years but from last month it diosent work good every attampt it indicates low blood presure at all on screen it dosent go up by 140 and all the time it shows 90 / 50
please advise what to do
Sep 27, 2012 | Microlife 3AC1-PC Blood Pressure Monitor
How to clear memory on a microlife bp 3ar1-3p
With power on, showing only clock.
Press M button, then press Power button together.
About 10 seconds, it'll display CL on screen.
Lift up your finger, CL will flashing.
Then press M button once, you'll hear 3 beep
Done.
Jul 08, 2012 | Microlife 3MQ1 Blood Pressure Monitor
SOFTWARE PROBLEM DURING PUMP FUNCNTION SO MANY ERROR I WANT UREGENT SERVICE PLESE CONTACT NO. & ADD. SERVICE CENTER IN AHMEDABAD
What brand of BP Monitor?
Is this a personal BP monitor?
Or is it a hospital BP monitor?
Well.. you have to check the cuff to see if it's OK. Most of the errors are because of the cuff which has a balloon inside the cuff.
It depends on your model.
On some models you can take off the cuff line. Check if there is air coming out from the BP machine. If there ir air, it must be probably the cuff.
If both the cuff and machine is OK, then the problem must be the machine calibration.
Is it electronic or manual BP?
Hope it helped.
God Bless You!
Feb 05, 2011 | Health & Beauty
Where do I get my omron bp monitor calibrated
Apr 27, 2010 | Omron Automatic Blood Pressure Monitor w/...
Where is omron bp monitor service center in india my bp monitor doesnot get enough preesure and shows no 50 on the screen.
call rehman on mobile no: +91-8754414889 for all your query of omron or other make of blood pressure monitor service problems
Jan 19, 2010 | Omron Automatic Blood Pressure Monitor...
What does error 3 on my microlife blood pressure monitor mean?
I have digital blood pressure monitor Model 302 made in japan. It is not working. when start shoes error 3. Please advise
Jun 28, 2009 | Microlife 3AC1-PC Blood Pressure Monitor
Health & Beauty Logo
88 people viewed this question
Top Microlife Health & Beauty Experts
Colin Stickland
Colin Stickland
Tom Chichester
Are you a Microlife Health and Beauty Expert? Answer questions, earn points and help others
