Question about Garden
I need a wiring diagram for a 7 terminal ignition switch on a Huskee riding mower.
  • Garden Master
  • 2,478 Answers
Hope this helps I need a wiring diagram for a 7  terminal ignition - abfeaa57-d292-474a-89b4-c828b010f4de.jpg
Posted on May 09, 2014
rockitman187
  • 2559 Answers
SOURCE: need drive belt diagram for LGT2654 Huskee
Here is a link to the manual on pages 7, 8, and 40,
Please take time to rate this a fixya
Posted on May 10, 2009
lester482529
  • 226 Answers
SOURCE: I need the wiring diagram for a 7 terminal
GO TO PARTSTREE.COM. PUT IN YOUR MAKE AND MODEL# THIS WILL PROBABLY BE WHAT YOUR LOOKING FOR HOPE THIS HELPED
Posted on Jun 11, 2009
SOURCE: need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Posted on Jun 22, 2009
SOURCE: NEED WIRING DIAGRAM FOR MTD 14.5 HP OHV I/C RIDING MOWER
try going to www.tulsaenginewarehouse.com/drawings/allwiring.pdf
Posted on Aug 29, 2009
bbreton
  • 437 Answers
SOURCE: I need a wiring diagram for the ignition switch on
Go to www.partsdirect.com. This is Sears website for equipment information. Put the model number in and it should find the model you are working on. A diagram should be available there.
Posted on Sep 25, 2009
Testimonial: "Thank you for you're quick response Robert Webster"
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
Where are the fuses on a huskee lt4200
Usually in the wiring harness that attaches to the back of the ignition switch in a blade type fuse holder or a twist lock style for the older glass tube fuses.
Jul 30, 2016 | Garden
What is the wiring sequence for the ignition switch on a John Deere CR125 ride on mower
Go on BING images, put in John Deere Ignition switch diagram and all sorts pop up. See if that helps. Most are the basic switch setup. Keep a copy for the future.
Nov 15, 2014 | Garden
Ignition switch
Find the wiring diagram on the web at one of the parts sellers. There are few differences in ignition switches, and not that many to be worried about. You will have battery, starter, ignition GROUND{to kill the engine}, and perhaps PTO accessories, and lighting. That's all I can think of. The terminals are labeled and the diagram should explain what each terminal should be connected to.
Dec 18, 2012 | Garden
MOWING DECK WILL NOT "TURN
A wiring diagram and a test light are needed. If you don't have the wiring diagram, use a test light, start at the clutch and work your way back checking for current at each switch/connector. It maybe the ignition switch, there should be one terminal on it that feeds 12v to the clutch curcuit.
could be your ignition switch but thats the best way to find out where its not getting power to.
May 28, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My dog tore out some wires on lt1000 17.5 hp ridng mower. inow have it wired so it will start and run,but have one wire i dont know where it goes. from the ignition switch the blue is hot the black im not...
If you unplug your harness from the key switch on the back of the key switch you will see by the terminals letters stamped a S for solenoid a L for lights B for battery G ground and a M for magneto. This will tell you were the loose wires should go. Hope this helped.
Mar 17, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Jun 06, 2009 | Garden
Need drive belt diagram for LGT2654 Huskee
May 10, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
I have a toro 8-25 rear engine rider model 56172 serial # 8008773, I need a wiring diagram for my mower. It is messed up,and some *@#$%+&* mess it up before I got it. I received a diagram for a 7-25 and it...
None of the numbers you supplied match any info on the toro.com web site. Check the numbers and then see if toro has any info for you.
That said, it sounds like you connected to the wrong relay terminal. Here is how you want it connected:
The battery (and alternator) connect to one of the large terminals on the relay. The starter connects to the other large terminal. The start switch connects to the small terminal on the relay. The idea being that the small current connected to the small terminal turns on the relay which connects the large battery current to the starter.
Obviously there is more to the wiring than just that, but you didn't ask about the rest...
May 05, 2009 | Garden
Garden Logo
539 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
