Question about Uniden Bcd396t Trunktracker Iv Apco Digital Handheld
I need help programming this scanner - Uniden Bcd396t Trunktracker Iv Apco Digital Handheld
Cannot get scanner programed
Most radio scanners these days have software that you can program from your PC etc, You will also need a cable, if not supplied. Check at the Uniden website. However you should be able to program it manually. Again the instructions that came with it? should tell you how.
Normally a scanner can be programed to scan between two frequencies ie 144 to 146 for the 2mtr amateur band etc
or you can program channels.
Feb 09, 2014 | Uniden BC340CRS Base Scanner
I need to program the scanner
http://mycusthelp.net/UNIDEN/FILEXFER/issue_1301/BC248clt%20web%20om.pdf
Here's your manual, they have easy to understand directions on programming. Hope this helps.
Sep 26, 2009 | Uniden BC248CLT Base Scanner
Programing Pro2096
There is a Yahoo GROUPS for this scanner and the PRO-96 - join and they can help you out-okay?
Aug 11, 2009 | Radio Shack Pro-2096 Base Scanner
To reset or re program my scanner model # bc178xlt
You can reset your scanner by pressing ""HOLD 2,9 and shut it off and turn it on hold all them buttons down when you do this!
Hope this helps!
Feb 03, 2009 | Uniden BC248CLT Base Scanner
How do I Program my Uniden Bearcat BC60XLT
how do I program bc60xlt handheld scanner
Aug 11, 2008 | Radio Communications
i am having trouble programing frequencies into my scanner i need help!!!!!!!!!!!!!!!!!!!
Aug 09, 2008 | Uniden BC60XLT-1 Handheld Scanner
Help
Hi - You can download the manual from the link underlined in blue below:
uniden Bc72xlt
See page 33 for programming.
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 20, 2008 | Uniden BC72XLT Handheld Scanner
How to program scanner
A downloadable copy of the manual is available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Uniden BC60XLT Handheld Scanner
Uniden Bcd396t Trunktracker Iv Apco Digital Handheld Logo
66 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
