Question about Health & Beauty
Scooter problems scooter starts after a few feet stops no beeps and starts to move again
  • 42 Answers
Possibly loose or broken wire somewhere. Take it to a dealer
Posted on May 08, 2014
  • 61 Answers
SOURCE: I have a ctm scooter the battries are charged
I would say the throttle pot is slightly out of neutral allowing the scooter to travel slightly when turned on. Try moving the throttle lever slightly in the opposite direction to which the scooter is travelling (i.e. if the scooter moves forward when turned on, press the lever to go backwards, but only a small amount). If the scooter stops and you hear a clicking noise from the back of the scooter (this would be the brake clicking on) then that would be your problem. Would just need a small adjustment but best left to a dealer as it has to be sopt on! Sometimes scooters will not work if the throttle is slightly out but if its only a very small amount out of neutral, it might sometimes work in the manner you have suggested. We have come accross this fault on a few occasions. Hope this helps...
Posted on Mar 19, 2010
  • 177 Answers
SOURCE: The motor or transaxil lock up and stop the
Hi. Sounds like the circuit breaker ( over load switch ) is tripping out. If you let it sit for a few minutes, does it start to work again? Does it stop when you are driving onthe flat ground, or when you drive up a slope.
I have had cases where this happens to scooters going up a slope, usually because the circuit breaker is rated to low. Sometimes a faulty or burn't out motor will cause this fault.
Also check that the brake solenoid ( free-wheel )is releasing properly. Can you push the scooter when the brake is released?
Good luck. Neil.
Posted on May 31, 2010
Testimonial: "thanks for the help"
taran_2005
  • 10515 Answers
SOURCE: Pride Legend 3-wheel scooter. I
This problem can be caused by a faulty signal from the throttle lever to the processor due to an intermittent failure of the throttle lever or the temperature switch for the motor is showing an "over heat " condition & the processor shuts down the system , until the switch is cycled. This will need to be checked & tested by a technician to verify the problem for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 24, 2011
my-mobility
  • 9 Answers
SOURCE: Scooter just stops
Battery connection problems cause the controller to overheat. Once you have allowed the electronics to cool down, all seems well again. Get on your knees and check that the battery terminals are secured very well. Happy scooting. Regards Chris… info@mymobility.co.nz
Posted on Jun 22, 2009
  • 177 Answers
SOURCE: Scooter moves approx 10 feet then stops led flashe...
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
Posted on May 28, 2010
My shop rider chameleon scooter beeps when I turn it on but it won't move the battery shows fully charged
Make sure the lever that disengages the motor from the wheels is in the engaged position. If it beeps a certain number of times then stops for a few seconds and then starts up again, count the number of beeps. That is a trouble code. You will need the owner's manual to determine what the code means by the number of beeps.
Dec 17, 2015 | Health & Beauty
What is problem with my rascal 305 four wheel scooter
your problem is related to the overload breaker on the chair you need to figure out why the breaker is tripping either due to batteries going bad or the brushes in the motor need adjusting or replaced , also you need to check the automatic brake is releasing completly a dragging brake will cause the auto reset breaker to trip
Oct 01, 2014 | Health & Beauty
How to stop a continuing beep on my Cordoba scooter when I turn the key on? The scooter don't move at all.
Hi Mag,
I have this steps that might help you with beeping sound on your Scooter. Hope it helps.
UNIT LIGHTS UP/HORN WORKS BUT UNIT WILL NOT MOVE
Possible Cause:
  • This often occurs when the scooter is in free wheel mode and is not in drive mode. Re-Engage the free wheel lever which is located down near the rear wheels (normally a yellow or red lever).
  • If you hear a beeping noise, the beeping you hear is a fault beep indicating the scooter main control box has detected a problem. Contact your dealer who can diagnose the beep code.
  • Check batteries with load tester - If either battery drops more than 1 volt under a load, the battery(s) are bad. Replace "both" batteries.
I also find these additional steps on how to know beep alarm indicators:
This main control box has a self-diagnostics feature & cannot be tested with a volt meter. When a
problem is present the main control box will diagnose the fault, prohibit the scooter from being driven
and sound an alert beep. Each alert beep indicates a different issue which helps to determining the
problem by narrowing the fault into one of a few main areas of the scooter. Reference this information
below for the alert beep indications.
Very Rapid beep- Batteries are low. Charge & test batteries.
Medium Fast beep- Motor/brake wiring fault. Free wheel lever disengaged.
Solid beep- The charger is plugged into the scooter (some models may vary).
Very Slow beep- The throttle pot was not at center when you turned the unit on. Throttle pot off
center or wiring (yellow & orange wires) fault.
Apr 24, 2014 | Shoprider Health & Beauty
Good luck. Neil.
May 31, 2010 | RTO Mega Motion 3 Wheel Travel Pal Scooter
I have a ctm scooter the battries are charged fully when i switch on the scooter will not work switch off and on again it then will travel a few feet before stopping
Mar 07, 2010 | Health & Beauty
Beeps when in drive won't move
How many times does it beep or is it continuous? Should beep a few times (usually up to 9 times), then stop, then beep so many times again, then stop and so an and so forth. Most of the time this is caused by the scooter being in freewheel or THINKING its in freewheel which could be a faulty brake switch. Also, on the GoGo ultra, the battery contacts regularly cause this problem and have to be replaced. They should be splotlessly clean and shiny for the contact to be good.
Feb 15, 2010 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
Scooter just stops
Jun 21, 2009 | Sunrise Medical Guardian Trek 4
Health & Beauty Logo
95 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
