Question about Power Tronic Computers & Internet
How long does it take a tronic 150w power inverter to be fully charged.and how long does it last after being disconnected from charging?
Tronic power inverter
  • 24 Answers
This device is meant to convert DC power from a car battery and similar devices into AC mains power suitable for running small appliances. It is not intended to be an energy storage device. Once plugged in, it does take a few seconds to reach peak output and will remain active a few seconds after input power is removed. This is due to the slow collapse of the magnetic field generated by the internal transformer that feeds the AC output. You'll notice this same effect in your laptop charger if it is equipped with an LED indicator light letting you know it is energized.
Posted on May 29, 2014
How do I charge my Motomaster Mobile Power Pack Model 11-1540-2?
It should have a small 120V to DC wall adapter charger with a DC wire / connector jack that plugs into the back of the power pack. Plug the wall adapter into 120V outlet and plug the DC connector jack into the back of the Power Pack. Leave on charge until the unit indicates it is charged fully (several Hours if it was fully discharged).
Nov 20, 2016 | Electronics - Others
Tip
Tips on how to make the cellphone batteries last for long
1. Do not charge the cell phone, hand held devices or PDA if the device is not running out of charge.
2. Make sure the phone is turned off while charging.
3. Do not disconnect the charger if the phone is not fully charged.
Doing these steps would make the batteries last for long.
Have a good day!
on Dec 01, 2009 | Cell Phones
After I charge my PSP ot last for about 10 mins but I charge it up fully
You need a new battery! Only charge your psp untill full. Then disconnect the charger! If you leave it on charge constant you damage the battery! Also battery's dont last forever and a psp is not in its prime. Good luck!
Nov 15, 2014 | Sony PSP (Piano Black)
Vivo manuals
150W inverter should match with the input power to this TV. Check whether TV has any other faults.
Gopakumar Gopalan Google
Aug 13, 2014 | Element Electronics FLX-2210 22 in. LCD...
Xantrex model rs2000. just purchased used. owner said all worked. got wired up, charger does not operate, shows no external power source, (led not lit). checked power to unit, at 119-123 acv.. inverter...
If it shows NO external source, then this is most likely the best place to look to find out why not?
http://www.ehow.com/how_7519715_troubleshooting-ac-inverter.html
Now above is a link that show you how to troubleshoot an AC inverter. Now below, there is a service manual, here at the back, is a factory troubleshooting chart that will be beneficial to you.
www.xantrex.biz/...Inverters/.../XS400_Owner_Guide(975-0054-01-01_Rev- B).pdf
The Biggest problems with Inverters is Flat/Low/Bad batteries, Sometimes it pays to remove the batteries and charge then up remotely, and then replace them, fully charged, Now a fully charged 12 volt battery should have 13.8 V DC at the terminals with NO LOAD. If the battery only reads 12 V it is not properly charged.
Dec 20, 2010 | Xantrex Technology Xantrex RS2000 Sine...
My powersource400 have never last more than 4 hour and that is with a destop and a 75 watt bulb.
Assuming a car battery with a capacity of 70Ah at its nominal voltage of 12V, the total energy stored in it amounts to 12V * 70Ah = 940Wh.
Your Xantrex XPower 400 Inverter is designed to deliver continuous power of 320W at a specified efficiency of 90% (I doubt that, this degree may be achieved for ideal conditions of load / outside temperature / air humidity / current beer price, but not for the whole power range, but let it be 90% for the argument's sake).
Lets assume your desktop needs 150W of power (no high end CPU or graphics board involved), plus the 75W light bulb, plus 10% loss due to power conversion, gives a total of ~280W power need.
This is well inside specs, so no problem here.
However, your battery can deliver this power for 940Wh / 280W = 3.8h only until its completely depleted.
Your observation of four hours of time from full charge to depletion is thus quite exactly what you can expect, you have no reason for complaints unless you were promised a longer time under the conditions you give.
Oct 19, 2010 | Xantrex Technology Xantrex XPower Power...
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
Microtek Inverter not fully charging the batteries
xenion pure shinewave inverter not charging fully
Jan 17, 2009 | Computers & Internet
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Aug 27, 2008 | Xantrex Technology Xantrex Freedom Xmic...
Computers & Internet Logo
126 people viewed this question
Top Power Tronic Computers & Internet Experts
David Payne
David Payne
Are you a Power Tronic Computer and Internet Expert? Answer questions, earn points and help others
