Unstable wifi with router D-link dsl-2640u
The wifi lately is unstable the network keeps appearing and disappearing i'm using a somewhat old Dlink dsl 2640u
    New Friend:
  • 8 Answers
Call Technical Support at 1-866-414-4714 TOLL FREE
Posted on May 08, 2014
SOURCE: Wireless range of DSL 2640U Wireless G ADSL2 ROUTER
hi
it is 100m maximum
Posted on Apr 08, 2009
mail2pvs
  • 390 Answers
SOURCE: vio and d-link wireless router dsl-2640u connection problem
hi
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Posted on Jun 24, 2009
  • 1341 Answers
SOURCE: Really unstable Dlink dir-655 router
I would suggest you try to change the channel to a higher one and this solves this problem most of the times...You need to go to your router configuration to do that usually by opening a browser and type 192.168 ... and log in into your router...Hope this helps.
Posted on Jun 25, 2009
homedesigner
  • 583 Answers
SOURCE: how to connect my router without the phone line
Go into the router setup and disable DHCP. Then just plug the ethernet from your new modem straight to one of the 4 ports on the D-Link and you have 3 open ports to use with the computers.
Posted on Feb 25, 2010
SOURCE: d-link dsl - 2640u ' the lan is up but wireless no...
i have a dlink dsl2640u when i go in 192.168.1.1 and try to turn on the wireless and save it reboots 3 to 4 times then it stays on but the wireless is off any help
Posted on Aug 28, 2010
Dlink router dsl-2640u unstable wifi
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
May 08, 2014 | D-Link Computers & Internet
Hi, am haveing dlink dsl 2640u .its wireless is not working properly.it always ask for the key.whe i reset the router it work fine for 2 days and it again starts asking for key.i updated the firmware...
You may need to have your computer checked as well from a computer technician because its your computer that is always asking for the network key and not the router. Once you reset your router to default settings and make use of the routers default wireless configuration, it will always stay that way. There might be a possibility that the wireless card on your computer is the one that is having a problem because it always loses the saved wireless settings from your D-Link Modem Router.
Aug 28, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
My d'link dsl 2640u keeps disconnecting. i try to access the router throw 192.168.1.1 but nothing shows every time i need to restart my PC then everything would be fine and i can ccess the router...
Does your PC work on other networks reliably? If so- it's likely the DLink failing. The firmware issue is just a symptom as well. I'd recommend either seeing if you could use your DSL provider's original modem (if this was a replacement) or if you have another router- if it doesn't drop at that point, it was definitely the router/modem. However, if it drops still, you may have a line issue- but I severely doubt this since the symptoms are pointing to the DLink.
Jun 08, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
My D-Link DSL 2640U modem is working through cable but not wifi
You could probably log into the router interface and chnage the wireless settings and re-name the network. This might work.
Hope this helped.
Feb 13, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
How to configure my Airtel dsl broadband with dlink dsl 2640u router
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Feb 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
I want to change password on D-link DSL-2640U
Here is a direct link to show you how to secure your router, now you will need to reset your router to default settings before securing to do that press and hold the reset button located on the back of the router for 15 seconds or until router resets, you may need a paper clip to access the reset button.
http://ftp.dlink.ru/pub/ADSL/DSL-2640U/Description/DSL-2640U_B2_Manual.pdf
Jan 12, 2011 | D-Link Computers & Internet
I have bought a wireless ADSL modem, Dlink DSL 2640u , How can I install and use it for another laptop? I want to use it without wire. Thanks
all wireless devices must be allowed in the router by either MAC address or by name. This is accomplished by logging into to the router and setting up the device in with the wireless setup feature in your router. The router will not allow the device to connect without permissions.
Aug 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
D-link dsl - 2640u ' the lan is up but wireless no...
Oct 06, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Vio and d-link wireless router dsl-2640u connection problem
hi
Jun 24, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Computers & Internet Logo
David Payne
David Payne
