Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
My sharp aquos picture has got bright(luminous)green edges to all images.fine until today.less than 2 years old.help
  • Anonymous Mar 29, 2014
    green parasites on picture especially for luminous pictures
    Problem Solver:
  • 9 Answers
Sharp Aquos is a bit like saying Ford Estate . Without the model advice is a bit bland
There are know issues where the digital decoder can cause the main software to crash.
Although its not a DIY fix the updated software and a reset is often the cure fir this kind of issue,
If it is a software issue its the kind of thing we do over coffee break!
Posted on Jun 22, 2009
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No Picture
I doubt that your component has burned out. You may be looking at a repair issue here even though your unit is only 3 years old IF: you have tried connecting using different inputs, OR if you cannot bring up your sharp menu, or you list of inputs. If you cannot do those following things, you have a SERVICE issue on your hands and unless you purchased and extended warranty with sharp, its useless calling them. They will just tell you tough luck, and refer you to one of their authorized service centers. good luck
Feb 15, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SHARP aquos 1080p HDTV: VCR image flickers when playback
I have the same model TV and the following worked for me. I am using A/V cables attached to Input1 on back of the TV.
On your Sharp TV remote control:
1. Select the Input (1-5) that is attached to your VCR.
2. Go to the menu and select options.
3. Change your color system to NTSC.
This should stop your picture frome flashing on and off.
You still may have a issue with the screen colors. I don't know of a way to address this, other than to make the picture monochrome.
Hope this helps.
Jun 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Well I do not know either machine but suspect if the video is old either your video's output is too rough for the TV because:-
It has some age related problem of wear.
The output signal is not quite correct in quality.
There may be a security signal applied on its recording material.
These are some of the issues, videos are very sloppy (by todays standard) but could get away with it with analogue TV's because of wider design variables inherent in that system.
Modern TV,s are less hardware more software driven and as such are critical about errors going to a blank screen as a way of escape an issue they can't resolve (mummy mummy!).
The video may need checking for mechanical or electronic issues, a favourite being power supplies which can generate noise from defective components that disturbe other equipment, or mechanical alignment which changes through wear and time.
You could try conversion to hdmi signal though cheap converters are limited in their method of doing this but might show you if it would work.
Cheap versions are about £10 but have no level controls (contrast, brightness or colour to trim for best picture)
Hope this helps............
Apr 27, 2017 | Televison & Video
Sharp Aquos
Shine a bright light on the screen, do you see the image (but very very very dark)? If so, its either a bad inverter or lamps, which are only sold with the LCD panel as an assembly, which is very expensive (more than the TV is worth).
Mar 09, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Picture quality
I think you are right about the backlight. You need to replace the backlight tube or, if you can, replace the TV. Good Luck.
Sep 13, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
TV will lose picture then go into standby!
Yes it is a temp problem as you found out for your self Great call on that BUD.. the best thing to do is contact sharp to see if they have had simular problems and if there are any recalls on this model . If not they will instruct you where to send the monitor into to be fixed.
Mar 31, 2006 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
289 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
