Question about Garden
I have a briggs and stratton polan pro 6.75 ex and it just cut off on me
jgwhomeequip
  • 1902 Answers
SOURCE: Is the air filter on my lawn mower is washable?
You can do both. Just make sure that if you wash it with your hose you let it dry out EXTREMELY well before putting it back on your system
Posted on Jun 01, 2009
  • 18 Answers
SOURCE: wanted briggs and stratton 92908 manual
Find the B&S website and you should be able to download a parts or service manual.
Think it is briggsandstratton.com.
You will also need your type number (after the 92908).
Posted on Apr 18, 2010
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
  • 59 Answers
SOURCE: I have a poulan pro
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Posted on Sep 25, 2010
  • 111 Answers
SOURCE: I have a Briggs @ Stratton self-propelled mower
There is probably water in your carburetor that is keeping the unit from running. When you press the primer bulb you are pushing fuel past the water into the carburetor .. this is why it will start up. Then it will try to pick up the water and then the unit will die. I would loosen the bowl nut on the bottom of the carburetor and dump the fuel from the fuel tank into an approved container. Also you may take the carburetor bowl off and see if you can see some water on the bottom of the bowl. Keep the bowl steady when you remove it. Also, check to see if the carburetor has any corrosion from the water sitting in it. It may have a white "stalagmite" appearance, or a varnish if the fuel was left in it from the last time you ran the unit last fall. If there is any corrosion you may be able to clean it up with some carburetor cleaning spray. This is available at any hardware or automotive store. After you have done this, then put some fresh fuel in the unit and prime it up and see if it will continue to run. If it does not run, then the carburetor needs to be removed and cleaned. To clean the carburetor you will need a thin wire. You can use this wire to probe the holes in the carburetor and "push" any obstruction out of the way and then you can use the carburetor cleaner to make sure the passage is clear. Then blow the holes out with compressed air. This should clean it up. If the unit still does not run then you may have to replace the carburetor with a new one. If you have to get a new carburetor, take in the MODEL, TYPE, and CODE off of the flywheel housing. It is stamped in the metal.
Posted on Mar 31, 2011
Testimonial: "thank you very much. I followed your advice and I am back in business again."
Briggs & stratton v-twin engine cuts out
acid dip rebuild carb make sure fuel selinoid on bottom of carb moves freely
Sep 07, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My 17.5 Briggs & Stratton engine runs fine at idle
replace air filter, check throttle linkage position, take to a pro shop and have governer adjustment checked
Sep 04, 2011 | Briggs & Stratton Garden
Briggs & Stratton Poulon Pro 600 Series Cuts Out After a Min
Water in the carb bowl. Primer charge is gas...what the main jet draws is water! Tipping backwards lets the water move away from main jet pickup and clean fuel to enter engine.
Drain the tank. Then the carb and fuel line. Then check your gas can for watery fuel. *(dump it into a large plastic bowl and look to see if there is a layer of water on the bottom. If you shake up the fuel before you pour it off you will see cloudy liquid if there is water in it).
That should do it.
Jul 17, 2010 | Briggs & Stratton Garden
Garden Logo
145 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
