Question about DeLonghi ESAM Coffee Makers & Espresso Machines
I spilled coffe on modem and have no power can it be fixed?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 51 Answers
This problem does not relate to coffee machines..
Posted on Jun 21, 2014
Airbag light
I also have a 2001 Hyundai Elantra.
Awhile back (about 3 years ago maybe) I got a recall letter in the mail saying there was a problem with the airbag if any liquid was spilled in the area around the e-brake. I never did go in and get it fixed. then last year after spilling coffe all over the ebrake handle my airbag light came on. Not sure if it means it is defective or it just need to be checked.
Oct 11, 2013 | 2001 Hyundai Elantra
Coffe spill now screen on lap top not working
No magic fix here Philip. The only thing to do is immediately remove ALL power, AC adapter (Charger) and Battery, and open the laptop up, remove the CMOS Battery, (RTC Battery), and dry it out THOROUGHLY.
After you are SURE all components inside the laptop are dry, reassemble.
Install the Battery, then the AC adapter.
Plug into power. WAIT 1 minute, turn the laptop on.
[ On ships they use old coffee to clean the deck. It has powerful acids in it. Don't get your hopes up in otherwords ]
1) http://www.irisvista.com/
(Read the entire page )
2) http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
3) http://www.irisvista.com/tech/laptops/ToshibaM35X/Satellite-M35X-display-1.htm
4) http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-toshiba
Go down to the heading that starts with - Satellite A10. (A10 in blue)
Drop down to the fourth line (L655), and scroll across to - M30X
Click on the file name M30X.
(The Toshiba Satellite M35X-S161 Notebook PC, is part of the Toshiba Satellite M30X series of Notebook PC's )
After you click on the file name (M30X), it may take up to 30 seconds before the first page comes up.
A) Buy and wear an ESD wrist strap. Average cost is around $3 to $6.
Connect the alligator clip to a good ground source.
(Electro Static Discharge)
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
IF, the computer is still good you need to give it a fighting chance.
B) Use a multi-compartment container for the various screws you will remove.
Label each compartment for the area the screw/s come out of.
There are MANY screws that look VERY similar to other screws.
DO NOT mix them up.
C) Make a personal record as you disassemble.
Make notes, and drawings. (Legible)
Use a digital camera, or video camera if available. Use good lighting.
It's nice to have a personal record to refer back to, in case you are interrupted.
For additional questions please post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Toshiba Satellite M35X-S161 Notebook
I spilled coffe over it, can it be reapired?
it depends on the amount of curcuit damage but with mobile phones this complex i dont like you chances
sorry
Apr 24, 2010 | Samsung SGH-A877 Impression Cell Phone
Spilled water on modem now an amber light appears but fan inside not running so computer wont turn on? Can i get it fixed?
More than likely when you spilled the water on the modem (external I'm guessing) it caused a short and fried your motherboard. Any type of short can fry anything connected to it...even if the device doesn't have power. Since the ethernet cable can carry voltage it can happen that way too.
Dec 30, 2009 | Dell Inspiron 530 Desktop Computer
No coffe in the cup
Hi
I would say you have a stripped thumb screw. It is in the top left side of the brew unit and holds the filter screen in. If it is stripped there will be water or coffee in the pocket on top left of the brew unit.
Dec 26, 2009 | Gaggia Syncrony Compact Coffee...
Water spilled into my laptop Dell Latitude D600. what do i do
  1. Disconnect any power and remove the battery
  2. Tilt the system in various angles to drain as much of the water from the system as possible.
  3. Let the system dry for several days, (I'd say a minimum of 4) is a relatively warm place
  4. Insert Battery, see if system will power on.
If the system was powered on when the spill occurred and turned off by itself during the spill, then the motherboard has most likely been damaged and will need replacement. ($100 or so on EBay)
If the system will not power on after drying, you might consider replacement rather than repair as the cost of fixing it could exceed the replacement cost. (Dell has portables starting around $399)
http://www.dell.com/us/en/home/notebooks/laptop-inspiron-1545/pd.aspx?refid=laptop-inspiron-1545&s=dhs&cs=19
Dec 24, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
Spilled coffe on keyboard... is it toast?
Two things. It shows your careless or Sometimes it happens unknowingly. Better try using keyboard skins. This may help you.
Dec 12, 2009 | Toshiba Satellite A305-S6863 Laptop
The disk tray will not open because I selt coffe
You can use a pin to manually open the disk tray, if you look carefully at the cd draw there will be a little hole , get a paper clip or some thing and press it in there firmly and the draw will open. try then cleaning the spill and hope for the best. hope this helps.
Dec 04, 2009 | Computers & Internet
I spilled a coffe on the battery side of my laptop
Hi Shema,
In which area do you live in? You can just call up any laptop repair service and tell them your problem and also ask an estimate for the repair. You can call up more than 2 sevices and compare the costs and fix it up.
Thanks.
Nov 03, 2008 | Toshiba Satellite A60 Notebook
Hamilton beach coffee maker Model 49464
Leave the carafe off the hot plate and place the basket in holder with the lip under hinged flange so it sits flat. Then replace the carafe and the basket should not move up when the Pause and Serve button opens. I just bought this pot too and
love it but except for the basket placement problem.
Feb 18, 2008 | Coffee Makers & Espresso Machines
Open Questions:
Coffee Makers & Espresso Machines Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
