Question about Moultrie D55IR Digital Camera
WHY WILL THE MODE FEATURE NOT WORK - Moultrie D55IR Digital Camera
Dim on headlight not working, changed fuse,bulb,relay 15016745,and bulb connector,still want work-2002 trailblazer
Low beam's don't work , how about high beams . Low beam relay is turned on by the BCM - body control module , headlamp switch is a input to the BCM . Your best bet mite be to take it to a qualified repair shop , rather then guessing an replacing parts you don't need . Hooking up a scan tool an checking for DTC'S - diagnostic trouble codes should have been the first step before replacing parts .
The headlamp driver module (HDM) is an electronic module that provides electrical power to the vehicle low beam headlamps. The HDM is controlled by a pulse width modulated (PWM) ground signal from the body control module (BCM). The BCM determines the desired lamp intensity using the ambient light sensor, multifunction switch , wiper motor, and the park brake switch as inputs. In general, the HDM will operate in one of three modes:
• Reduced Intensity Mode: This mode is used by features that do not require or allow maximum low beam headlamp intensity such as daytime running lights (DRL) (nominal: 81% duty cycle).
• Full Intensity Mode: This mode is used by features that require full low beam headlamp intensity such as low beam headlamp operation in manual, wiper activated headlamp (WAH), or auto modes (nominal: 100% duty cycle).
• Off Mode: This is the default mode of the system that will occur when none of the features described above are active. The BCM will deactivate its PWM output (0% duty cycle) during this mode.
Chevy Trailblazer headlights don work HDM input output testing YouTube
Aug 27, 2017 | Cars & Trucks
2007 envoy the headlights on dim are not working
Did you check the fuse's an HDM relay #46 in the under hood fuse / relay box ?
Headlamps
The headlamp driver module (HDM) is an electronic module that provides electrical power to the vehicle low beam headlamps. The HDM is controlled by a pulse width modulated (PWM) ground signal from the body control module (BCM). The BCM determines the lamp intensity using the ambient light sensor, multifunction switch and the park brake switch as inputs. In general, the HDM will operate in 1 of 3 modes:
Reduced Intensity Mode: This mode is used by features that do not require or allow maximum low beam headlamp intensity such as daytime running lights (DRL) (nominal: 85% duty cycle).
Full Intensity Mode: This mode is used by features that require full low beam headlamp intensity such as low beam headlamp operation in manual or auto modes (nominal: 100% duty cycle).
Mar 16, 2015 | 2007 GMC Envoy SLT
Format feature does not light up
Check your shooting mode. Some features are available for a given mode only. If you set your camera to a pre-programmed mode, many features will be greyed - not available.
Aug 28, 2014 | Canon PowerShot Cameras
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
I HAVE A DEH-P640 AND THE SCREEN IS IN DEMO MODE AND I WOULD LIKE TO KNOW HOW TO TURN IT OFF IT IS VERY ANNOYING DRIVING AT NIGHT THANKS RON
Feature demo
The feature demo automatically starts when
power to this product is switched off while the
ignition switch is set to ACC or ON. Pressing 6
numbered button during feature demo operation
cancels the feature demo mode. Pressing 6
numbered button again to start the feature
mode. remember that if the feature demo continues
operating when the car engine is
switched off, it may drain battery power.
Notes
• You cannot cancel a demo mode when the
front panel is open.
• The red lead (ACC) of this product should be
connected to a terminal coupled with ignition
switch on/off operations. If this is not done,
the vehicle battery may be drained.
Apr 27, 2009 | Car Audio & Video
HI,I INSTALLED MY DEH-6500 PIONEER RADIO,CAME ON DEMO MODE,PUT CD IN VOLUME WORKS BUT CANT CHANGE SONG ON CD,TOOK CD OUT,BACK TO DEMO MODE WHERE I CANT DO ANYTHING,CAN YOU HELP GET ME OUT OF DEMO MODE...
Feature demo
Notes
Apr 26, 2009 | Car Audio & Video
Timer does not work in auto mode but does work in timed mode
Check the venting for your dryer. Most "auto dry" features are controlled by a thermostat that is in line with the timer motor. If you have a gas dryer especially, a clogged or obstructed vent will stall the auto dry feature. If you can provide the complete model number, I can provide more insight.
Dec 11, 2008 | Dryers
Can't use any features of playback mode
I've done some further research on the web..looks like a CCD problem and canon is inconsistent with free repair/postal costs.
Feb 01, 2008 | Canon PowerShot A530 Digital Camera
Red-eye reduction in macro mode
The red-eye reduction feature causes the flash to blink on and off rapidly, then flash normally. This may cause over exposure and subject discomfort in the macro mode.
Sep 13, 2005 | Epson PhotoPC 650 Digital Camera
Moultrie D55IR Digital Camera Logo
53 people viewed this question
Top Moultrie Cameras Experts
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
