Question about Frigidaire GLRS264ZA Side by Side Refrigerator
Frigidaire trips gfi when ice maker begins filling with water
Tried replacing GFI - new one does the same
  • 3 more comments
  • Brad Carlson
    Brad Carlson May 09, 2014
    Thank you - bypassing the GFI did the trick. But confused why the same unit worked for almost 9 years on that outlet. Saw something about perhaps being a bad diode online? Could that be the case? I appreciate your time & response.
  • Day Coker May 09, 2014
    Brad...the reason the GFI trips with your new refrigerator is because of the amp draw the control boards pull in order to properly run your ice maker while the compressor is also running. We are having the same issues in the field
    Jared... Can you describe the sound. Is it a knocking sound or clicking?
    Brad you should also have your gfi check to see if it needs to be place they also weaken over time.
  • Brad Carlson
    Brad Carlson May 14, 2014
    Thank you for the responses. Plugged into a non-GFI, it is working just fine. I replaced the GFI just before posting, bu the new one did the same. It would trip as soon as you would hear the water come on. No real sound other than the solenoid opening, then the snap of the GFI.
    Sergeant:
  • 304 Answers
It's recommended not to plug refrigerators into gfi's due to regulated amp draws you'll find that if you use an extension cord and plug it into a standard outlet that issue will go away
Posted on May 09, 2014
roadbird383
  • 40 Answers
SOURCE: Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Posted on Dec 05, 2007
  • 1073 Answers
SOURCE: Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Posted on Apr 17, 2008
Krazytech
  • 725 Answers
SOURCE: Frigidaire plhs267za side/side water dispenser leaks while ice maker cycles
You have a bad diode on the water valve connection frigidaire has a kit for this fix..
5303918287, 5304418384 DIODE KIT frigidaire
Posted on Sep 07, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
SOURCE: Frigidaire Ice Maker not working
I have a Frigidaire side by side refrigerator freezer MRS20WRGW0. I had the thermostat-defrost replaced yesterday. Now the ice maker isn't working, doesn't have water in the "tray" part that makes ice, but does still dispense water through the door. What could be causing this problem?
Posted on Mar 28, 2011
How do I fixed the gfi
That means your GFI is shot. You just need to buy a new one and replace it. Turn off the power before you do.
Oct 04, 2014 | Refrigerators
Seacoast magic plus keeps tripping gfi breaker
try in different GFI outlet, if it trips the new one, the coffee maker is dangerous and you should return/replace it, it has a short.
if it doesn't, replace the GFI outlet, it is old.
Apr 16, 2012 | Philips Coffee Makers & Espresso Machines
A6414w7b b wall unit gfi plug keep tripping problem: fedders wall unit brand new keep tripping the gfi on its power cord
GFI plugs go bad very often if you had a storm in you area. You need to replace the plug. Go to aplliance parts house and they will sell you the new cord. Feed back please.
Jun 13, 2009 | Fedders A6D24E7D Wall/Window Air...
My under counter Uline refrigerator/ice maker suddenly trips GFI
I here this alot. If you have a compressor on a gfi the compressor after awhile would trip it. The compressor start amps is usually higher than the gfi is rated. So you have 2 choices. Replace the GFI and try to find one with higher amp ratings. Or install a normal outlet for your unit. Your code will usually call for a gfi, If it does then replace with a new gfi.
To explain the start amps on a compressor depending on your model could be 10 amps. This is for a split second. However the gfi can become week after time. You can also try to plug the unit into a normal outlet to make sure everything is good on the unit. I believe it is the gfi
Jun 10, 2009 | U-Line Uline Origins Series...
GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Jun 01, 2009 | Whirlpool ES5FHAXS Side by Side...
The GFI that my refridgerator is plugged in to keeps shutting off
try putting it in non gfi outlet not supposed to use one in major appliances as everything grounds to body of unit
Mar 12, 2009 | GE Refrigerators
Traeger BBQ trips circuit breaker
Mine is doing the same thing, but it does it within seconds of turning it on. I'd assume you as well have the digital thermostat. I've narrowed it down to what I believe is the flame ignitor (or the purple connector). Unplug it and it should eliminate tripping and order new part or get warranty part.
Jan 16, 2009 | Traeger Industries BBQ070 All-in-One Grill...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
90 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
