Question about Teac Audio Players & Recorders
My DAB radio (technika 106) has internittant power. I've tried another plug adapter and it is not that. The radio turns on then after a few minutes the screen starts to flash and then the power goes off. Can I fix this problem?
  • 45 Answers
Most likely a bad earth (Ground)
Posted on May 08, 2014
techman
  • 3130 Answers
SOURCE: I have a Technika DAB-206
You have leaky filter capacitors in this radio, this is a common fault and these are soldered into a rinted circuit board. Good luck
Posted on May 29, 2008
hi-fi
  • 25 Answers
SOURCE: my dab radio has stopped
hi, you just replace the power adaptor with a new one,the power transformer may be defective.
hope it may help
regards
Posted on Sep 11, 2008
  • 1348 Answers
SOURCE: Mains hum on Ferguson R121 DAB radio
wrap aluminum foil around the power cord
Posted on Jul 19, 2009
SOURCE: Have lost four preset
Finally sussed out how to (re)set presets, overall you need a little patience:
Probably best to press Autotune before we set off and let it do its thing.
Press 'presets' and find a free channel or the one you want to change, leave it until you can hear the station its on play.
Now, press 'jog/select' and WAIT until it says <SELECT> (but don't wait too long when it says this or you'll have to start again)
Use dial to find station you want AND LEAVE to tune in.
Press AND hold presets down until number flashes.
Press jog/select once briefly (normally).
Press presets once briefly...it should now say "Saved"
Leave to save for a few seconds.
Voila!
You can now change station either by pressing Presets and moving dial...waiting for the station to load OR press jog/select to manually tune to the station of your choice using the dial.
Posted on Mar 01, 2011
SOURCE: Have bought a Technika DAB
To set alarm mode :- press Alarm 1 or 2 briefly to swtich between choices of Alarm On-Beep / DAB / FM / Off, keep pressing this alarm button until you get to the mode you want then stop pressing and leave to settle.
To set time: Press and HOLD Alarm 1 or 2 to change time. Minutes will flash first, use dial to change numbers, when you've got to the number you want press jog/select to change hour, use dial to change hour number. If you just leave it alone once you've reached the hour you want it will set where you left it, but...
If you want to specify preset channel/volume/beep tone etc keep pressing jog/preset after setting hour and use dial to set your preferences.
Where can I get new adapter?
The power adapter is most probably a standard type. On the radio, Check the voltage rating, the polarity. There are many adapters with multiple output voltage, multiple tips and reversible polarity.
If you want John Lewis (never heard that name before today) here is the website.
http://www.johnlewis.com/electricals/audio/all-radios/by-feature/view-all-radios/dab=features-518/c800001842
Jan 23, 2014 | John Lewis Galaxy Dab Radio w/ IPod dock
Garmin nuvi 40 will not charge
Sounds like a defective unit. You've tried everything their support people would walk you through.
Sorry...
Oct 31, 2012 | Garmin Nuvi 40
Wii wont turn on
Try this:
Reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the
Wii system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.Reset the AC adapter by following steps below.
Jun 27, 2012 | Nintendo Wii Console
Acer Aspire 5536 only gives black screen when i connect power supply
  • Nothing is more annoying than a monitor that refuses to turn on. Make sure your Acer monitor is plugged in to a functioning outlet. If it's plugged into a power strip, try replacing it with a new one or moving the plug to a different outlet. Ensure that both ends of the power cable are plugged in firmly and securely, and that the connection to the monitor is not loose.
Cable Issues
  • Your Acer LCD monitor will usually accept DVI and VGA inputs. If you have an older computer, a VGA cable should work fine. If it doesn't have a VGA port, you'll need to obtain an inexpensive DVI to VGA adapter at your local computer store. A DVI cable, however, is compatible with most modern computers and offers superior picture quality over VGA. Make sure you're using the cable that's compatible with your system, and that you have the proper conversion adapter, if necessary.
Jun 19, 2012 | Computers & Internet
Delphi roady2 SA10085 XM Radio Receiver with Car Kit
Sounds like its the dock itself. Have you tried using the home dock with the vehicle power or visa versa? This should help you confirm what the problem is. You can get a replacement power adapter here:
http://www.tss-radio.com/products/xm-car-power-adapter-for-6-volt-receivers
A cradle may be difficult to find, but TSS Radio can help you look.
Jun 05, 2012 | Delphi Roady2 SA10085 XM Radio Receiver...
I HAVE A SC-HC30DB SYSTEM AND IT'S NOT LETTING ME IN THE DAB MENU,DAB NOT WORKING ALL WORKING OK OTHERWISE.
I had the same problem - you can fix with a system reset. Unplug the unit at the wall and wait 2-3 mins, then plug in and switch on while holding the power button - the display will be blank for at first, but will eventually display '---------------------'. Release the power button and switch the unit on as normal. Press the Dab button and the unit will start to auto-search for channels. Give it a few minutes and you'll be back in action :)
Chris
Jun 29, 2011 | Panasonic SC-HC30 Audio Shelf System
Technika fm/digital frozen
Possible shorted power supply capacitor or bad diode.
Rod
Apr 20, 2010 | Audio Players & Recorders
I have lost the operating manual for a technika DAB 109 Radio
I HAS SAME PROBLEM BUT FOUND THE ANSWER. PRESS STANDBY AND TURN UNIT ON, THEN PRESS ALARM BUTTON, DISPLAY SHOWS ALARM 1, PRESS SELECT BUTTON DISPLAY SHOWS FM/DAB/BUZZ, PRESS LEFT/RIGHT BUTTONS TO SWITCH BETWEEN WAKE UP OPTIONS, THEN PRESS SELECT AGAIN, DISPLAY SHOWS OFF, PRESS LEFT/RIGHT BUTTON TO TOGGLE BETWEEN ON/OFF LEAVE 'ON' SHOWING, PRESS SELECT AGAIN DISPLAY WILL SHOW ALARM TIME, USE LEFT/RIGHT TO SET HOUR THEN PRERSS SELECT, USE LEFT/RIGHT TO SET MINUTES TEHM PRESS SELECT AGAIN, DISPLAY WILL NOW SHOW SMALL ALARM CLOCK IN DISPLAY WINDOW, THIS MEANS ALARM IS NOW SET.
Mar 07, 2010 | Audio Players & Recorders
134 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
