Question about LG 22" FLATRON LCD Monitor
Screen Half darker
Half upper side is darker than the half lower side.
When I change my viewing angle, in this case higher, it is better but the ratio is still the same, half of the screen is darker.
    Scholar:
  • 41 Answers
It sounds like your backlight isn't working properly. LCD screens have backlights that illuminate the colors produced upon their surfaces, so that you can easily see the screen without an external light source. In your case, it sounds like your backlights either aren't cailbrated, are damaged, or were produced unevenly.
There is most likely not a fix for this, though most all LCD screens have some form of light distortion. My own LCD screen is slightly brighter around the edges, where the backlights are located, but this is only noticeable when displaying a completely black screen.
Posted on Jun 22, 2009
Try also resetting the your monitor back to factory settings from the forteManager software that comes with it. It's under Options, Restore. I had a similar problem and this fixed it for mine.
Posted on Jan 06, 2010
How can I fix my visio tv 49 inch?
The backlights are out on one side.
Jun 15, 2017 | Televison & Video
TCL L46E5300F flatscreen half right side screen is darker than left side
If it is an LED LCD TV, the backlight inverter board should be troubleshooted. Contact any service technician.
Jan 09, 2014 | Vizio VW46LFHDTV10A 46 in. LCD TV
Sony bravia kdl-40s2010 top half of screen is fading
Most sets use two boards (each drives the image on half the screen) some combine both into a single larger board but if a even half of the screen is doing something the other half is not that is where the problem likely is.
Different makers use different names for this like T-Con or Y out etc.
You if interested might Google the model number with "parts" which may provide you a list of the boards in this set along with prices in some cases.
Dec 17, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
When viewed at an angle my lcd screen looks like a negative - is there anything I can do?
Unless this is some new behaviour of your TV, this is something totally normal, it's a common problem that is inherent to the Lcd technology, there is nothing you can do here.
Some TV have a better Viewing angle than others and it is getting better with every new screen generation.
On some model you can have a "Magic Angle option" but it is just for vertical angles - If for example you are looking at your TV from a lower or higher point of view.
Hope this helps
May 18, 2011 | Televison & Video
PANASONIC TH-42PX60U 42 - half of screen not working
I had the same issue. I am going to replace my scan buffer boards. The upper half of mine works but the lower half is black so I would replace the lower Scan buffer board but in case of future issues I have ordered both upper and lower for $44.
The scan buffer boards are fairly simple to locate. Open up back of tv there are two biffer boards identical. The item or product code on them contain letters either SU or SD (Scan up and Scan down)Look up tv parts and item code you will find a place to order or just get the 1 800 number from tv manufacturer.
Jun 18, 2010 | Panasonic TH-42PX60U Television
Upper half of screen is darker than the lower half
Its back light in LCD Panel problem, there are approx 20 CCFLs in 40" lcd panel and one or two in upper half is not providing enough light to give proper brightness so you see bit darker image.
As per Sony policy, lcd panel will be replaced to fix this issue and local tech can fix it on component level (replacing bad ccfl) if he/she agrees because its risky work.
Hope this nfo will help you.
Dec 28, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Upper half of the monitor is darker
I would try an auto-adjust first see if that helps any, also you could try it on another PC to make sure its not your video card on your PC. Another option is to reset the screen to its factory defaults see if that does anything.
Sep 30, 2009 | Samsung SyncMaster 932B LCD Monitor
Screen split in half
Hello, same thing happened to my 10 day old 60ps60 and we called LG and they came out and put "pin tighteners" on the Y board. All they are are these little white plastic clips that the technician put on the connectors. It is nothing you can fix. Call LG
Sep 05, 2009 | LG 60PS60 60 in. Plasma HDTV
Freezer and fridge not cooling (halfway)
SxS Amana upper half of feezer and Refrigerator not working
Jun 22, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Yellow area on screen
either burn in or magnetic field interference. I suggest moving any speakers away from the tv. if thats not the case, then find a strong magnet, make sweeping motions across the screen with it but dont touch the screen! Keep doing this until the colors change, then "sweep" them with the magnet into a corner and they will mostly dissapea.......r, sounds complicated but worked for me. can be scary so dont try unless sickly despearate or confident.   Hope This helps!
Jan 24, 2009 | Panasonic PT-51HX42 51" Rear Projection...
LG 22" FLATRON LCD Monitor Logo
2,738 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
