Question about Jandy Pool & Spa
How to flow
How to make sensor flow
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Jandy Master
  • 1,448 Answers
If pump is running check to see if you have voltage to pressure switch or jump it to check if works you need a new pressure switch also check to see if filter is clean if sand filter put it on recirculate this bypasses filter if works clean filters
Posted on May 26, 2014
Symptoms of faulty air flow sensor
  • How to Detect and Clean a Faulty Mass Airflow Sensor ... www.carsdirect.com > Car Repair > Engine Repair 2012-02-24 · Symptoms of a Faulty Mass Air Flow Sensor ... Here are some of the most common symptoms of a faulty mass airflow sensor: ... CARSDIRECT IS AN ...
  • Mass Airflow Sensor: An Easy Fix for Big Problems from a ... www.airtexproducts.com/news-blog-mass-airflow-sensor-an-easy-fix... news,blog,mass,airflow,sensor,an,easy,fix,for,big,problems,from,a,little,instrument. ... Mass Airflow Sensor: ... What Are the Symptoms of a Faulty Mass Air Flow Sensor?
  • Signs & Symptoms of a Faulty Mass Air Flow Sensor www.geeksofcars.com/list_5794328_signs-mass-air-flow-sensor.html Signs & Symptoms of a Faulty Mass Air Flow Sensor. The Mass Air Flow Sensor is a device used on many fuel injected automobile engines to measure the density of air ...
  • See Bad Mass Airflow Sensor Symptoms on YouFixCars.com www.youfixcars.com/mass-airflow-sensor.html Video embedded · Mass airflow sensor problems can turn on the check engine light. They can also cause a variety of other symptoms before the ... How to clean mass air flow sensor ...
  • How to ' Tell If You Really Need a Mass Air Flow Sensor ... www.youtube.com/watch?v=aDlHCjgYf8s
    • BY AUTO REPAIR QUESTIONS ANSWERED BY WESLEY HARRISON
    • 4 MIN
    2011-08-22 · Video embedded · ... How To Clean a Mass Air Flow Meter and Tell if you really need ... Mass Air Flow Sensor ' Auto Repair ' Wesley Harrison ... Sensor Symptoms ...
  • Videos too.,
  • Go to Bing homepage
    Jul 09, 2016 | Cars & Trucks
    My 1998 coast spa has three small lights flashing and the pumps will not come on
    3 lights usually means you have an issue with the flow sensors. Can't remember exactly, but there's two issues: pump is on and sensor not reading flow or not enough flow to register. Normal reason for this is to check
    • Dirty filter
    • Closed valves
    • Not enough water in tub
    • Plugged impeller
    • Falling / failed flow sensor
    Or... Sensing flow, but pump is NOT on, so there's no way for the sensor to be reading flow!
    • fix - replace flow sensor
    Feb 21, 2015 | Pool & Spa
    2008 Chevy Kodiak c4500 duramax desiel code reader (Innova 3100 Can OBD2) shows P0102, what does it mean
    P0102 Chevrolet - Mass or Volume Air Flow Circuit Low Input
    Read more: http://engine-codes.com/p0102_chevrolet.html#ixzz38p5k1ZD8
    Possible causes - Faulty mass air flow sensor
    - Intake air leaks
    - Dirty mass air flow sensor
    - Dirty mass air filter
    - Mass air flow sensor harness is open or shorted
    - Mass air flow sensor circuit poor electrical connection
    Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    Read more: http://engine-codes.com/p0102_chevrolet.html#ixzz38p5tpWZk
    Jul 28, 2014 | Cars & Trucks
    2003 Grand Am Has P0102
    It is not an ECM/PCM problem.
    P0102 - Mass or Volume Air Flow Circuit Low Input
    Possible causes- Faulty mass air flow sensor
    - Dirty air filter
    - Mass air flow sensor electrical circuit poor connection
    - Intake air leaks Tech notes Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor
    Sep 27, 2012 | 2003 Pontiac Grand Am
    Spare part 12(po100)
    P0100 NISSAN - Mass Air Flow Sensor Circuit Range/Performance Error
    Possible causes- Dirty mass air flow sensor
    - Intake air leaks
    Tech notes Before replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    Sep 25, 2012 | 1997 Nissan Pickup
    ISUZU TROOPER 3.2 V6 CODE P0101
    P0101 ISUZU - Mass Air Flow Circuit Performancexicon.jpghttp://engine-codes.com/p0101_isuzu.htmlForum CodePossible causes- Dirty mass air flow sensor
    - Intake air leaks
    Jul 04, 2012 | 2001 Isuzu Trooper
    Check engine lght on and 2 codes p0103 and p0112
    P0103 HYUNDAI - Mass or Volume Air Flow Circuit High InputPossible causes- Dirty mass air flow sensor
    - Intake air leaks
    Tech notesBefore replacing the mass air flow sensor, try replacing the air filter and cleaning the air flow sensor with low compress air or mass air flow sensor cleaner. Reset code and drive vehicle. If the code comes back, it may be necessary to replaced the mass air flow sensor.
    P0112 HYUNDAI - Intake Air Temperature Sensor 1 Circuit Low InputPossible causes- Dirty air filter
    - Intake air temperature (IAT) sensor harness is open or shorted
    - Intake air temperature (IAT) sensor electrical circuit poor connection
    - Faulty intake air temperature sensor
    When is the code detected?An excessively low voltage from the sensor is sent to ECM.
    Jun 08, 2012 | 2001 Hyundai Accent
    P0101
    P0101: MAF or VAF A Circuit Range/Perf
    - Intake air leaks
    Feb 09, 2012 | 1999 Pontiac Grand Prix
    I got the code from the OBD IT read a code of 23 and one of 36 now i need to find what it means
    code 23 is MAT too low.(mass air temp.) code 36 is Mass Air Flow Sensor Error
    The ECM receives a signal from the Mass Air Flow sensor depending on the amount of air entering the engine. The ECM uses information from this sensor to help calculate fuel delivery and spark timing.
    Fault Code Description
    • 36 - Mass Air Flow sensor error
      Symptoms
      • Engine stalling
      • Lack of power
      Common Problems Faulty Mass Air Flow sensor,Broken wire to Mass Air Flow sensor,Dirty sensing element in Mass Air Flow sensor
        May 17, 2011 | Pontiac Bonneville Cars & Trucks
        P0103
        P0103 MAZDA - Mass Air Flow Sensor High Input Signal Possible causes - Dirty mass air flow sensor
        - Intake air leaks
        Mar 07, 2011 | 2004 Mazda MPV
        Pool & Spa Logo
        Top Jandy Pool & Spa Experts
        David Spradling
        David Spradling
        Pj Kiley
        Pj Kiley
        Level 1 Expert
        Bill Jordan
        Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
