Question about Boss TU3 Tuner
Can't get the tuner to 440 Hz or reset factory settings
Tuner has G where it says pitch and keeps reverting back to it when I try to reset it...
I tune my guitars at 400 using a clip on tuner,which I believe is concert pitch I've recently bought a 5 string blue grass banjo .I set tuner to c mode to tune banjo is this correct
Actually, concert pitch is A=440 rather than A=400. Normally a 5 string banjo is tuned G (octave) D G B D though many variations exist.
Feb 20, 2015 | Ovation Music
Just purchased a used Alvarez FF60WR. The Electrical part works, but the on board tuner does not. It lights up when you turn it on, but the pitch indicator lights do not flash, and neither do the arrows,...
my on board tuner used to do that. I just tried to tune the guitar normally and it usually worked after a couple of seconds. The tuner needs sound to work - it won't work without you playing any notes :)
Aug 30, 2013 | Ibanez Ael20e AcousticElectric Guitar with...
My AG6 tuner its wrong at the moment of intonation. I comprobe it with a computer tunner (a program). I need to now how to tune my tuner. Thanks
Your Fender tuner is crystal controlled and if you set it for A440 Hz, it will be far more accurate than any computer program can generate. Most of these tuners have the ability to be set at different reference pitches. If your guitar intonation doesn't match at the 12th fret, then you have a guitar setup problem, not the tuner. The intonationation is set at the bridge if you have a bridge with individual adjustments.
Jul 06, 2011 | Fender AG6 SparkleTone Tuner
HOW TO CALIBRATE KORG DT-10 TUNER TO 440 TUNING
From the user manual:
While the setting is shown in the display, press the CALIB key to
set the calibration.
Each time you press the key you will cycle through the following
settings.
0: 440 Hz 2: 442 Hz 4: 444 Hz 8: 438 Hz
1: 441 Hz 3: 443 Hz 5: 445 Hz 9: 439 Hz
When you have made the desired setting, wait approximately two
seconds without pressing the key.
The indication in the note display will blink three times, and the
calibration setting will be completed. You will then return to tuning
mode.
Just do it and stop on the 440 one.
May 18, 2011 | Korg DT-10 Digital Tuner
How to reset the pedal 25 ME? thank you.
You can restore the settings in the ME-25 (memories, tuner
reference pitch, and knob response method) to the values set when
the unit was shipped from the factory.
Performing a factory reset causes all settings saved in memory to be
lost. If you want to keep the memory settings, use the ME-25 Librarian
(p. 11) to save them on a computer.
1.
Hold down [EXIT] and press the MEMORY DOWN
pedal at the same time.
"FA" appears in the display.
2.
Press [WRITE].
The Tuning Guide flashes.
3.
Press [WRITE] again.
The display flashes and the factory reset is executed.
Never turn off the power while factory reset is in progress.
Feb 15, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
My guitar is great I love it but the built in fishman isys tuner is not tuning my guitar properly and when it tells me my guitar is in tune it is really not at all. Is there a way to fix this ? Please...
Hey There,
If its adjustable its worth checking if the Pitch of the tuner is set right (normaly changed by a + & - button) Any normal tuner should be set to 440 which is standard Pitch.
Hope this is of any help
Jan 10, 2011 | Washburn NEW PRO WASHBURN ACOUSTIC GUITAR...
I have 2 digital pianos and an xk3 Hammond but i find the xk3 is out of tune to the pianos. is this possible can you help me please Gordon
Ooften there is a setting for the pitch. Set it to A at 440 Hz which is usual standard. HOWEVER make sure it is really a pitch difference as the ear can be fooled by the "hammond" type sounds.
Dec 29, 2010 | Hammond XK-3 Lower Manual - Pro Style...
My tuner reads D when it should be on E. It is set for 440. Please help. Thx
Test on another guitar first... If it only happens on yours, then you guitar MAY have a resonance in the neck or bridge that cross couples to your D string that MAY be the strongest vibration which the tuner is looking for. Try damping your D string while tuning the E strings by placing a finger on the D string to quiet the D..
Sep 19, 2010 | IntelliTouch Communications Intellitouch...
No instructions for a yamaha erg 121 c electric guitar
i don't really know what instructions you expected, although you should have received something for the tuner and amp. I suspect that you are new to playing the guitar, as, I don't wish to sound disrespectful, you would know what to do! So first, and again I hope not to sound like I'm treating you like a dummy, plug the guitar into the tuner input. Or if It's a piezo tuner clamp it to your headstock. Most tuners are now automatic so it should pick up on the string you are striking.Repeatedly pluck the same string til the tuner changes colour, or flashes, or some other indication to tell you the string is at pitch. Repeat the above for all 6 strings.
Then plug the cable into the amp input, switch it on, and bugger about with the controls til you get a half decent sound. ( thats what the rest of us do).Don't expext too much from this package, it is budget level, but of quite good overall quality.hope this helps
Feb 05, 2009 | Yamaha Electric Guitar
Boss TU3 Tuner Logo
82 people viewed this question
Top Boss Music Experts
Michial Gueffroy
shaun taylor
Robert Graf
Are you a Boss Music Expert? Answer questions, earn points and help others
