Question about Pool & Spa
The panel says no flow. what dirction should the cell be facing and direction do we install it for proper water flow?
    Champion:
  • 305 Answers
Do you mean your salt cell ? some models are multi directional. if you have a flow switch for your salt cell, ensure its facing against the flow of water. or you could have a faulty flow switch
Posted on May 09, 2014
If I hook the wires up backwards on the water pump on a encore energystar wht would it do??? It pumps put seams like the drum turning backwards lol ????
If you have two wires and hooked up correctly, than it should only turn in one direction. Make sure the pump is installed correctly (facing the correct direction of flow)
Mar 06, 2016 | Washing Machines
Tip
What is Backflow or R.P.Z.
Why get my Backflow device tested? Each Backflow device must be tested and certified at the time of installation , then annually once per year of the entire life of device.
Testing the device is important to insure safe clean drinking water, testing the device once a year is to insure the backflow is working properly.
Who can test a Backflow?
Only a C.C.D.I. Inspector can test backflow device‘s. Note: not just a licensed plumber, C.C.D.I. is its own license.
Once a person has become a licensed plumber, they are eligible to apply to take a C.C.D.I. course .
After completing the course, one becomes a C.C.D.I. Inspector.
Backflows that aren’t annually tested once a year can not guarantee clean safe drinking water to its users.
What is Backflow?
Water in a pipe can flow in either direction, Flow is the intended direction of wich the water should flow under normal working conditions. BackFlow is the flow of water in the un-intended direction.
Backflow can happen when unequal pressure causes the flow to be pulled back the opposite way intended, causing non-drinkable substance such as chemicals or contaminants from getting into the drinking system.
on Mar 28, 2010 | Plumbing
Is the 93 Mazda rx7 a traditional flow cooling system or a reverse flow cooling system... Meaning does the spring side of the thermostat face the "block" or the theremostat housing?
Hot water or air rises , water inlet goes in the lower part of the engine and exits at the highest point ,the thermostat control element must face the hot water.
Oct 01, 2014 | 1993 Mazda RX-7
2008 CTS front directional not working?
Try replacing ALL directionals for the side that is not working properly. That fast blink in the back usually means bad bulb, but could also mean bad relay.
Can you elaborate? You say emergency flashers work, but FR directional does not. Does the bulb-in-question light when the E-flashers are going?
Oct 19, 2012 | 2008 Cadillac Cts
Salt water pool cell shows no flow but there is no visible obrstuction in the cell
This could be many things but the first one to check would be the flow switch. This could be salt or calcium build up on the probes. You will need to carefully unscrew the switch so you don't bend the probes. If they are clean, plug the hole in the pipe that you removed it from and turn the system on. Then press the probes together and see if it shows flow. Clean or replace as necessary. When you reinstall, find the arrow on the probe and be sure it points in the direction of the water flow when finished installing.
Oct 02, 2010 | Intex Automatic Salt Water System for ...
I just bought my hot tub, it shows ''FLO'' on the panel when i turn it on. I did every thing they say on the panflet but it still doesn`t work. Anything else i should do??
The problem is that the flow switch for your water heater is indicating no flow. Therefore your water heater will not operate. Without proper water flow your heater will burn up. Check that your valves are open. Check that your pump is running. Check that your filters are properly installed and not restricting flow. Check the wiring to your flow switch and make sure the flow switch operating properly (i.e. put a ohm meter across the contacts and see if you have continuity when the switch closes).
Sep 18, 2010 | Apollo Pool & Spa
How do i change the fuel filter on my 2002 lincoln continental
Removal & Installation - Fuel Filter
NOTE Disable the air suspension before raising the vehicle. The switch is located on the left side of the luggage compartment.
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Turn the air suspension service switch OFF .
  3. Disconnect the negative battery cable.
  4. Relieve the fuel system pressure.
  5. Disconnect the fuel lines.
  6. Loosen the filter retaining clamp and remove the fuel filter.
    Fig. Slide the special tool into the fitting to disengage it
To install:
  1. Install the fuel filter with the flow arrow facing the proper direction and tighten the filter retaining clamp.
  2. Push the fuel lines on to the filter fittings until an audible click is heard.
  3. Connect the negative battery cable.
  4. Start the engine and check for fuel leaks and proper operation.
  5. Turn the air suspension switch to the ON position.
On 1992-up vehicles, install the fuel filter with the flow arrow facing the proper direction and tighten the filter retaining clamp.
Hope this helps (remember rated this)-
Aug 13, 2010 | 2002 Lincoln Continental
No hot water from bosch tankless heater
  1. If the display is blank, verify power to electrical outlet. (120VAC/60Hz properly grounded circuit required). Verify that the heater on/off switch is in the on (I) position.
  2. Verify the fuses in the control unit are good.To access fuses, the control unit must be removed. See BULLETIN TWH-G2-24 Two spare fuses are located inside lower access panel of control unit.
  3. Make sure cold water inlet connection is plumbed to the right side of heater when facing unit.
  4. A minimum of 0.8 gallons per minute (GPM) (3 l/m) is required to activate the heater. A quart container should fill in 20 seconds or less to activate heater.
  5. Clean inlet filter screen per chapter 5.2. of the installation manual.
  6. Inspect the water path for obstructions. Make sure all showerheads, faucet aerators and whole house filters are clear of debris.
  7. The heater activates when the water flow through the unit is at or above the required minimum of 0.8 GPM (3 l/m). A crossover creates back pressure on the water flowing through the heater. Therefore, a higher flow rate than normal is needed to force the heater to activate. To check for a plumbing crossover, shut off the cold water supply feed to the water heater. Then open all of the hot water taps served by the heater. Wait 10 minutes and check for water flow at taps. There should be no water flowing. Any continuous flow of water indicates a crossover is present and must be corrected. Consult a professional plumber for help in correcting a crossover. Failing single lever faucets and mixing valves are common causes of plumbing crossovers.
  8. With the ON/OFF switch turned to OFF (O) position and the power supply cord unplugged, remove theunit's front cover (See Page 5. Fig 3 of installation manual). Check wire connections between the water valve, control unit and electrode set. See chapter 9.2 of installation manual for location of these parts.
Feb 14, 2010 | Bosch & Tankless LP Hot Water Heater
Pleaase advise how to install the Cabin Filter on a Hyundai 2003
Open glove compartment. Press inward at both sides of the glove compartment, then lower the glove compartment.Remove the lower side instrument panel and crash trim pad. Remove the four glove compartment upper cover retaining screws, then the cover. Remove the two glove compartment retaining bolts, then the glove compartment. Press on the cabin air filter cover tab, then remove the cove
Remove the cabin air filter from the blower unit opening. Install a new cabin filter, ensuring the air flow marking is facing in the proper direction. Install the cabin air filter cover, ensuring the cover is properly installed.
Position the glove compartment to the instrument panel, then install the two retaining bolts. Install the glove compartment upper cover. Install the lower side instrument panel crash pad. Lift the glove compartment into position. Close the glove compartment.
Oct 30, 2009 | Hyundai Motor 2003 Sonata
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
