Question about GMC 1999 Truck C6500 Power Includes power washing, pressure washing E
Where is the hazard/ turn signal relay located on a 1999 gmc C 6500 ?
DumpTruck with air brakes. and hazard switch on the dash panel left of the steering wheel
  • 50 Answers
SOURCE: gmc sierra turn flasher location
The flasher on this vehicle looks nothing like the flasher's of yesteryear. It will be located behind the drivers side knee bolster(under the steering wheel). It will be a small black box that is about 3 inches wide, 2 inches deep, and 1 inch thick. It may be somewhat difficult to locate because on some of the GM trucks they actually hide it behind the guage cluster bezel but to the left of the guages. Let me know if I can help you any further.
Posted on Aug 21, 2008
  • 48 Answers
SOURCE: 95 GMC Sonoma --- Brake Lights and Turn Signals --- NOT WORKING
yes , i have a 96 mine done the same thing , i was removing the dash cover to install a radio accidently broke mine , i had to push down on what remained and wedged a sheetrock screw to hold it in place till i could get a new one
Posted on Dec 19, 2008
joecoolvette
  • 5660 Answers
SOURCE: no brake/hazard lights,have running/turn signal lights
Suggest you change hazard flasher 'can' first, then go to the hazard switch. I'm betting it's the flasher can.
Posted on May 11, 2009
  • 5 Answers
SOURCE: 1997 gmc 3500 box truck. no brake lights. changed
Check the fuse.
Posted on Sep 18, 2009
  • 9 Answers
SOURCE: 1996 GMC Yukon 5.7 Brake and
here is a wiring diagram. Are the bulbs for sure good?
hope you can read it.
Posted on May 03, 2011
Where is the blinker relay in my 2011 Chevy Equinox.
PCB Relays
This vehicle is equipped with the following printed circuit board PCB mounted relays.
• High beam
• Low beam
• DRL
• Fog lamp
• Park lamp
• Stop lamp
• Horn relay
They are directly soldered to the underhood fuseblock circuit board. A failure of one of these relays will require the whole under hood fuse block to be replaced.
Turn Signal/Hazard Lamps
The body control module (BCM) is responsible for controlling the turn signals and hazard lamps. When the turn signal switch is placed in either the left turn or right turn position, the BCM receives a signal from the turn signal switch. The BCM then sends an on-off voltage signal to either the left or right turn signals and their instrument panel cluster (IPC) indicator. When the hazard switch is pressed, the BCM receives a signal from the hazard switch. The BCM then will send an on-off voltage signal to all the turn signal lamps. All the turn signal lamps will flash including both IPC turn signal indicators.
Vehicles are just not the same as they use to be. Electronics !!!!!
Sep 25, 2015 | 2011 Chevrolet Equinox
4-WAY FLASHERS
Sir,
The combination flasher unit for the turn signals and hazard flashers is located to the left of the floor console behind the lower steering colum trim cover.
Thanks
good luck
gaframe = true; ' + '' + google_ads[i].line1 + '
' + '' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
' + '' + google_ads[i].visible_url + '
'; } } var adsByGoogleRight = "-40px"; if(dartRecieved){ document.getElementById("ga_300x250").style.clear="both"; document.getElementById("ga_300x250").style.left = "0px"; document.getElementById("inner_adv_caption").style.display = "block"; adsByGoogleRight = "5px"; } else if(isHealthinationExist){ var healthinationBox = $('healthonationBox'); if(healthinationBox){ var helthinationBot = getObjXY(healthinationBox)[1]+healthinationBox.clientHeight; var ga_top =getObjXY(document.getElementById("ga_300x250"))[1]; if(ga_top-helthinationBot >0){ document.getElementById("ga_300x250").style.width = "530px"; } else{ document.getElementById("ga_300x250").style.width = "410px"; } } $('boxAdWrapper').style.display = "none"; } else{ document.getElementById("ga_300x250").style.width = "530px"; $('boxAdWrapper').style.display = "none"; } //add "ads by google" var logo_img = 'abg-en-100c-000000.gif'+versionno+''; s += '' + logo_img + ''; document.getElementById("ga_300x250").innerHTML = s; var currl = $('related_links'); var currq = $('related_questions'); if(currl!=null && currq!=null){ var currltop = getObjXY(currl)[1]; if(currltop > rltop ) currq.style.clear="left"; } return; }; //-->
Sep 21, 2008 | 1999 Audi A4
How to fix no brake light issue on 1999 Expedition
Have you tried wiggling the hazard light switch? The brake light switch puts 12 volts to the hazard/turn signal switch,and the switch will apply this to both taillights.If you turn on the left or right turn signal,it will only route 12 volts to the other light.If you turn on the hazard lights,it will only allow the 3rd brake to come on due to the brake switch.Often.the hazard light/brake light contacts get corroded due to not being turned on and off regularly.Have someone watch the taillights(or use a mirror) to see if they come on when you wiggle the hazard switch.If it does,turn the hazard light switch on and of repeatedly to clean the contacts.
Jul 14, 2012 | 1999 Ford Expedition
I have a 2005 GMC w-4500 cab over box truck. The turn signals do not work. I have checked the fuse in the glove box, checked the flasher under the dash. The hazard lights work, but neither turn signal.
that could have two flashers one for the turn signals and one for the hazards lights.if you turn the hazard lights on and the flasher you located, you should feel it click as the lights flash.if it does it could possibly have another one for turn signals. sometimes it is a square relay in the fuse panel. and could be a problem with the turn signal switch this is the same as a isuzu npr.
Sep 15, 2011 | GMC W3500 Cars & Trucks
1999 firebird turn signal relay
you have to find it first not sure where it is located more than likely under dash is put your head into another firebird and turn on indicators should locate it by sound its just a plug in
Mar 25, 2010 | 1999 Pontiac Firebird
Where is the turn signal relay located in my 1999 pontiac grand am,,,,i already checked the fuses and the hazards work but no turn signals at all
the hazard button is the relay for both the turn signals and the hazards. you have to remove the trim panel that the hazard switch and radio are in pull it out of the back of that panel
Dec 28, 2009 | 1999 Pontiac Grand Am GT
1989 Lincoln Town Car Turn Signal Relay location
Thats strange they should be on the fuse panel ! Are you sure !!!!
Aug 12, 2009 | 1989 Lincoln Town Car
Flasher location
I believe the hazard/flasher relay is located under/left of the dash . I think if you remove the under panel under the steering column it should be attached to the BCM bracket under the dash on the left side.
Remove the left instrument panel (IP) insulator.
Remove the steering column filler panel.
Slide the hazard and turn signal flasher to the right, releasing the tabs from the Body Control Module (BCM) bracket.
Disconnect the electrical connector from the hazard and turn signal flasher.
Hope this helps.....
Apr 29, 2009 | 2003 Pontiac Grand Prix
I have no turning signals on my 1995 jimmy. The fuse is good and the four way flashers work. If the flasher was bad wouldn't the little turning signal light still light up on the dash? I'm not sure where...
there should be a set of huge fuses located on the top of the firewall under your hood. Look for a burnt fuse there or look for an outside fuse panel located close to the fender wall under the hood. Some makes and models also wont allow the lights to work in the dash even if there is a blown signal bulb.
Mar 31, 2009 | 1995 GMC Jimmy
93 buick century -turn signals
The Buick Century uses separate relays for the hazard warning and turn signal functions. The turn signal relay is located on the accelerator pedal bracket, and the 4-way flasher relay is located on the convenience center near the left kick panel. Try switching these two relays with one another to see if your turn signals work instead of your 4-ways.
Sep 28, 2008 | 1993 Buick Century
GMC 1999 Truck C6500 Power Includes power washing, pressure washing E Logo
Top GMC Electrical Supplies Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Lawrence Oravetz
Are you a GMC Electrical Supply Expert? Answer questions, earn points and help others
