Question about Pentair "Pentair" In Ground Pool Pump At251001
Why is the pump pulling water but blowing air as well as water in the pool?
We just put a new oring on and it is filling with water but when I plug the vacuum hose in it stops working and when I pull the hose out it still doesn't work
  • 2,760 Answers
Look for small crack in strainer housing or missing o-ring on cover , i use a eye dropper of blue dye on outside !! of strainer housing , a quick look at pool return and you'll see where the crack is , dry out housing 1st but superglue has saved many a cracked strainer from replacemnet
Posted on Dec 11, 2014
  • 3 Answers
SOURCE: pool pump won't prime
check for air leaks, cover o-ring is common culprit. anything in front of pump can cause this.
Posted on Jan 19, 2009
  • 61 Answers
SOURCE: pump is not pulling the water from the pool
*Check all of the drain plugs*...You would want to check for air leaks on the suction side of the pump. Make sure that there is water at least 3/4 of the way up in the pump and the valves are in the right position (sometimes turning the skimmer off and just sucking from the main drain can help). Also check to make sure that there is water in the skimmer, and it is not getting sucked dry. Next lubricate the pump lid gasket, and try some silicone around the threaded pipe on the front of the pump. If all this fails you could have some debris stuck in the impeller.
Posted on Apr 05, 2009
  • 366 Answers
SOURCE: When I turn the suction
sounds like you have alot of air coming from the pool. check the weir in the skimmer to make sure it's not stuck and blocking water from coming in, assuming the water level in the pool is normal.
If you have an auto cleaner, make sure the hoses are not cracked. Use a process of elimination to try and determine where the air is coming from. If you can't find anything obvious, have the line(s) pressure tested.
Posted on Aug 23, 2010
adamh294
  • 310 Answers
SOURCE: My pressure gauge is reading 0 when the pump is
1. Make sure multi-port valve if on "filter" (gotta start with the easy answers)
2. Remove the V-clamp holding the pump housing together and start inspection.
3. remove diffuser to gain access to the impeller.
4. check impeller for clogs (very common if around pine trees)
5. If impeller in free of debris, inspect housing o-ring, diffuser o-ring, drain plug o-ring, and shaft seal (if any one of these parts as failed, this pump will not prime and the filter will have no pressure)
6. If all these things check out, then it is possible you have a suction side plumbing clog. (is the skimmer and main drain protected by screens? if so, a clog is very unlikely)
Note: the most common cause of a loss of "prime" on a pump is a failed shaft seal. It is cheap and easy to replce.
You will not want to remove the impeller or do any serious work on this pump unless you have replacement o-rings for the internals. New o-rings and seals is what allows these pumps to work properly.
Hope this helps
If this post helped you, please take the time to vote positively for me on this site.
thanks,
adam
Need more help? adamh@newconceptchem.com
Posted on Oct 28, 2010
  • 106 Answers
SOURCE: I'm trying to drain a
Sounds like you're trying to pull water from skimmer and main drain. Soon as the level goes down, it sucks air from skimmer. Turn off skimmer line. If that's not possible, then cut off input side of pump(front pipe) and run new line to pool. Just lay it on top of ground and keep it below top by a couple of feet. This will stop all the **** on the bottom from plugging up the pump.
Posted on Mar 09, 2011
Pump air locked
Take lid if pump off, and fill with water.
Put lid back on and start.
if still won't prime, check orings everywhere Air can be sucked in.
System should be tight, so no air gets sucked in!
Jun 07, 2015 | Pool & Spa
My intex 637r pump is not pulling the water through to the filter and letting it discharge back into pool could it be that the pump and hoses are sitting to high on the ground and not far enough under the...
Air release valve for air trapped inside filter chamber
Intex 1000 GPH Easy Set Pool Filter Pump Instructional Guide 637R
The link has a set-up video for the 637R pump. Make sure water flows out of the air valve on the top of the filter cover. This will purge air out of the filter and prime the pump. Hope this helps you....
May 13, 2014 | Intex Krystal Clear Model 635 Pool Filter...
Pool cleaner starts and then stops working
Check for water flow / water flow restrictions / and water flow blockages.
Many things create water flow reductions: Dirty filters, plugged impellers, packed with debris baskets - both skimmers and at pump, closed to partially closed valves, air suction leaks: worn shaft seal, worn orings at pump lid or pump volute body, low water level, stuck skimmer weir blade/gate in the up position & skimmer empties and air is sucked into the system which may cause the pump to lose prime. This a problem that goes un-noticed and is hard to detect even by some service technicians!
Jan 31, 2014 | Pool & Spa
Loss of suction and loosing prime on pump
This can be a number of problems....
Are the filter , and all baskets clean? Is the pump impeller clogged with debri? Is the pool water level high enough for flow?
Is there something stuck in the line, do you have a pool vac if so check it for blockage.
If you think none of the above mentioned are your issue, then the next step is to find the air leak, which most likely is in from of the inlet of the pump, if you get a water hose or container of water, turn on the pump and then pour the water one by one on all the plumbing joints and or valves that are ahead of the pump, of one of them has an air leak the water will fill the air gap and allow the pump to prime and you have found the problem. This can be used on fittings after the pump as well but typically an issue like this is ahead of the pump.
Many times it will be the inlet pipe which is threaded into the pump or the valve ahead of the pump needs new orings.
Sep 05, 2013 | Dolphin Advantage
I'm trying to drain a pool that's Ben sitting for years full of nasty water. Pump works and operates but the fill pot on the pump itself will not stay full
Mar 08, 2011 | Pentair Pool & Spa
How do i hook a vaccum up to my model 604 filter pump?
You should take your vacuum hose and plug it into the hole in the bottom of one of the skimmers. Fill the hose with water first or your pump will loose suction. I fill my hose by putting the head of the vacuum in the pool. Take the other end and hold it over a pool's discharge port (where the water comes back to the pool from the pump. When the air bubbles stop, put your hand over the end of the hose and move it to the skimmer and connect it.
That work for you?
Thanks fo your visit today.
Jan 30, 2011 | Intex Krystal Clear Model 635 Pool Filter...
My Kreepy Krauly is working at half speed, any ideas? I've checked the tubing, no visible leaks, flapper works. Seems to pull air into the filter even after tubing is full of water. Both baskets clean.
Are you using a skimmer plate with the regulator valve or is connected direct to wall? Do you have a valve near pump that allows you to select skimmer or main drain or other input port? If so, select only skimmer. What is the pressure on your filter? Filter may need to be backwashed.
Aug 05, 2009 | Universal Kreepy Krauly In-Ground Pool...
The pump is not pumping out water fast enough. It a 637 pump for a 14x42' pool. The pump is not pumping out the water properly. If I unplug it and release the air valve hole the water comes out the top and...
Check the strainer housing on the front of the pump for a worn out oring. If you see water swirling around the in basket, it is a good indicator that air is making it's way in past the o-ring killing the waterflow. (the prime) Replace the oring. Make sure you lube the oring with a non-petrolum silicon grease.
Jul 04, 2009 | Intex Pool & Spa
Jandy pool pump will not prime it is a Jandy plus HP model PHPM 2.0
make sure pool is full of water
check skimmer weir doors and make sure not stuck in up position
fill pump basket with water and try to prime
if that doesn't work
replace diffuser oring
http://www.jandy-downloads.com/pdfs/PHP_Manual.pdf
May 25, 2009 | Jandy PHP High Head Pump 2 HP Up rated
Pentair "Pentair" In Ground Pool Pump  At251001 Logo
43 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
