Question about Kitchen Appliances - Others
I cannot get my my plastic bowl loose from the cookltop, ??
  • 1,340 Answers
First try filling it with Hot water, place a towel over it and give it a light smack with your hand- no- try filling it with Ice and some salt and a little water, same thing towel,smack. or you can try a plastic putty knife, this will lessen the chance of scratching the surface.
Posted on May 08, 2014
Water dripping out of a tubular part of outer plastic bowl.This is at the right rear, when viewed from the rear. It is an LG WF-T657 top loader
the plastic tube for the water level control is in that area
check for it to be attached , cracked or loose
Oct 26, 2016 | LG Washing Machines
I'm thinking about buying my cat a plastic bowl. Is this a good idea?
Plastic bowls aren't the best choice for your cat. They are the cheapest though so if you're looking to save a few bucks, they're a good choice. If you are going to buy your cat a plastic bowl, you have to make sure that your cat is not allergic to plastic because there are many cats that are. Also, you have to make sure you clean the plastic bowl very thoroughly because it tends to absorb many bacteria.
Sep 02, 2012 | Alessi Cats
What types of materials are cat bowls made from?
Most cat bowls are made from one of three materials - plastic, ceramic/glass, or stainless steel. I recommend a ceramic/glass bowl. Many plastic bowls harbor bacteria and stainless steel bowls (although they are best for keeping water cool) are not heavy enough and will be easily tipped over by your cat.
Aug 26, 2012 | Alessi Cats
My dog has a plastic dog bowl and I find that the water in it goes a funny color
Plastic dog bowls are quite cheap however I wouldn't recommend using them. Plastic absorbs toxins and this could cause health problems for your dog. Also dogs are natural chewers and they will more than likely chew a plastic bowl when left to their own devises. I would invest a bit more money on a metal dish, they are clean, long lasting, indestructible and safe.
May 13, 2012 | Pets - Others
Loose tank-how to fix
There are two large plastic nuts holding the tank to the bowl underneath and behind the bowl. You need to retighten the plastic nuts. You almost have to lay on your back on the floor to look up under the the tank.
Nov 25, 2010 | Kohler Memoirs toilet tank with Stately...
BRand new elongated Cimarron shoots water out of bowl durng flush
Is the fill line in the tank loose? Does it just shoot water into the tank itself? I had this issue until I realized the while fill tube is supposed to be pushed into the black cylinder/small plastic tube in the middle of the stopper assembly. After i pushed the line into the tube, the bowl would always only fill a little bit. Now it fills almost a 3rd of the way up the bowl and doesn't bubble during flushes.
May 09, 2010 | Kohler Cimarron Comfort Height elongated...
I have a WMA 31 washing machine. There is a serious leak from the white plastic bowl at the back. The bowl is fastened with a large bulldog grip. Could this have come loose? We bought the damned thing...
think you are referring to Sump/could be loose clip or damaged sump//if no transit bolts were fitted during transportation this can result in serious damage..Hope you manage to fix ok...
Oct 07, 2009 | Hotpoint WMA31 Front Load Washer
LG wd8013F bowl support plastic pin fell out. I turned machine upside-down, replaced plastic pin, now doesnt wash or spin.
(A) Set-up
1) The inner bowl is supported by (2) heavy springs at the top, plus (2) telescopic shock absorbers beneath the bowl.
(B) Observed Problem
1) Inner bowl was missaligned, causing out of balance knocking & banging, also drive belt was squealing from misalignment.
(C) Remedy:
1) Disconnect power from outlet.
2) Remove (4) screws from back plate, remove back plate.
3) Bowl is suspended on (2) heavy springs from top, and (2) telescopic shock absorbers below bowl.
4) Inspection showed plastic pin retaining shock absorber end to frame had fallen out.
5) Place old carpet or whatever on floor, invert washing machine.
6) Re-align end of shock absorber into housing piece.
7) Re-insert plastic pin (about 2 inches long x 1/2 inch diameter) securely into place.
8) Re-assemble.
Also:
a) It could be one of the top springs as per (B)1 above may have broken or become loose.
b) In this case the top cover plate is easily removed from machine by removing (2) screws at the rear top of cover.
This gives access to the (2) heavy springs, which are easily repaired.
Note:
Sometimes the machine will not re-start again following out of balance problems.
1) Turn power off again, re-boot like computer.
2) There is also a re-boot procedure similar to Alt+Ctrl+Del on computer.
3) Use three buttons simulateously, Start+spin+option buttons or similar.
4) I fiddled with these until all lights lit up, then after a while the machine worked satsifactorily.
Cheers
Nov 06, 2008 | LG Washing Machines
Cup for grinder
This happened to mine this morning. I was so frustrated because the reason I bought this was because of the removeable bowl. My bf got it off but he broke off a piece of plastic (he is pretty sure the piece of plastic was on the bowl part).
I put it back on and it kind still worked- I think I will just need to get a replacement bowl now - but it was hard to get off again.
When I tried to get it off the second time, I moved it into the "unlocked" postion and then manipulated the the blade part while pulling and it came off - but of course mine was broken already.
There appears to be two areas where it locks - on the base and a part on the bowl. I think somehow they get out of synch.
The problem is not with the base I think but with the bowl.
Although, now that it is "sorta" broken - I can't remember what parts were supposed to be loose before and which ones were not. The blade part of the bowl is very loose now. My boyfriend is pretty sure the plastic broke off the bowl part so I am going to get another bowl. I hope that solves my problem!
Feb 04, 2008 | Cuisinart DCG-12BC Electric Blades Grinder
Kitchen Appliances - Others Logo
53 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
