How to correct order error?
Correct an order error
How can I correct non system error?
The most common setup on BIOS boot order is the removable media first. IF there is a drive problem then that computer changes to the next item in the boot order. What you are describing is a failure to detect any of the boot devices. Check the CMOS battery to make sure it is ok. The easiest way to do this is by looking at the clock time and date on the BIOS screen. If it is wrong then the battery has died and the computer can not remember the devices. IF you had disk problem to start then the hard drive might have failed.
Jan 29, 2016 | IBM Computers & Internet
Error f01, what means?
The "F01" error code is indicating a communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Generally in order to correct this failure the CCU board will need to be replaced
Jan 05, 2016 | Washing Machines
Error code SY CE displayed plus lights in refrigerator and freezer not working
I appreciate your post, Carol!
Based off the information you have provided your Frigidaire refrigerator is displaying an error code of "SY CE" and the lights are not working. A "SY CE" error code stands for a communication error at start up. This might be a miscommunication within your refrigerator and I would recommend performing a reset in order to correct the issue. To reset your refrigerator you need to disconnect power from it for roughly ten minutes. If this does not help correct your issue you may need to change your control panel or a wiring harness. In order to properly diagnosis your refrigerator you may need to disassemble it and I would suggest having a professional technician out to do so. This will help you avoid any unnecessary part purchases or personal injury. -Matt
Jun 08, 2015 | Frigidaire Refrigerators
I have a se or 5e code what is it
Thank you for your post, friend!
I understand that your Frigidaire microwave is displaying the error code "SE" or "5E". I have researched and the error code seems to be "SE" which means keypad is stuck. In order to remove the error code the keypad would need to be replaced.
Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered and is installed correctly to prevent future issues. I hope this helps to some degree. -Matt
Sep 26, 2014 | Frigidaire Microwave Ovens
Press numbers display syntax error how solve a problem?
The order in which you are entering numbers and operations is not correct. For example, if you enter 5++2 most calculators will flag this as a syntax error.
On some calculators you calculate square roots as follows: 25 [SQRT]= gives 5. That is the correct syntax for this type of calculators.
For the newer ones you press the SQRT key and see displayed the square root symbol followed by a left parenthesis. You enter the number, close the right parenthesis, then =. If you do not respect the order you get a syntax error.
I cannot say more because I have no idea what you were trying to do, and more importantly, I do not know the make and model of the calculator.
Oct 28, 2013 | Office Equipment & Supplies
Ge pss26sgpass keep in defrost error code bc ?????
That is actually a "tc" error code.
This error means that the display board isn\'t communication correctly with the temperature control sensors which is why it\'s giving the error. It may stop cooling so you need to keep an eye out. Either way, try to unplug the unit for 5 minutes (don\'t plug it in early it\'s hard on the compressor). Plug it back in and see if the error goes away. If it doesn\'t, you need to order and replace your display control board because it\'s just not working correctly unfortunately.Here is the board to order.
Dec 01, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Hi my washer dryer 9kg front loader wd 1290 rd is showing a code d.h.e in the middle of drying?
here is a list of eror codes i dont think your reading what yours says correctly hope this helps
"IE" Water inlet error. Cause : Correct water level (246) is not reached within 8 minutes after water is supplied or it does not reach the preset water level within 25 minutes Ensure your taps supplying the washing machine are turned on. "UE" Imbalance error. Cause : The load is to small, the appliance is tilted, laundry is gathered to one side, non distributed things are put into the drum. Move the washing around inside the washing machine to create a more even distribution of weight "OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge "FE" Over flow error. Cause: water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. "PE" Pressure sensor error. Cause: the sensor switch assembly is out of order. "dE" Door open error. Cause: door not all the way closed, loose electrical connections at door switch and pwb assembly.The door switch assembly is out of order. Gasket on door maybe creased in. Try opening and closing the door, sheck to see the gasket isn't jamming "[-E" Heating error. Cause: the thermistor is out of order. CE Over current error. Cause: Main PWB assembly is out of order, Winding in the stator assembly is short circuited. LE Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective. bE Ball sensor error. Cause : Loose ball sensor connector,ball is out of order. This is displayed only when the start / pause button is first pressed in the OC test mode. EE (EEprom error) Cause: EEprom is out order. Displayed only when the start / pause button is first pressed in the OC test mode. PF Power failure. Cause : the washer experienced a power failure. E1 Leakage error. Cause : water leakage in hose connections. Water is leaked by damages.
Aug 11, 2010 | LG Washing Machines
Is it possible to reset pro 416 out of this problem.
Limited information provided.<br /> Pressing 8 start may give you a error code. Or a 8 plus stop button.<br /> If the machine has a C4 code, this may require machine software to be installed on the machine in order to correct problems. The scanner will not operate correctly even with a new scanner. The software needs to be installed by the service representative in order to align the correct software to main board, to correct laser heas assay.<br /> Good luck.<!-- from fixya rte -->
Jun 18, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
MP530- Printer issue
Install recommended ink tanks in the correct order MP500 / MP530 / MP800 / MP800R / MP830
Ink Tank Order Install ink tanks in the correct order (from left to right) CLI-8BK (Black) PG-5BK (Pigment Black) CLI-8Y (Yellow) CLI-8M (Magenta) CLI-8C (Cyan) mp500_inktankorder.gif 05sj00141_08_en.gif
Jan 01, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Computers & Internet Logo
David Payne
David Payne
