Question about Asko 1375 Dishwasher
I need the specs the dimensions of the dishwasher model 1375
3 Suggested Answers
  • 7 Answers
SOURCE: The drain pump motor on my ASKO model 1375
Had a similar scenario on my Asko 1325. I simply removed the unit in preparation to chuck it, but once outside decided to check the inside of the pump/impeller and the electrical connections. Found plastic debris in the pump, and wiggled every electrical connector of its attachment and then re-attached it. Tried the Asko-fiasko outside and it worked.
BTW be prepared for an electrical failure/ meltdown as per the following two photos:e4b01cd.jpg47ce737.jpg
Posted on Sep 01, 2009
  • 246 Answers
SOURCE: I have an ASKO dishwasher 1375 model in black.
You can try applianceart.com, they have alot of different color and texture appliance covers.
Posted on Feb 28, 2011
Does anyone have the specs for this model, HxWxD
Watts (W) 1300 W
Current (A) 12 A
Volts (V) 120 V
Frequency (Hz) 60 Hz
Tub type TallTub
Plug type 120V-3 prong
Dimensions & Weight
Overall appliance dimensions (HxWxD) (in) 34 1/8 '' x 23 9/16 '' x 22 7/16 ''
Required cutout size (HxWxD) (in) 34 1/8 '' x 24 '' x 24 ''
Product packaging dimensions (HxWxD) (in) 36 13/16'' x 26'' x 28''
Length inlet hose (in) 55''
Gross weight (lbs) 123 lbs
Net weight (lbs) 118 lbs
Of course you don't mention which model you have ??
Mar 18, 2016 | Bosch SHX68P05UC Dishwasher
Front top panel broken on ASKO model 1375 where can i get a replacement
Parts of that type might be hard to get for this model.
Try this site and select the part based on your dishwasher finish.
http://www.repairclinic.com/Shop-For-Parts/a9b126d610738/Model-1375-Asko-Dishwasher-Parts
Apr 01, 2014 | Asko 1375 Dishwasher
Asko 1375 not running right, turn it on hear humming only no water running
It is likely the inlet valve is faulty provided the tap under kitchen sink is open and there is water supply to the dishwasher.
Jan 12, 2013 | Asko 1375 Dishwasher
Needing to replace Kenmore Built in Dishwasher model 587.1426582 Wanting to find specs so I know what options I have for replacement
95% of all dishwashers are the same dimensions and hook up all the same unless I misunderstood you can buy any
Aug 22, 2011 | Dishwashers
Dishwasher begins to fill then stops with no further progress.
Welcome to FixYa.
Based on hoe you`ve described the issue with your Asko, initially it sounds like a faulty inlet/water fill valve...
But, I`d like to clarify the symptom first. Does the unit complete the fill cycle and then do nothing, or it just energizes the fill momentarily then does nothing ?
Also I will ask to verify the model is an Asko 1375 ?
I`l watch for your reply.
Regards,
Macmarkus :)
Sep 02, 2010 | Asko 1375 Dishwasher
I have an ASKO dishwasher 1375 model in black. Can it be spray painted with bisque appliance paint to match my other appliances?
Oct 20, 2009 | Asko 1375 Dishwasher
The drain pump motor on my ASKO model 1375 dishwasher wont stop running
Jun 22, 2009 | Asko 1375 Dishwasher
Need upper/lower racks for Asko 1375
An authorized servicer could order them for you but I just priced them and they would cost over $300. You can find a servicer at asko's website.
Jan 02, 2009 | Asko 1375 Dishwasher
Strange odour from dishwasher.
There was a recall of this model for fire hazard - the recall is still in effect
Dec 17, 2008 | Asko 1375 Dishwasher
Dishwasher does not drain after cycle
Check the drain pump and/or drain hose. It may be clogged woth something.
Jan 26, 2008 | Asko 1375 Dishwasher
Asko 1375 Dishwasher Logo
74 people viewed this question
Top Asko Dishwashers Experts
Owen Barnes
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
