Question about IBM Wheelwriter 6 Typewriter
How to fix the teflon cap on the solenoid end
  • 43 Answers
These caps just get hard and break and when they do you have either very lite print or none. Cap can be purchased and they just snap in place, no glue, no screws. Company out of Texas Coleman can supply.
Posted on May 08, 2014
  • IBM Master
  • 3,594 Answers
We sell the cap with instructions fo 20.00.
DickyO
216-269-3918
How do you cap off a flex copper refrigerator water line
Flex? Do you mean a braided line like this?
http://i.stack.imgur.com/9tE11.jpg
or a solid wall copper tube like this?
http://www.frankcondelli.com/staging1/store/image/cache/data/Camper/copper%20tubing%203:8-500x500.jpg
In the first case it should have a fitting on the end, usually female, for which you can buy a blind cap to screw in. See a hardware house.
In the second case you are best to sweat, or hard solder, a blind cap on the end. There are cold compression fittings using a teflon or copper olive
http://help.tradingdepot.co.uk/wp-content/uploads/2013/04/compression-nut-olive.gif
but they aren't generally recommend for terminating a pressurised line. If the line just has low pressure you could use one, and no heat is needed.
Jun 22, 2016 | Refrigerators
I installed a new ribbon but no type appears on my paper.
It is possible that your print solenoid is bad . You may need a repair kit that has a plastic cap that goes on the end of the solenoid. Any typewriter technician can fix that in a short amount of time.
May 19, 2016 | IBM Wheelwriter 3500 By Lexmark Electric...
Need to change the solenoid on 2008 haritage softail classic?
TO Disassemble
Remove the field coil and then pull the field coil with end cap from the solenoid housing, holding the end cap to the field coil to avoid pulling the armature out of the brush holder which would require further starter disassembly. Then with a 9 mm socket, remove the two hex screws with Phillips recesses to release the solenoid housing from the drive housing and if necessary use a dead blow hammer or a rubber mallet to separate the solenoid and the drive housings. And remove the return spring from the solenoid plunger shaft.
TO Re-Assemble
Install the return spring onto the solenoid plunger shaft and then mate the solenoid and drive housings and install the two hex screws using a 9 mm socket and alternately tighten them until they are snug. Then lubricate the armature bearing with LUBRIPLATE 110 grease and seat the armature bearing into the counterbore and mate up the field coil and solenoid housings. Properly assembled a small nub on the field coil housing flange must engage the slot on the solenoid housing flange closest to the short field wire post on the solenoid housing
Jun 21, 2014 | 2005 Harley Davidson FLSTC - FLSTCI...
Where is the TYPEWRITER SOLENOID on a IBM Wheelwriter 6 Series II
The "print" solenoid is what hits the hammer that hits the printwheel and makes it type on your paper. If you remove the ribbon and look straight down in the carrier on the left side you can see the solenoid. It is below the blue piece of rubber that sits on the hammer arm. The end of the solenoid is supposed to have a cap on the end of the plunger. This cap gives a specific clearance so when it is activated, it hits the hammer arm to propel it forward to strike the printwheel.
Apr 28, 2014 | IBM Wheelwriter 6 Typewriter
Replacing the print solenoid cap
The best way to find what you are looking for is to look at your printwheel. Right in the middle of the carriage there is a part that hits the printwheel. That is called the hammer. If you look down on the left side you will see a blue piece of rubber that attaches to the hammer. If you continue to look further down the hammer you will see the solenoid that activates and hits a screw that sticks out from the hammer. The end of the solenoid is where the "cap" can be attached. You do not have to remove the solenoid to install the repair "cap" if that is what you are really looking for. A technician can put in a new cap in less that 30 seconds.
Apr 11, 2014 | IBM Wheelwriter 6 Typewriter
Have a 1986 Harley Davidson FXRS that will not start, just hear one click back by the starter/solenoid. Any suggestions?
I would guess that the contacts in the solenoid are not making contact. I seem to remember that the solenoid is on the inside wall of the inner primary. Disconnect the battery cables and take all the wires off the backside of the solenoid. Take the solenoid off of the engine. Now, you've got to take the black end cap off the solenoid. Take the nuts off all three studs and take the two screws or bolts out that hold the black end cap on. Carefully remove the end cap guiding the lower and small terminal screws through the cap. When you get the cap off, look at the backside of the large screw at the top. It'll probably look burned off on the side towards the center of the cap. Push the screw out of the cap, turn it 180° and reinsert it into the cap. Then put the cap back on and put the nuts on the screw terminals. Put the cap back on the solenoid and reconnect the wires. Be very careful about how tight you tighten the nuts and screws on the cap. The cap is made of a phonelic type material and will crack very easily. You can get a complete rebuild kit from most aftermarket shops. This will probably fix your problem.
Good Luck
Steve
Sep 17, 2011 | Harley Davidson FXR Super Glide...
Steam nozzle not working
Check the end of the steam valve, if that is not blocked, check where the wand connects to the valve, on some models they inserted a teflon piece that was supposed to hep the machine with steaming but that gets blocked, remove and throw away.
Apr 16, 2010 | Saeco Royal Professional Espresso Machine
Wheel writer II will not print - replaced with new ribbon
There's a small cap on the solenoid that pushes the hammer, this cap wears out and the solenoid cannot push anymore. Cheap part, always wears out, new ones are teflon and last lots longer.
Jul 27, 2009 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 - No Impact
The teflon cap on the solenoid end needs to be replaced.
Jul 21, 2009 | Lexmark Wheelwriter 3 Typewriter
14h error
14: 2nd image transfer pressure/retraction failure
Relevant Electrical Parts
Retraction Position Sensor /2nd Image Transfer
(PC5)
Pressure/Retraction Solenoid /2nd Image Transfer
(SL4)
open cover, remove image transfer unit, behind ITU is 2nd image transfer roller, move it with hand, check solenoid and sensors, thaht they moving freely.
restart
good luck
Nov 11, 2007 | Konica Minolta magicolor 2400 Laser...
IBM Wheelwriter 6 Typewriter Logo
48 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
