Question about Cat Pump 623 - 10 Frame Piston Pump
What can i do with a cat 623 pump for a car wash mortor runs & belts turn but pump not pulling water
Water supply was empty going to pump mabey for a couplr hours primed pump it worked fine then stoped drawing water did this cfew times
  • 1,358 Answers
Make sure the inlet is clean, most of these get the hose hooked up without flushing the hose first and end up with grass,frogs and lizards plugging up the pump inlet.
Posted on May 08, 2014
My dwf-185mnp washing machine does not pump water out of the machine. please assit
Hi first you need to listen on the emptying cycle if the pump is running if you think it is then turn all electric off to the washer & find the filter it should be in your manual it may be blocked & its not un common for screws or small change button's ect' to block this if you don't have a filter the pump itself could be blocked when turned off & left for 30 mins use a spin cycle & listen if the pump is running if you have to empty the washer whilst still full make sure you have a large vessel for the water & something like a chopping board to deflect the water & have towels & mop's @ the ready hope this helps
Feb 08, 2015 | Washing Machines
Miele G892 SC Touctronic dishwasher, intake/Drain light came on. How do I clear the drain?
Evening to you - empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check if all clear - clean up & assemble - should be good to go...
Jul 01, 2011 | Miele Dishwashers
Water does not pump out. Actually it will load water, but when you pull to start, all it does is hum, it will not wash or spin and will not remove the water
Belt maybe slipping, empty out and turn on its side and check , if its direct drive the transmission may be empty of fluid..
Apr 16, 2010 | Whirlpool LSB6200KQ Top Load Washer
Washer wont spin
You may have some small piece of clothing stuck in the water pump. Pull clothes out, empty water out, turn over and remove pump and check for obstructions. If nothing in there see if it is frozen from moving, if not belt may be loose by being streched. Replace belt if needed.
Apr 16, 2010 | GE Spacemaker WSLP1100D Top Load Washer
Old Maytag a207 seems to run well, but gives poor rince.
Change out the pump belt and drive belt underneath the washer.
Remove the center filter from the agitator and clean it. It will twist out and pull up.
Dec 01, 2009 | Maytag Washing Machines
Kenmore 700 series, almost new
i would start by taking the pump off the motor and starting the washer if your washer agiates something is probably in the pump if the washer still does not work with the pump unattached to the motor you could have a bad motor
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Cat Pump 623 - 10 Frame Piston Pump Logo
64 people viewed this question
Top Cat Pump Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Cat Pump Garden Expert? Answer questions, earn points and help others
