Question about Watches
E377 The composite back cover on my E377 has disintegrated. Is there any possibility of obtaining a replacement cover ?
  • 1,363 Answers
I would set a saved search on ebay, for that watch or watch parts, and have the daily email checked, that way when one comes available you will know. that's the cheapest way I can tell ya
Posted on May 08, 2014
Casio AQ-164W battery replacement
  • Remove back
  • Find battery and note how it is installed
  • Identify type
  • Obtain replacement
  • Install battery
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Pay a jeweler a few bucks to replace it
OR
Oct 25, 2016 | Casio Watches
Finding and replacing the battery on my Zodiac sea dragon Z02270
  • Remove back
  • Locate battery. Note mounting arrangement for later battery replacement
  • Obtain replacement battery
  • Install battery
  • Check operation
  • Install back
  • Set time, etc.
Oct 19, 2016 | Zodiac Watches
What is the battery that my mk 5590 watch needs?
  • Remove back
  • Find battery and identify type. Note mounting arrangement and polarity (place watch in plastic bag to keep out dust while replacement battery is being obtained)
  • Install battery
  • Check operation
  • Install back
Aug 17, 2016 | Watches
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
BRegards
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
My signa E377 R/F watch wont reset to correct time.It,s 42 mins fast.I need instructions.Can anybody help?
Check you have the battery in the correct way and it is the right voltage/one for your watch
Apr 24, 2012 | Watches
Looking for Instruction Manual E377/E378 R/F Watch Having replaced Battery the LCD shows the correct time, date and month. But the pointers are 1hr8minutes fast
You don't say what make of watch you have but I think they work in a similar manner to mine, so try this.
Press the mode button (usually the lower left one) and observe the LCD screen. Each time you press the mode button the screen should change to a different setting mode. Keep pressing it until you find one that allows you to set the hands (on mine it is "HS"). Some experiment may be needed.
When you have found the setting you need, press the buttons on the right to move the hands forward or backward until the correct time is indicated.
When you finished, press the mode button until the normal timekeeping mode returned.
Jul 24, 2011 | Watches
I have a Casio TSR 100 IR ThermoScanner Watch (ca. 1995) but have lost the manual. I would like to be able to get a replacement manual online.
Hi,To obtain your user manual just write the code on the back side and click searched on the URL below which you can download a soft version of the user manual .
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Jul 19, 2011 | Watches
Can't close a ladies Versace case back 50 m with my regular press?
mcdevito75 here, Double check case and back cover line up, Clean mateing surfaces with a little alcohol and a Q"tip. The back cover may have gotton very warm and is now just a little to big for the case, temperature could cause the back cover to be so very slightly too large to fit the case, make sure both the case and back cover are the same temperature. I"ve does this myself, place the cover in the frig. for about an hour, this will make the back cover just a bit smaller than the case then try to re-fit the cover onto the case. If this fails, look for a small watch repair shop in your area. Just the cover in the fig. (lower section) not the case, the cold will shrink the cover and possibly give a better fit to the case.
Aug 03, 2010 | Versace 27473-008-00 Wrist Watch
I have lost the back of a gold ladies geneve watch. can I get a replacement back? Gold case, white dial with black clear numbers , gold brick link type bracelet. 9ct.Quartz model.
Best bet here is to go to a dealer that carries that brand and seeing if they can order you a new caseback.
Or, you can look for the same model online or EBAY that is broken or in disrepair, then just scrap it for the caseback. (It is not always possible to find one, but i recommend trying as this is the least expensive way to obtain small parts).
Oct 17, 2009 | Watches
Watches Logo
116 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
