Question about GE Refrigerator Automatic Ice Maker IM6
Psw23psta only crushes ice cubes
Even when on cubed, it only crushes the ice
Krazytech
  • 725 Answers
SOURCE: ice maker
check to see if you ice bin has full size ice cube in it... if there is then you dispense is stuck in the crush mode check to see if there is something keep the crushing wheels from releasing... other than that it could be the control on the door..hope this helps
Posted on Aug 26, 2007
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
SOURCE: ice dispenser will not switch back to cubed from crushed
Had the same problem, dispenser stuck on crushed ice, even when cubed ice is selected.  There is a magnetic switch behind the panel where the motor for the ice dispenser is.  It gets water in it and freezes so it is not free to go up and down.  It is always down for crushed, but for cubed ice, the magnet pulls it up.  when it's frozen with ice, all you'll get is crushed.  You'll have to defrost it.  You can defrost the whole freezer, but better to just remove the ice dispenser and defrost that. Three 1/4'' bolts hold secure it.  You'll have to unplug the wires from the back of the freezer to remove the unit. The just let it defrost and dry. You can remove the switch from the panel and dry it out too.   I've had to to this several times and am looking for a solution to keeping water out of the thing so it won't freeze again. Has anybody solved that?
Posted on Mar 28, 2009
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
samrat_babui
  • 296 Answers
SOURCE: Ice maker only makes crushed ice, no cubes
hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
Posted on May 27, 2009
Getting shaved ice instead of cubes
Several possibilities, but check first for cubes that are too small (means too little water is coming in during ice maker fill) and those cubes fracture into smaller bits when they are dispensed.
Another possibility is the cube/crushed plate inside the dispenser is stuck. This is a curved plastic piece that lies next to the crusher blades inside the dispenser head of the ice storage bin. For cubes this place must be retracted (swing away from) the crushed fingers to allow the cubes to pass without being broken up.
Oct 30, 2016 | Refrigerators
Mu Kenmore refrigerator's ice maker is dispensing crushed iced even in the cube mode
Take out the ice bucket and check the metal arm and make sure it moves freely. Ice may have gotten stuck.
Jul 20, 2016 | Kenmore Refrigerators
The ice maker of our GE GSH25JSXSS is only producing crushed ice even when it's set to cubed. Is there a way to fix this issue?
Check that the shifter bar on the bottom of the ice bin is moving to shift from cubed ice to crushed. With the ice bin out you should see movement in the back wall of the freezer with the light switch button held in while changing the dispenser controls from cubed to crushed. GSH25JSXASS Parts
Ice Bin Parts
Appliance 911 Sea Breeze
Nov 03, 2015 | GE Refrigerators
Why am I getting crushed ice when I requested cubes
Hello friend, thank you for your post!
I understand that you are receiving crushed ice even when you request cubed ice. It could be an issue within your control panel or solenoid. Since it could be any one of these under lying issues I would recommend having a technician come out to properly diagnose your appliance. Hope this is helpful. -Matt
Sep 12, 2014 | Frigidaire Refrigerators
My samsung rfg297aa dispenses crushed ice whether its set on crushed or cubed. why will it no longer dispense cubes?
This answer probably comes too late for you (you posted the question 9 months ago), but I want to record it here for posterity, since I had the same problem, and searching on Google for it brought up your question.
Anyway, I managed to fix this very problem by removing an ice cube that was wedged in the ice dispensing mechanism. The way this unit works is that it pushes the ice cubes through the mechanism, which always rotates the "crushing blades". When you select "cubed" ice, a lever opens up the exit chute wider, which causes the blades to simply push out the ice cubes as they pass through. When you select "crushed" ice, the lever closes the "exit" for the ice cubes to be narrower, so that the ice cubes can't be pushed through by the blades, and instead get crushed by them. I had an ice cube wedged in there that had the same effect of closing the exit to be narrower. Removing it fixed the problem.
You might want to collect all the ice cubes that have accumulated in the ice bucket in a container, empty the ice bucket, clean out the mechanism from any obstructions, and then put the ice cubes back into the ice bucket.
Feb 16, 2011 | Samsung RFG297AA (285 cu ft) Bottom...
Fridge Freezer model KA58NP90 Ice maker problem
What is most likely your problem is the crushed ice solenoid. This solenoid, which is located next to the auger motor behind the ice bucket, is failing to actuate when you request cubed ice. Its "home" setting is crushed, and actuates to allow cubes past the crushing mechanism in the bucket. To be certain its the problem, remove the ice bucket, and tape the door light switch in the closed position. actuate the ice dispenser lever, for both cubed and crushed ice. you will see a square hole next to the rotating fork, when you select cubes, it should open. If it does open, there is something wrong with your ice bucket, perhaps the arm is broken, or the door inside bucket is off its snap in type hinge or broken altogether. If it doesnt open, replace the solenoid
Expert Refrigerator Repair Service in Chicago and Suburbs
Mar 20, 2010 | Freezers
Ice maker chute becomes jammed with snow and cubes are being crushed even if the cube option is selected
You need to remove the ice bin , remove ( save ) the ice , and defrost the bin opening with hot water . It sounds like a piece of ice got caught behind the bin flap , keeping the flap from opening fully , so cubes will go thru . When cubes cannot go thru , the crusher will crush anything that tries . Now this is the ice container only .
Sep 09, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice instead of cube ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice maker is crushing ice when cube ice button is on
We've had a similar problem, possibly the same, with our LG in-door ice maker. Whether cubed ice or crushed ice is selected, it crushes the ice.
We found that there is a little lever on the inside of the door, on the lower right behind the ice bin, which freezes in the down position. This is a literal "freeze up", as a block of ice forms in the little well under this switch and eventually freezes the switch in place. Since the switch needs to go up to provide cubed,.. we only get crushed. On 3 separate occassions we've thawed and chipped out (carefully) this little ice dam and gotten cubed ice capability back for a few weeks. At which point it freezes again. I have no idea why water collects there in the first place.
Feb 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
GE Refrigerator Automatic Ice Maker IM6 Logo
74 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
