Question about Music
I have a Technics digital piano with 1 dead key. The piano is about 10 years old and in great shape. The key stopped working after my toddler started banging on the keyboard. Is this fixable?
  • 1 more comment
  • Gary Manis
    Gary Manis Jun 24, 2009
    Thanks for your response. My piano is a sx-px336 if that helps. It has the Dynamic Action Keyboard.
  • Anonymous Mar 24, 2014
    piano willis numero de serie 311418
  • Anonymous Mar 27, 2014
    How old is it & what's the value? It's in rough shape
    President:
  • 1,138 Answers
If your piano is the same as mine, there is a rubber membrane with contacts imbedded in it that sits on top of a circuit board. The key pushes the contact in the membrane onto the contact causing a note on. What happens is the cylindrical part of the membrane that holds the contact can get torn and the contact will no longer travel in a straight line to trigger the note. The entire membrane strip has to be replaced. The strip on my piano was discontinued and I had to manufacture one from an extra Roland membrane that had some bad contacts in it. You will have to contact Technicsat www2.panasonic.com/webapp/wcs/stores/servlet/PNAEndecaSearchCmd for support. If you don't feel comfortable tackling the repair yourself consult a good piano tuner/repair place in your area for advice.
Posted on Jun 23, 2009
I have a Technics PR-305 Digital Piano. I had a couple of guys come out to see if they could fix it. Only the LCD display and the front light worked. It must be the power supply.
Technics, digital piano, keyboard repairs, repair, service ...
www.mikebarden.com/technics-electronic-digital-kn-pr-px-piano-keybo...
technics, technic, tecnic, digital piano repair, service, servicing, digital, electronic, ... pr200, pr250, pr270, pr3, pr300, pr303, pr305, pr307, pr350, pr370, pr40, pr5, pr50, ... It needs extremely specialised repair work which must only be carried out by .... nodisplay, LEDS don't light up (except for the one on the front of the piano ...
Dec 18, 2015 | Music
I have a Technics PR-305 Digital Piano in which I play on. I took apart the Digital piano to get to the rubber contact to clean them. later on I went to turn on the piano and it didn`t work.
Attempted to clean? Not a good idea obviously...Take it apart like you did before and look at the wiring and imagine that you can divine the thing to reveal some logical explanation. If you used a contact cleaner or spray to clean, that could be death to that piano my friend.
Dec 12, 2015 | Music
I have I Technics PR-305 Digital Piano. I took it apart to try to clean the rubber contacts with rubbing alcohol. It improve some what, then later on I turned on my Technics R-305 Digital Piano.
I would suggest taking it into the nearest factory authorized repair center. Go to the Technics web site to find one in your area.
Dec 10, 2015 | Music
I Have a Technics PR-305 Digital piano that I have for a little over 12 years ago that I enjoy playing on very much, I have a distortion problem in my speakers it`s not very bad I was told in Fixya th
The Speakers can be replaced with any brand. The thing you need to know is the OHM rating for the speaker. OHM is also called impedance. Unless the sticker has fallen off the back of the speaker that information will be on that sticker. OHM rating MUST match the old speaker. For instance 4 OHM, 8 OHM, 16 OHM are common ratings. All different ratings but VERY important to get this correct otherwise you could damage the electronics of your instrument.
Aug 13, 2017 | Music
Korg C- 155 Digital Piano - Sound comes on after 15 minutes of being turned on.
All of the above answers are wrong.
First off, forget about 6ya! Sixya, fixya, scam artists all. See for example, https://tinyurl.com/ybpds4h5. Calling them for a digital piano repair would be like calling a plumber to do brain surgery.
She's asking about a KORG C-155. Not a Roland anything. Not a Technics anything. Not a Kurzweil anything. And the problem isn't about dead notes or intermittent loss of touch sensitivity, or volume issues. Her piano is dead until after a 15 minute warm-up and then plays NORMALLY! This issue just about screams, "POWER SUPPLY PROBLEM!" At least, this is the first place to begin.
For the average user, this is not a DIY project. Troubleshooting it will require an experienced technician with the proper instruments and tools at least an hour to open the unit (ker-ching!), take some measurements, identify the defective assembly or component. Then on a 25 year old unit, he would need to start hunting for replacement part(s), since KORG very likely no longer stocks parts on a unit that old.
That is probably why the typical answer from a professional would be, "save your money, and buy a new unit." Because of the parts issue, the cost of the repair will likely be in the hundreds of dollars (ker-ching!), and when it breaks down again with something else (ker-ching! ker-ching!).
I'm not saying the piano can't be fixed, but I am asserting that it can't be fixed economically by a professional who cannot afford to spend many hours on isolating a defect, hunting online for a USED replacement assembly, or a NEW component (assuming that the repair involves just one or two individual components), then actually doing the repair, and putting the unit back together, and only get paid for a fraction of the actual time involved.
Feb 10, 2012 | Korg Music
The graded action has stopped working, any help greatly appreciated!
The graded action is only that there are different counterweights on the various keys. They are a sort of "J" shaped pieces of steel that vary in length. I don''t know how the graded part could stop working, as they just vary the key "feel" across the keyboard. Are you saying this key "feel" has been lost?
Mar 20, 2011 | Yamaha P85 88Key Portable Digital Piano
Kurzweil digital piano unpredictable voices and volume
The contacts of various switches and keys are likely dirty. They are often conductive rubber and need cleaning with 99% isoprophly alcohol and q-tip. Clean both the conductive rubber pill and th circuit board traces they contact.
Sep 17, 2009 | Yamaha NP 30 76 Key Lightweight Digital...
Loose keys on my wonderful Technics digital piano
You would be very surprised of how few moving parts are in side one of these keyboards. There is no fix to the action,trust me. play the day lights out of it until it stops then get a new one. Have some fun and explore, if you find an old one that is shot, take it a part and you will see what I mean. These units are really a disposable instrument.
I hope this doesn't disappoint you . I hope it helped. Keep on rockin in the free world. DFD
Apr 13, 2009 | Music
Music Logo
1,269 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
