Question about Boating
How to clear evinrude water jacket/ zebra mussels
3 Suggested Answers
oaktree123
  • 17 Answers
SOURCE: what is the problem with zebra mussels
They attack the resources that the native fish and flora use and take over the water as an invader.
Posted on Sep 17, 2009
Gort007
  • 1187 Answers
SOURCE: We need to get rid of zebra mussels.
Probably impossible; we don't know yet.
best solution? Preditory birds/ducks and fish.
But then you may have unbalanced the bird/fish population. Better than the mussels.
Sorry, no non-invasive solution, in my opinion.
Posted on Sep 21, 2009
Whats place of water jacket
The water jacket is just a name for the coolant inside the engine. It is the metal of the block surrounding the coolant.
26063781-v2hn1he4tapx4zekfu2mgcdc-4-0.jpeg The photo shows an engine block. The 4 bigger holes are - obviously- where the pistons fit. The smaller holes lead into the water jacket'. The coolant is held between the outer wall of the engine block and the inner wall. This area between them is known as the 'water jacket'.
The coolant circulates through the water jacket and into the radiator via the top radiator hose. As it cools it goes downwards in the radiator and then back into the engine block via the bottom radiator hose
Jan 22, 2016 | Cars & Trucks
Why do I not have compression in one cylinder?
cylinder head gasket failure ?
if it was a piston failure the noise it would make would put a rock concert to shame
gasket failures are common on aluminum block engines due to hot spots developing from not flushing out dirty cooling water (river?) often and dirt builds up inside cooling jacket of block making for hot spots next time you run it , I now use a flir (heat) camera to see it happen live on older engines , I used to use a old thermometer that I touched in key spots when running , the camera works way better !!!! diagnosis in seconds not minutes with this tool
Oct 20, 2015 | Johnson Evinrude OMC New Lower 75/115HP...
What would cause water to leak into the upper partof a 1992 evinrude 48spl outboard boat motor
I Presume You Are Talking About Water In The Combustion Chamber.
If So The Head Gaskets Or Water Jacket Gaskets Are Corroded By The Salt Water.
Replace Gaskets.
Aug 18, 2013 | Light Outboard Motor Boat Bass Fishing...
Hi , i have an evinrude lightwin 3hp 1969, water does not circulate and the outbord is overheating !
2 CRITICAL THINGS:
1. Replace Thermostat
2. Replace Water Pump:IMPELLER, CUP, PLATE(IF APPLICABLE) SEALS & GASKETS
***ALSO: MAKE SURE DISCHARGE AND INTAKE PASSAGES ARE CLEAR
Jul 25, 2013 | Boating
What are the signs for a blown head gasket
if water in rad has oil in it or smells , building up pressure in rad , water in oil !
Feb 23, 2013 | Sierra International 18-2959 Marine Head...
Do life jackets keep my head above water?
Yes, Life jackets are designed to keep your head above water and keep you in this position until rescue arrive.
Jan 14, 2013 | Boating
Sep 21, 2009 | Uniden Cordless Phone
What is the problem with zebra mussels
Sep 16, 2009 | Computers & Internet
Outboard motor overheating
Mate.The powerhead(engine block) is clogged.Don,t run it anymore untill its cleaned out or the motor will cook.Take the heads off 1st and see whats in the water jackets.It will probably be blocked.A build up of white 'gunk' is the main indicator.If thats the case,a complete cleanout is needed.Hope this helps
Jul 27, 2009 | Boating
Boating Logo
324 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
