Question about Kenmore 5.7 cu. ft. Electric Range w/ True Convection - Black
How to change the fuses
Plug ins at the top don't work anymore. suspect blown on board fuse?
  • 641 Answers
Hi Steve,
I have 2 videos for you and hope it helps you on how to resolve it.
Posted on May 08, 2014
Testimonial: "These appliances have little or no bearing on the Kitchen stove fuses or how to replace or repair them. thank you anyways"
Plug fuse blew.
Something is blowing the fuse if its out again, check for rails that are lower then they should be, chances are you will need a new power board.
Feb 08, 2018 | Televison & Video
I have a Carrier Heat Pump model FK4CNF003. I noted that the thermostat wasn't working (no power) so I checked the usual suspects...in bound power etc. before I pulled the top housing off the interior...
The source may be the circuit board itself,since the fuse is only 5 amps I would strongly suspect this part, look for any heat damaged area, this is the usual suspect.
Sep 19, 2008 | Heating & Cooling
Not working anymore after I plugged in I have heard some electric noise.
Wild guess but if not powering up, possible that fuse blew (if no external, then there's often one on the power board), or something blew in power supply...check for blown filter capacitors (the larger ones, for leaking, or blown/bulging tops), burnt resistor, or bad diodes.
Aug 28, 2014 | Yamaha HS50M Active Studio Monitor (Pair)
Fuse box diagram
If something quits in your car and you suspect a blown fuse, you can find it by pulling out each fuse one by one. Don't mix them up, replace each one as you go, across the top or down the sides, make sure to look at each one. You may even find you have more than one blown fuse! Don't worry about your intended location, checking them all this way will take less than a minute of time. If you have some needle-nose plyers, they work very well, most times you can use your fingers. Here are a few pictures if your unfamiliar with what your looking for:
Dec 12, 2013 | 2002 Chevrolet Silverado 2500HD
1983 Chevy Silverado, Glow plug light will not come on, Truck will turn over but not start, fuse panel has no blown fuses, I suspect the Glow Plug Relat but I don't know how to verify it is bad.
With most relays, you have 4 wires. One is power to the component the relay controls, one is a ground to the relay magnet, one is power to the magnet, and the fourth goes to the component, in this case the glow plugs. The ground usually comes from the computer.
With the key on you should have power to two terminals and you would jumper the hot terminal to the glow plug terminal. Or use a test light or meter to check for power on the glow plug circuit.
Sep 19, 2012 | 1983 Chevrolet Silverado
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
How to fix my plasma after a suspected power surge.
Power supply board would be first suspect to look at.
some general info:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
May 18, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
LG 42PQ30 plasma tv wont turn on anymore, when you plug the tv in it makes a click noise and when you hit the power button the blue light comes on then changes to red after couple seconds. Note the...
I see so many here with no sound/nopicture issues:
ISSUES:
Answers to issues:
4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.5_15_2012_1_19_09_pm.jpg
May 15, 2012 | LG 42PQ30 42 in. Plasma TV
I need a 120v power supply circuit board
purchase a AC to DC adaptor and use the 12volt power cord plugged into it.. these are commercially available, just make sure you purchase an adaptor that can handle the power used by the fridge which is on the back of the unit.
May 30, 2009 | Sharper Image (SI714SL2) Compact...
HITACHI 37PD5200 E Plasma dead.
The fuse is either open or it will have continuity do you have any standby voltages
May 14, 2008 | Televison & Video
Kenmore 5.7 cu. ft. Electric Range w/ True Convection - Black Logo
52 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
