Question about Robot Coupe "R2 DICE - Combination Food Processor, 3 qt.gray ABS plastic bowl with hand"
Why doesn't drive shaft spin?
Robot Coupe R2 Dice powers on, but shaft won't spin until you give it a little twist or push. Then, it spins just fine. Why won't it spin on it's own?
  • 1,339 Answers
Might be the start switch in the motor and or a capacitor. it should turn fairly freely by hand, if not it could be a bad bearing/bushing.
Posted on May 08, 2014
Robot coupe jucier machine need price quote
we do not quote any prices here . this is a repair help site
Dec 19, 2015 | Robot Coupe Blenders
Disassembling a robot coupe mp450
First you drill out the plastic plugs to acess the torx screws holding the housing together. Remove 4 motor mounting screws to separate from shaft.
May 28, 2013 | Robot Coupe MP450 Handheld Blender
Blades on ninja blender won't spin, but motor seems to be working.
I don't have one, but inspect the shaft, it looks like there is a key on the shaft, then inspect the inside of the blade where it goes on top of the shaft, see if it looks like the shaft has spun out the blade and this is why it's not spinning.
Remove the blade and the container, then turn on and see if the shaft is spinning, it should be most are a direct drive.
So now if the shaft is spinning, that most likely means that the blade hole is broke where it sets on top of the shaft.
Look closely at the inside of the blade, you should see some type of damage like the groves are worn, I hate to see you buy one and it was the shaft that wore, but usually the blade will go first.
Mar 31, 2013 | Blenders
ELECTRIC DIAGRAM ROBOT COUPE MP450
I need a wiring diagram too don' Robot Coupe have service info. on their products as expensive as they are it's a problem. Robot Coupe MP450 Turbo can't seem to find anywhere. Thanks
Jun 02, 2012 | Robot Coupe MP450 Handheld Blender
Disassemble
we found the solution to the problem on your website.
Thank's for the tip.
Feb 15, 2010 | Robot Coupe MP450 Handheld Blender
Braun 4169 disassembly procedure
4169 blender dismantling. this device is not suitable to be dismantled but this is how I did it. 1 disconnect from the mains. 2 lever off operating lever button at opposite end to hinge 3 insert sharp screwdriver into gap by top lid at same side as cable entry and prise off 4 heat up the casing with an electric paint stripper, wear gardening gloves. 5 when the casing starts to get pliable, insert a driver into the gap above the operating button locating lip and prise away as far as you can 6 do this with the locating peg on the other side 7 work between the two until the whole thing comes apart 8 lever out the motor, it will slide out once loosened 9 wash out the blender drive shaft with boiling water and detergent 10 dry out the body and soak the inside with silicone oil 11 work the blender blade until it spins freely 12 clean everything up and push it all back together 13 if any parts are deformed with the heat gun reheat them to a pliable state and reform them as best you can 14 if it is all loose when its back together, glue the joints with superglue and spray with glue accelerator 15 test it and if it's no good chuck it in the bin and buy a new one 16 but mine works fine.
Oct 09, 2009 | Robot Coupe MP450 Handheld Blender
Does any one know how to dismantle a blender mp 450 robot coupe?
4 screws are covered by caps in the handle area, everyone finds these but there are a further 4 screws found by removing the air vent grilles. The grilles are held in place along their shorter sides midway. Pop a fine screwdriver in at this point and the grille comes off.
Jun 03, 2009 | Robot Coupe MP450 Handheld Blender
Robot coupe mp 450
http://www.retrevo.com/support/Robot-Coupe-MP450Turbo-Food-Processors-manual/id/23109bh930/t/2/
Hope this helps you can download it by PDF
May 22, 2009 | Robot Coupe MP450 Handheld Blender
MP 450 TURBO
If you type in your model number on the internet information will come up on it for parts & other things. Hope this helps
May 04, 2009 | Robot Coupe MP450 Handheld Blender
Robot Coupe "R2 DICE - Combination Food Processor, 3 qt.gray ABS plastic bowl with hand" Logo
268 people viewed this question
Top Robot Coupe Blenders Experts
Ruth summersides
ray gallant
Are you a Robot Coupe Blender Expert? Answer questions, earn points and help others
