Question about ViewSonic Televison & Video
Problem : input control mod.# vs11771-1M tv shuts down by itself within seconds of being turned on!
Tv was functioning properly, suddenly screen only showwed no signal, tried input button, when it appeared on screen, it scolled itself to a position that indicated tv did not recognize and it would shut itself down, which it did within a couple of seconds,tried repeatedly .no success!
SOURCE: 42" Plasma TV Problem
same frustrating symptoms on brand new 42inch here! tv just turns itself off sometimes without warning or if changing to certain channels. leaves red light flashing for a while then red light goes away. any attempts with remote gives flashing green liht on tv. manual power off and on restarts tv but auto off again. found while manual power on keep changing channel on remote till stable picture appears. then use remote to shut down tv - solid red light indicates standby mode. then use remote to turn on again... till next time it happens. but what is technical fault??
Posted on Oct 07, 2007
osborne382
  • 306 Answers
SOURCE: TV keeps shutting off
Its the power pack located inside the TV, it needs replaced. contact manufacturer for parts or service.
http://www.support.philips.com/support/html/index_global.html
Posted on Nov 14, 2007
SOURCE: Deep Sleep
use the TV VIZEO remote to get out of RGB mode and go to hdmi2 and for me that ALWAYS works.  or whatever mode your cable is set to.  good luck
Posted on Jun 19, 2009
  • 36 Answers
SOURCE: TV powers up initially, but shuts down within seconds.
These TV's are somewhat sensitive to internal heat. It appears your sensor has triggered an overheat. This doesnt mean you still have the heat issue, it just saying it needs to be replaced or reset, either way it is not something you can do in your home. Taking it to your local authorized shop will ensure proper repairs, about $90 worth.
Posted on Jul 24, 2009
  • 46 Answers
SOURCE: After punching some of the
you'll need to do a master reset of the device
check link -->
www.retrevo.com/support/Vizio-L32-TVs-manual/id/512dj084/t/2
Posted on May 03, 2011
For HL-T5087SA DLP I have lost all inputs to tv. Can't turn off or on with main control in center. All remote functions do not function.
is there a reset button on the tv? on some electronice devices, if you hold down the power button for about 15 seconds, the unit will reset.
May 17, 2015 | Samsung Televison & Video
LG 42CS560-UE LCD TV turns off by itself Power Supply is New
You must accidentally setup the auto sleep function within 3 seconds interval. Go to the setup page to re-configure no auto sleep interval.
Jul 22, 2014 | LG Televison & Video
Why does my MAG Innovision MA-32EF1ASP Flat Screen TV not function properly?
Have your hand ready when you turn the set on and instantly change the input to get back to the tuner in the set--some sets will shut down if hooked to a input with nothing connected.
Also if using a box connected to that input unplug box and set--wait and plug both back up to allow them to reboot.
Let me know what you find--not likely a reset will cure this but possible.
Apr 03, 2012 | Televison & Video
My television suddenly turned itself off while switching from video to hdmi. Now it will only turn on for a few seconds and shows a "no signal" message, then shuts itself off.
We have a 42" Model XV42L HDTV10A 100-240V,2.5A,50/60HZ....when we turn the TV on the screen is flickering and then shuts itself off....sometimes it will come on for a few seconds and then shuts off
Dec 16, 2010 | Vizio 42 in. LCD TV
I have an Mitsubishi HD 1080 big screen tv. When
Ur power ic inverter board is dead.
U need a new one.
Aug 26, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Tv shuts off immediately
check first for the contact point of your control panel button maybe the tact switch is shoted specially when your always using remote control for function operation.second check power supply for leak capacitor or change in value,check also the photo coupler for leak test or change in actual.
Aug 01, 2009 | Mitsubishi VS-5043 50" Rear Projection...
Shuts self off
Press input and menu on the tv panel and hold both buttons in together for 8 seconds and let me know if the led blinks a two digit code
May 04, 2008 | Mitsubishi WS-65315 65" Rear Projection...
Tv won't stay on
it is a brandnew tv, so expected that it is under warranty,, it best for you to return where you bought so the warraty will not void. Big possible of factory deffect.
Dec 26, 2007 | RCA 20F420T 20" TV
T.v. will not stay on
Power on your TV and press the INPUT button on the side of the TV repeatedly and rapidly until you can change it to a different input, such as AV.
If this does not work. Try this: With the TV off, press and hold the input button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. Let me know if either of these work.
Nov 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Samsung PC J5225 shuts down after 3 - 5 seconds
It sounds like the tv power supply has problems. you probably should call a service center about a repair.
there are "safety" features built in to any tv with a "crt" type of screen that will not allow the tv to run when there is a problem.
Oct 20, 2007 | Samsung PCJ522R 52" Rear Projection...
Televison & Video Logo
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
