Question about Garden
Sears Series 700 22" Lawn Mower electric starter spins but won't engage with engine
The battery is good and the starter spins when the key is turned but does not engage with the engine to start it. I am assuming it is the solenoid but not sure. How do I access the solenoid and starter on this lawnmower and how do I test them to trouble shoot what is wrong and fix it?
  • 89 Answers
Its not the solenoid if you turn the key and it spins that's the job of the solenoid .Try some wd forty on the shaft ,it probably gots some dirt on it they like to hang .I think that will take care of your problem
Posted on May 08, 2014
Testimonial: "I lubricated the shaft with WD40 and the starter gear seems to slide on the shaft. I figured that the battery was not strong enough to engage the starting gear so purchased a new battery but the starter shaft still spins but the gear does not engage with the engine. What could be wrong?"
When I try to start my 60" Ariens rider all I get is a loud clattering sound. I just replaced the battery 2 months ago. What's wrong with my mower?
Joel, Recheck battery to make sure it has good charge >12 v and all battery and starter wiring,plugs,connections are clean,tight and undamaged. If you remove spark plug and engine spins freely from the key, the engine compression release or valve clearance needs adjusted. It is probable the solenoid or starter is faulty, the starter Bendix/drive may be sticking. If you can, give the starter a couple sharp raps with a hammer or bar and then try to start.
Check the attached links,instruction and guides to help diagnose starting issue. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://troybilt.custhelp.com/app/answers/detail/a_id/86/~/clicking-sound-while-attempting-to-key-start---riding-mower
What Are the Symptoms of Bad Starter Motor on Riding Mower Engine
My Bolens lawn tractor won start It just clicks when turn the key even...
Craftsman riding mower won start Just clicks the starter motor
Aug 27, 2016 | Ariens MaxZoom60 60" 25HP Kohler Zero Turn...
Why will Ariens lawn mower starter engine not turn over?
These machines have carb and coil issues. Check for fire. Nice when new, but once a little age creeps in, the engines just aren't that sturdy. Sorry, but as a small equipment mechanic, I don't recommend Lawn Boy. Next time, buy another brand.
May 30, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
The electric starter spinns but wont engage to turn 6-5 hp briggs and strattanengine on my huskvarna lawn mower
hi there
svseanachai
have you had the battery out ? if so did you refit the battery back in , with the proper connections to battery - reversed connections at battery makes starter spin but starter clutch wont engage - have seen this on b/s 16 hp vee twin
if this is ok check the starter clutch / helix and gear they may be faulty or stuck
have a look let me know
cheers hope it helps
pauly46
dont fprget the thumbs rating
Jun 02, 2011 | Husqvarna 675 hp 21" Honda Rear Bag Push...
My mower wont start...i replaced the battery and it just clicks
Have a friend jump start the mower while you a seated on it. Turn the key to the "on" position. Connect the black jumper cable from a known good battery to a good ground on the mower and the red cable directly to the electrical connection of the starter. If the starter does not engage, it is faulty.
Apr 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Electric start doesn't turn over the engine the first time
Have you checked the battery voltage with a multimeter? It should read 12.2 volts or higher. It sounds like the battery is dead, or the charger is not charging.
It starts after it's run because the magneto is slightly charging the battery, plus a cold engine is more difficult to start -- more friciton when cold.
Charlie
Aug 23, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
Jun 14, 2009 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
