Question about Miscellaneous
What is the gap specification between intake manifold and the mount for a 1996 Mercury Sable 3.0L DOHC engine? (It looks like it might not be compressing enough)
Not sure I understand your question. The intake manifold bolts directly to the head, so there should be zero clearance when its bolted down. Any gap will cause a vacuum leak.
May 08, 2014 | 1996 Mercury Sable
Were is the thermosat located
For the 3.0 ohv engine follow the upper hose the the housing on the intake manifold. It will be behind that housing. On the 3.0 DOHC engine. Follow the lower hose to the water outlet housing. The thermostat will be behind that housing.
Apr 06, 2013 | 1999 Mercury Sable
Where is the pcv on '00 dohc engine?
Look on the intake manifold there will be a 3/8 hose attached to it going to the throttle body or the air intake tube that attaches to the throttle body.
Jan 26, 2012 | 2000 Mercury Sable
Change spark plugs on a 96 sable v6 dohc, how much do I need to take apart to change them and should I just take it in?
actually if i was u i would take it in cus to get to the back 3 spark plugs u have to drop the back of the motor down about a foot or so until u can reach the plugs, or take the intake manifold off. either way its a pain in the ****. but its up to u. good luck to u and i hope this helps u
Jul 05, 2010 | 1996 Mercury Sable
Just wanting to know what gage spec to set gap the plugs on a 1996 mercury sable
3.0 EFI 6 cylinder: .044 (In thousandths of an inch)
3.0 EFI DOHC 6 cylinder: .054 (In thousandths of an inch)
Nov 22, 2009 | 1996 Mercury Sable
1996 mercury sable computer
If you are looking for the powertrain control module (PCM) it is located in the right rear corner of engine compartment ( Passenger side), mounted in Firewall
Sep 10, 2009 | 1996 Mercury Sable
2000 Mercury Sable 24V 3.o engine. Need to know
yes about the upper intake and the only way i know how to check the coils is with a engine anilyser or if the check engine light comes on then you can have the codes pulled and that will tell you which cylender is missfiring this engine has a indevidual coil for each spark plug so thares 6 of them and thay slide right down over the sparkplugs
May 05, 2009 | 2000 Mercury Sable
Changing rear spark plugs
yes you have to take your front motor mount out and come along the motor forward you do not need to take the intake off
Apr 21, 2009 | 2005 Mercury Sable
Miscellaneous Logo
15 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
