Question about Juki DNU-1541 Mechanical Sewing Machine
How do I loosen the stitch length knob ?
It's too tight to move lower than 5. There is a screw in the middle of the knob but I'm hesitant to loosen it.
  • Juki Master
  • 7,365 Answers
Try to loosen the screw just a little at a time and see what happens
Posted on May 08, 2014
Juki 8700- stitch length won't go below 2.5. Knob gets stuck. How to make stitch length lower?
SLIGHTLY unscrew the large screw in the center of the stitch length knob, turn the knob to the right several clicks and retighten the screw. DON'T take it completely out, or you will make more work for your self.
Jul 07, 2016 | Juki Sewing Machines
Singer 4530- stitch length adjustment not working. How do I fix?
Since you indicated the machine has been cleaned and lubed, that is probably not the problem unless the stitch length lever is sticky or the feed dogs are hanging up somewhere. Suggest perhaps directing heated air from a handheld hair dryer into the internal mechanics (focus on the stitch selector lever and the feed dog mechanics) and see if that loosens anything.
Apr 04, 2016 | Singer Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
I cant get the tention right what numbers should the 3 knobs be ever three or 4 stitchs are slack or all of them i dont no what knob is for the top stitchs and which is the under neath
Forget the three knobs for tension adjustment, only the top tension knob should be about 4 or 5, you should be able to pull the bottom thread through on the bobbin with slight resistence, if it is too tight slacken the screw on the bobbin case anti clockwise about a quarter of a turn, pattern selectors stitch length and width work independently of the tensions.
Aug 10, 2011 | Necchi 6022 Sewing Machine
The 6 built-in stitches (such as blind stitch, darning stitch, etc.) are not working, they only just do the basic zig zag stitch. Also the cams for decorative stitching do not work either. These are all...
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Feb 15, 2011 | Elna Sewing Machines
My Elna SU will only do straight stitching it will not zig zag
Feb 02, 2011 | Elna Quilter's Dream 6003Q
Looking for the reverse button on a necchi bu nova
There is no reverse button, it is a lever.The stitch length lever also reverses the feed dogs - when down, it runs forward - at zero, it does not feed at all and when moved up, it reverses the machine. Set your stitch length by loosening the thumbscrew on the vertically moving lever and sliding the plate into position while moving the lever up to the desired mark. Tighten the screw and move the lever down to sew - to reverse just move the lever up until it hits the stop to sew the same stitch length in reverse.
Jan 12, 2011 | Necchi 4575 Mechanical Sewing Machine
I want to know which knob I use to make the stitching narrower
there are generally two variable controls .. one adjusts the stitch length (distance between stitches measured in stitches per inch) ... the second is stitch width .. that adjusts how far the zigzag moves left and right .. thats usually just a number from 0 to 10 or so .. 10 would be maximum width .. 0 would be used for straight stitch ..
so you need to adjust the stitch width control to make the stitching narrower .. the controls are called different things on different brand sewing machines .. if you have the brand and model number then there may be instruction booklets available ...
Jan 04, 2010 | Sewing Machines
Sewing Machines Logo
53 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
SewTechWayne
SewTechWayne
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
