Question about Cycling
How to wire my ignition switch to my scooter
Al my harnesses are destroyed need to rewire
Mobility Scooter 8MPH ROAD OFF ROAD COUNTRYMAN BATRICAR
Hi, before i advise you is it possible to see a picture of the scooter in question ?
Regards
Rob
www.gewizrepairs.co.uk
Feb 12, 2014 | Pride Go-Go Elite Traveller Plus HD...
Diamo scooter kick starts electric starter not wiring
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have nice a day.
Scooter Troubleshooting Scooter won start All about Scooters
http://www.linnbenton.edu/auto/perform/no_start.html
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial http://scmotorized.com/image/data/pdf/scooter-repair-manuals/Retro-150--Parts-Catalog-V.12.07.pdf
Diamo Retro 150 2007
Sep 24, 2013 | 2007 Diamo Retro 150
Ignition switch
Why not look for a used column with all the wiring harnesses and switches?
Jul 22, 2013 | 2003 Hummer H2
Auto electricl wiring size and color
I have been restoring cars for years and in my opinion the absolute best/easiest way is to buy a new harness kit from "Painless Wiring" it will include a complete harness and fuseblock, the wires are all labeled so there really isn't any guesswork.
Feb 25, 2010 | 1995-1997 Chevy 1500 Truck Ignition...
Cycling Logo
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
