Question about Rangemaster Kitchen Ranges
Stop oven igniter clicking
Oven lights but igniter will not stopp clicking
    New Friend:
    Problem Solver:
  • 17 Answers
The igniter button is stuck...should be linked with your pilot light switch...try loosening by hand (just pull up on it gently, attempting to release contacts...if not lubricate it.*(ONLY WITH GAD AND PIOLIT OFF! your contact cleaner, degreaser...or WD40 could be flammable?!) caut
Posted on May 08, 2014
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
It buckle and sputters when in iddle or at stop light
HAVE THE IGNITION SYSTEM CHECK,ALSO THE IACV(IDLE AIR CONTROL VALVE)IF THERE IS ONE.
Mar 18, 2014 | Hyundai Motor 1995 Accent
Main burner ignites, but cut-off soon after.
Having never seen one or heard of one , I would try the manufacturer's website for tech support . or contact a LOCAL gas service
Sep 11, 2017 | Vulcan GCO2D Gas Single Oven
How do you light the oven? We turn the dial and
I take it the range is electric ignition because you say the top burners have a clicking(igniter) noise. If the top burners are electric ignition then the oven is also. The oven probably uses a hot surface igniter and that is why you do not hear any clicking. Turn the oven on and open the broiler compartment. You should see a bright glow from the hot surface igniter. If you do not see any glow there may be a grounding issue or the igniter could be bad. If you do see a glow but the burner does not come on in a few minutes then give the gas valve a tap with a wrench and see if the burner comes on. Shut it off and then back on several times. If the burner continues to light after this you may have fixed the problem. If it does not come on gas valve could be sticking or igniter is weak.
Sep 10, 2009 | Magic Chef 31000 Gas Kitchen Range
Range Oven Will not light
Check your igniter for the bake manifold. Open the oven door and look down at the bottom oven pan. Set the oven to bake and see if you can notice a glowing or clicking noise coming from under the oven pan. This will tell you if your igniter is attempting to work or not.
Now...just because an igniter glows or clicks does not necessarily mean it is good. They can become weak with age and fail to draw the required current to open the gas safety valve. The bake igniter commonly goes bad first, because of the frequency it gets used. The following link will explain:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
If you have questions, or require addtional assistance, please let me know. I hope you find this information helpful.
Feb 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas oven will not ignite
It sounds like somebody bypassed the flame sensor on the oven, no oven should ever release gas for more than a couple seconds if there is no ignition. This oven is very dangerous and should not be used until it is looked at by a professional.
Dec 19, 2008 | Ovens
Top burners often wont light if oven is already lit
Hello and welcome,
If your range has electronic igniters, then you seem to have one or more bad igniters on top of the range if you have a pilot range then you have a gas restriction or clogged orifice tube.
Even if they make the click noise while trying to light they may not get hot enough to draw the gas on a constant speed!
This will need to be diagnosed hands on at your location.
But this is the fault!
Thank you for using fixya.
Huum
Please remember to leave a solved rating before you leave!
Dec 07, 2008 | GE Kitchen Ranges
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
HELLO MR BEAN
These problems are difficult to diagnose sometimes without being there to actually see what is going on. Now...let me see if I can remember all of this. You replaced the spark module and have a spark at each burner now. You also checked for gas leaks and didn't find any. Now, you're telling me that the oven isn't working? Most oven igniters I'm familiar with are the glow bar type. Which means they don't spark at all. They glow to a certain current potential (roughly 2.7 to 3.3 amps) before the gas valve is opened and begins to flow. Once gas flow is achieved, the igniter ignites the gas. Now, when these igniters get old, they become weak and will not provide enough current to open the gas valve, or, they take a long time to ignite. If this is your case, then you need to replace the oven igniter. Does this help you? PS Keep in mind, some ovens have two separate igniters. One for the broiler and one for bake. Does the broil function work? If so, the oven switch is good.
Aug 07, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
121 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
