Question about Dell 3130cn Color Laser Printer
Dell 3130cn reset replace belt - Dell 3130cn Color Laser Printer
2 Suggested Answers
SOURCE: Where can I get a dell 3130cn service manual to
3130cn users guide is available at:
http://support.dell.com/support/edocs/systems/3130cn/en/ug_en/index.htm
and has instructions for replacing normal components.
Posted on Jan 26, 2011
Tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
on Mar 29, 2016 | Dell 3130cn Color Laser Printer
Error code 093-921
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Mar 02, 2016 | Dell 3130cn Color Laser Printer
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
What does it mean Dell 3010cn error code 091-422
I can only assume you mean 094-422 error. I do not think there is an error code 091-422. Anyway here is what error code 094-422 means:
The transfer belt unit must be replaced every 100,000 pages, usually along with the fuser and feed rollers as part of a maintenance kit.
The error code 094-422 indicates the belt has reached 75,000 page and as a result has 25% life or less remaining.
The belt does not need to be replaced immediately and can continue to be used until end of life is reached.
Aug 20, 2014 | Dell 3130cn Color Laser Printer
How to reset dell 3130cn to factory defaults
Go here: http://en.community.dell.com/support-forums/peripherals/f/3528/t/19494398.aspx
Jul 09, 2014 | Dell 3130cn Color Laser Printer
3130cn not a clean print
This is a bit vague for a description of a problem.
Details.
How is it not clean?
Is it an overall colour background?
Is it producing 'smudgy' prints (that rub off the page)?
The pagecount of the printer could be useful - indicates how much use the printer has had 0 could point to wear somewhere.
Have you replaced any of the toner cartridges, fuser, of transfer belt recently.
Are you using different paper (than when you were getting good print)?
Oct 02, 2013 | Dell 3130cn Color Laser Printer
Dell 3130cn Color Laser Printer Logo
200 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
