Question about Aqua Vac Tiger Shark
Our Tiger shark has to be hauled out of pool by power cord. The cord has frayed and the shark won't run. Where can I have it repaired? I live in Gainesville Fl.
The frayed part is approx. 6" from robot, at the section with additional insulation.
    Champion:
    Scholar:
  • Aqua Expert
  • 239 Answers
The power cord can be changed by a service pro. there are special tools required to perform this task. not to judge, but exercise more care when removing the unit. According to the hayward website, there are two dealers in gainsville at your disposal. they are both 'pinch a penny' stores. this link should take you to the address
Encuentra un profesional de piscinas
Posted on Oct 05, 2014
5 Suggested Answers
  • 106 Answers
SOURCE: How can I keep my Tiger Shark from sticking to the main drains.
Decrease suction on main drain and increase suction to cleaner.
Posted on Jan 15, 2010
jharwell668
  • 640 Answers
SOURCE: my tiger shark pool cleaner
The pool cleaners impeller may be clogged or jammed with debris. Check and clean if necessary. The brush rollers or drive tracks could also be stuck. Check for debris and remove. It is most likely one of these problems if it is shutting off after only seconds of running. If these don't seem to be the problem, I would check your power source.
Posted on May 11, 2011
john224
  • 1378 Answers
SOURCE: My tiger shark does not
The motor pack...
Was the store able to scan the motor to pull out operational info? Was it water tested prior to being returned to you? Perhaps the store will make accomodations to get it returned and repaired correctly?
John
Posted on Jul 25, 2011
john224
  • 1378 Answers
SOURCE: I lent my tiger shark
No. The unit 'learns' the pool based upon time recorded in the horizontal and vertical positions while cleaning. It will work, although perhaps not as well as in a rectangle-shaped pool, without any further action than dropping it in and powering it up.
John
Posted on Sep 06, 2011
Testimonial: "Thanks"
Tiger shark won’t seat properly on tiled floor
there should be a round weight the is around the end of the suction hose. this weight should be free moving. the weight helps keep the tiger shark to the floor. good luck.
Dec 23, 2017 | Pool & Spa
How can i replace the power cord on my tiger shark
there are special tools required to remove the power cord. i would send you a link to the manual but they are no longer active. the process itself is very simple but removal of the cord from the motor is tricky without those tools.
Jul 06, 2014 | Aqua Vac Tiger Shark
Why does my tiger shark motor run and peller spins but wheels do not turn
if the wheels are not turning, there is a good chance the drive belt is damaged. this can be repaired
Jun 14, 2014 | Aqua Vac Tiger Shark
Power supply
power cord for sure
Jul 30, 2013 | Aqua Vac Tiger Shark
My tiger shark does not work!! I have power to the transformer and shark, but it won't move. I just spent $400.00 at my pool store to get it fixed, they put new wheels, filters, and a new cord and...
The motor pack...
John
Jul 23, 2011 | Aqua Vac Tiger Shark
My tiger shark pool cleaner will run for about 30 sec. then shut off. how can i fix this problem?
Aug 18, 2010 | Aqua Vac Tiger Shark
Have power to the floating cord but tigershark will not run.
My tigershark would start working then stop 20 seconds to 20 minutes later. I found that the power switch was loosing good connection after self check cycle, I turned it on and off rapidly to hopefully clean the contact! I now disconnect and restart by pulling the power cord. I have run two cycles with no problem> I will replace the switch when I get a chance.
Good Luck
Apr 25, 2009 | Aqua Vac Tiger Shark
Aqua Vac Tiger Shark Logo
126 people viewed this question
Top Aqua Pool & Spa Experts
Ben Clacy
Ben Clacy
Level 1 Expert
ray gallant
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
