Question about Xerox WorkCentre 220 All-In-One Laser Printer
The machine will not get out of its start-up mode. Keep's saying "Please Wait." Cycles on and off. Clicking sounds
    Scholar:
  • 141 Answers
Fuser is probably out of order. Occasionally, I'll find a fuser bulb that has just come unclipped and is rolling around in there. Either way, you're looking at removing the fuser to find out.
Posted on Aug 04, 2009
My samsung washing machine Model # WA5471AB is not spin drying...when it reaches the spin cycle the wash starts all over again and the minutes are reading inaccurate...PLEASE HELP!!!
Sounds like a mother board problem. If you're handy, take the panel off and reseat all connectors. Don't forget to unplug the machine first.
Feb 04, 2017 | Samsung Washing Machines
Turn on my jet system 1200 fj 1254w xc just makes clicking sound
Obviously appeared family error code E40 (visible to the customer) what means a problem with door interlock. Could be: door open (mechanical failure), door interlock malfunction, the problem with main PCB (triac) or wiring. In service mode you can see exactly error code: E41,E42,E43,E44 or E45.
Dado
Jun 07, 2015 | Zanussi Washing Machines
Washing machine knocks and dims lights only during rinse cycle
Possible that the bearings are a suspect, if the machine seems to wobble around. Also if the load is high, does the noise go higher, if so check the suspension, check the mounting and the counter weights.
Please check this link: Wobbling machine
Jan 24, 2013 | Washing Machines
Clicking noise from dash near a/c controls and radio area. possibly fan assembly fault
I doubt if you have a fan problem. More than likely you have a bad actutor motor. There are 2 small electric actuator motors under the dash. The temperture door actuator moves the air temperature door, which controls the temperature of the air coming from either the a/c or heater vents. The mode actuator (which is probably the one you hear clicking) controls the mode of operation, or more simply, which vents the air will be coming out of. When the internal gears of the mode actuator fail and start slipping, they make a loud repetative "clicking" sound, which is what you are hearing. Another symptom that may or may not accompany this situation is a longer than usual wait time for your mode selection to occur. So to sum up, a loud repetative clicking sound from the center of the dashboard possibly accompanied by a longer than usual wait time for your ac,heat or defrost mode to occur, usually indicates a failing mode door actuator.
Sep 20, 2011 | Mercury Grand Marquis Cars & Trucks
Received a Blue Screen with Fatal Error
Please turn on the machine and keep hitting softly the F8 button on the keyboard.
When the list of options show up, select SAFE MODE and wait for the PC to load default drivers. Once asked to log in, please select "ADMIN". If none exists then select your user account.
A pop-up greets you, just click on "OK" to proceed.
Click on "Start"
Click on "My Computer"
Right click on your hard-drive and select "Properties"
Click on "Tools" tab
In the dialog box, check both options that is
"Automatically fix file system errors"
and
"Scan for and attempt recovery of bad sectors"
Click "Start" and accept by clicking on "YES" to accept a scheduled scan.
Nov 30, 2010 | Computers & Internet
The ice machine it beeping 3 time. I reset the little white button on the pc broad. It run for a while and the beeping sound come back. I know if I hit on the F/S with my crew driver it turn to diffrent...
sounds like you may have more than one issue. Tapping the float switch indicates that it is sticking. This will keep the water coming in and the unit will not go into it's freeze mode. Go to the Hoshizaki web site for how to remove and clean. It's really not that hard. If you can't find it, I'll walk you thru.
With the machine turned off, is there still water running? IF so, the water valve is also stuck in the open position and letting water in. This could cause it to have long freeze cycles and possibly freeze up.
Start there and let me know if you need any more help.
http://www.hoshizakiamerica.com/techsupport/tech.asp?
Feb 27, 2010 | Freezers
My MFC 8860DN does not scan or copy but instead says please wait
Turn the machine off and hold menu while turning it on and keep holding it while the machine starts up. This should go into maint mode.
When it gets into maint mode you can try 99 to exit. This is like a soft reset. Hard reset is hitting 01 in maint mode and then 99 to exit.
Let me know if this is helpful.
Jan 09, 2009 | Brother MFC-8860DN Printer
Mfc210c says no device
This could be for two reasons:
1. Lightning strike the days before has seriously damaged the circuit board.
2. (nearly the same) some part within the circuit board is damaged.
In both ways the circuit baord needs replacement. Unfurtunately the costs for this spare part is twice as high as a new mfc 240c...
You can try to buy another defectiv one (scanner broken or clogged print head) from eBay and simply change the circuit board, to keep your machine alive (This is what brother themself do: collecting faulty machines, separate parts and refurbish them for swapping ;-))
Dec 07, 2007 | Brother MFC 420CN All-In-One InkJet...
Xerox WorkCentre 220 All-In-One Laser Printer Logo
78 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
