Question about Mackie HR824-MK2 System
Macbook Pro 15" Mid 2009 A1286 Backlight fuse location?
Hi, can some point me in the direction of the backlight fuse, on the logic board of a Apple MacBook Pro 15-inch mid 2009 A1286 logic board? Thank you.
How replace backlight mac?
The reasons for backlight situation are;
1 bad screen
2. backlight chip being defective on the logic board
3. bad inverter.
It is therefore advised to take your machine to a local mac repair store.
Mac Repair Mississauga Apple MacBook screen repair Service MacBook pro...
Aug 29, 2014 | Apple PowerBook G4 Mac Notebook
I can not update my mac to 10.9
Hard to say without knowing exactly what Mac you have and what specs, but most likely reason would be your system doesn't meet the requirements (From Apple support site) - To install Mavericks, you need one of these Macs:
  • iMac (Mid-2007 or later)
  • MacBook (13-inch Aluminum, Late 2008), (13-inch, Early 2009 or later)
  • MacBook Pro (13-inch, Mid-2009 or later),
  • MacBook Pro (15-inch or 17-inch, Mid/Late 2007 or later)
  • MacBook Air (Late 2008 or later)
  • Mac mini (Early 2009 or later)
  • Mac Pro (Early 2008 or later)
  • Xserve (Early 2009)
Your Mac also needs:
  • OS X Mountain Lion, Lion, or Snow Leopard v10.6.8 already installed
  • 2 GB or more of memory
  • 8 GB or more of available space
Jan 18, 2014 | Apple OS Computers & Internet
2010 Macbook pro i5 15" Image seen only with flashlight.
As always the Apple products are proprietary and DISPLAY post has issues. Disregard all the testing with other adapters and displays and replace the inverter first, it is the cheaper option.
Mar 02, 2017 | Apple MacBook Pro Notebook
Can I add backlight to my 13 inch macbook (unibody)?
Do you mean the behind the keyboard backlight or something else?
As far as I'm aware only the macbook Pro models have KB backlighting so without a motherboard change you are probably out of luck
Sep 10, 2009 | Apple Computers & Internet
Macbook Pro Dimmed but see the image clearly
Here is a photo. It is the white circled part.
Jul 10, 2009 | Apple MacBook Mac Notebook
Macbook chip shim
Thias can also come from a dead hard drive, or a dead backlight (screen).
The best test would be to plug an external monitor to see if something shows up. If yes, that would mean that the backlight doesn't work anymore. If not, then you have an other hardware problem (motherboard, hard drive).
You can check if the hard disk is the problem by removing it. You should then see a flashing question mark and the screen on.
Keep in touch ;)
Jun 25, 2009 | Apple MacBook Pro Notebook
Mackie HR824-MK2 System Logo
218 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
