Mfd 6020 A inch thick margin when i copy are scan how do i get rid of this Regards Tina
SOURCE: scanning document leaves streak down right hand side
Backu
Thanks for the tip...the problem is NOT a black line but a wide yellow line on the right side of the paper. It starts out about a quarter of the page in width and diminishes in size to about a half inch in width after many repeated scans.
The glass IS clean , and even when the glass had some smudges here and there, I never had a yellow stripe problem!
Scanner bulb is bright and even the entire length of bulb (no dark areas) so I don't think it is the bulb!
Rowboat
Posted on Dec 26, 2007
Soulvisitor
  • 1113 Answers
SOURCE: Print quality bad
To clear white vertical lines from printed documents follow the steps listed below:
NOTE: The use of non-Brother or generic toner may cause white vertical lines.
Brother strongly recommends that customers do not use generic drum units and/or toner cartridges, or refill their Brother toner cartridge. Each Brother laser printer is designed to work at pre-set temperatures that are matched exactly to each of our individual toner formulations. Each individual component is designed to work with the other to ensure quality and reliability. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability.
The Brotherlimited warranty does not apply to any problem that is caused by the useof unauthorized third party drum units, toner cartridges or toner.
1. First, power OFF the unit for safety. The ON/OFF switch is located on the left, rear side of the unit.
2. Open the scanner cover by pulling the blue lever located below the control panel toward you and lifting the cover. Make sure the cover is completely open.
3. Remove the drum unit by holding each side of the drum by its handles and gently lifting the drum forward (toward) you.
4. Place the drum unit on a drop cloth or large piece of disposablepaper to avoid spilling and scattering the toner. Make sure thedirections and DR-250 stickers are facing you.
5. With the drum removed from the Brother machine, clean the laser glass. The laser glass is located inside the Brother machine where the drum was located. It is a piece of glass, about 1/2 inch wide and approximately 8 inches long, located on the bottom of the inside. Gently wipe the glass with a clean soft DRY cloth. DO NOT use isopropyl alcoholor any liquid to clean the glass.
6. Gently pull up on the mauve lever to turn the toner cartridge toward you until it stops. Remove the toner cartridge from the drum unit by gently sliding it out of the drum unit. ***Handle the toner cartridge carefully. If toner scatters on your hands or clothes, immediately wipe it off or wash it with cold water.
7. Gently rock the toner cartridge from side to side five or six times to distribute the toner evenly inside the cartridge. Then, reset the toner into the drum (be sure it clicks into place). Gently push on the mauve lever to turn the toner cartridge away from you until it stops.
8. With the DR-250 sticker facing you turn the drum upside down. There is a blue tab located on the right side. Slide the blue tab back and forth seven times to clean the corona wire. When finished, make sure the blue tab is locked to the right side of the drum.
9. Reset drum unit in Brother machine. Close the cover securely.
Print the help list to test the unit by pressing the REPORTS key located on the control panel and then (1) on the dial pad.
If the white vertical lines still continue, the drum unit will need to
be replaced.
If the purchase date of the original drum or replacement drum is less than 90 days (within the warranty of the drum), contact Brother Customer Service Center at 1-877-Brother (1-877-276-8437) . The center is open Monday-Friday, 9:00am to 7:00 pm EST, excluding holidays.
Posted on Dec 27, 2007
bandana_gyrl
  • 181 Answers
SOURCE: Thick verticle line on copies and scans
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. If problem is still there and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Posted on Aug 07, 2008
SteveLXK
  • 109 Answers
SOURCE: thick black line through page when copying or scanning
Sounds like part of your scanner is not functioning and reading black all the time. Probably best to return it for a replacement.
Steve
Posted on Feb 25, 2009
  • 133 Answers
SOURCE: Solid black line down the document when scanning
are you using the autofeeder to feed your documents?
if yes, open the top cover and clean both glasses (big and small).
and take the drum out, move the blue panel to clean up your drum.
after that should be working fine.
Posted on May 22, 2009
How do i download and install my philip laser mfd 6020 printer
Go to Philips.comsupport, and click on "contact". Have the full product number available. Pose your question to Philips. Usually going directly to the source, will bring you the best results.
Jan 04, 2015 | Laser Office Equipment & Supplies
How do i connect my philips laserMFD 6020 printer to my computer without a cd?
Without a CD, first of all you need to go on google and search for philips website. Enter your product as Laser MFD 6020. This will take you to a page where you will see all the info on it including software and drivers with an option to download. Once you download, connect your printer to your computer using a USB Cable. After that reboot your computer should detect it and follow the instructions to install. I hope this will help.
Jun 26, 2012 | Philips LaserMFD 6020 (LFF6020)
I get a thick vertical black line/margin down the entire page when i scan on my SX115
Please make sure the scanner flatbed is clean.
You can also try to copy and see if it happens on copying.
If it does, then your printer needs servicing.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Hi I bought a new printer Philips Laser MFD 6020 but I am unable to install as the CD is not helping, since it said cant find the hard drive.
Go to this site and download the drivers for your printer.
ptf.com/philips/philips+laser+mfd+6020+drivers
May 19, 2010 | Office Equipment & Supplies
In copy mode I am getting a back strip along the left hand side of the copy. The strip also shows up in the preview. Strip used to be half inch thick and is now an inch thick.
Is any part of the image missing under this black strip, or is it just margin from the side of the document to the end of the glass?
If nothing's missing, then probably you set a larger original size in the settings somewhere.
Try a sheet of white paper the size of the glass, put on top of the (smaller) copied picture or document; when scanning it is not a big deal, you can always choose the area to be scanned, right?
If however part of the document is missing, this can mean that the photosensitive element is faulty and doesn't read a couple hundred pixels on that side and the device needs repair.
Oct 27, 2009 | HP Photosmart 2575 All-In-One InkJet...
May 11, 2009 | Brother MFC 7420 All-In-One Laser Printer
Jun 01, 2008 | HP OfficeJet 6310 All-in-One Printer...
Refurbished Canon PC 160
Yes...it's definitely the toner cartridge.
Erice
Oct 29, 2007 | Office Equipment & Supplies
11 people viewed this question
k24674
