Question about Xerox Office Equipment & Supplies
How do you align a xerox 8560n print head - Xerox Office Equipment & Supplies
  • 2072 Answers
SOURCE: phaser 8560 blurr
There is an encoder on teh drum motor that picks up lubricant from the maintenance kit and causes those blurs. It eneeds cleaned or replaced
Posted on Jul 12, 2008
  • 2072 Answers
SOURCE: phaser 8560n printing greenish instead of cyan
Just shut it down for about 15 minutes and turn it back on. Every long warm up the machine will **** out the old ink and refull. Some of those odd sounds is a compressor emptying the print head.
You may not get the true blue you want. That is a shortfall on that machine, I have battled getting a greenish blue tint on that product.
Have not received a good answer from engineering. Frustraiting.
Posted on Sep 10, 2008
heuweiler
  • 56 Answers
SOURCE: Error Number in Xerox 8560N: 07.010.43:16733
The printhead is stuck in the tilt position by the tilt arms. The process motor gearbox being out of sync can cause this error also. I've also seen the wiper assembly be stuck between the drum and printhead cause this. Pls take a look if there is a piece of paper beside the printhead..
Posted on May 06, 2009
pdouglasss
  • 125 Answers
SOURCE: Xerox Phaser 8560n 07,009,42:0 error.
Hi oconde:
This is your problem.
7,009.42: The printhead is tilted back but not properly restrained in the park arms.
This will require a certified Xerox technician to repair.
Hope this helps
Posted on Jun 03, 2009
  • 123 Answers
SOURCE: after print heads alignment its getting error 1004
The trailing cable is probably runing the printhead. Try replacing the printhead and trailing cable together. Parts available at: http://www.lpscomputer.com/c-622-designjet-5000-5500.aspx
Posted on Apr 15, 2010
Xerox Phaser 8560N PS error code 0805.42:187039
8,035.42: The Media Drive stalled while moving the cap/wipe Up.
Check for obstructions in the Wiper Assembly path.
Is the Wiper Assembly obstructed by the Printhead or wiring?
Apr 18, 2014 | Xerox Office Equipment & Supplies
My Xerox Phaser 8560N has paper jams very often. The codes from Troubleshooting->Service Tools->Jam History for the last 20 jams are: - N4W [9] - C3T [6] - P4V [2] - C3X [1] - M4F [1] -A2C ...
Most of these types of paper jam errors are caused by a cracked cam on the Drum Maintenance Camshaft, which throws the timing off for the whole print process. I would recommend a technician replace the camshaft because there are components that need carefully removed to avoid breaking, then they need to be properly aligned and timed when they are reinstalled. Not really a do-it-yourself repair.
Aug 29, 2013 | Xerox Phaser 8560N Laser Printer
Xerox printer 8560n won't print
First download and install printer's driver ..click here Select your operating system and language. Next try to print the configuration page ..--> Press the [Up] or [Down] arrow button on the Control Panelto select [Printer Setup] on the Display Screen, and then press the [OK]button. Press the [Up] or [Down] arrow button to select[Configuration Page], and then press the [OK] button to print. Press the [Up] or [Down] arrow button to select [Exit], andthen press the [OK] button to return to the Main Menu.
Apr 05, 2011 | Xerox Upgrade Phaser 8560N to Phaser...
I recently installed windows 7 and my phaser 8560N will not print, the printer keeps telling me to add paper but the tray is full?
Sometimes the sensors need to be woke up. Try the -paper feed- setting. If that does not work turn off the printer and re-boot your computer. Turn the printer on.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Xerox Phaser 8560N Laser Printer
Phaser 8560N prints multiple pages when powered on
This was due to the TFTP (PXE) setting on the printer set to on. No more wasted paper at startup/wakeup after changing setting to off.
Jan 12, 2010 | Xerox Phaser 8560N Laser Printer
Our Paser 8560n won't print, sz Fault code
Here is the info from the service manual
Harry
8500/8550/8560 PEST description
37,017.44: Deskew Clutch Disconnect.
The Deskew Clutch is not
drawing the expected power.
Oct 09, 2009 | Xerox Phaser 8560N Laser Printer
Print error
The means the print head is not moving left to right or front to back properly.
Normally either the print head block is contaminated with ink, or the print head wiper blade is stuck between the print head and the drum.
Let me know if you want to take it apart and try and fix it. I will send you directions.
Mar 23, 2009 | Xerox Phaser 8560N Laser Printer
Phaser 8560n printing greenish instead of cyan
Sep 09, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8560 blurr
Jul 11, 2008 | Xerox Office Equipment & Supplies
16 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
