Procedure for draining the machine - Washing Machines
  • 641 Answers
Hi Marios,
I do have a link below on how to do drain washing machine properly.
How to Drain Washing Machine by Hand
Posted on May 08, 2014
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
When washer turns on there is a horrible buzzing sound, e 20 error message was on before
This is a blocked drain error code (E20) which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums, buzzes or whirs.
Error Code E20 on Frigidaire Front Load Washing Machines
Aug 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Front Load Washer will not drain. Frigidaire Gallexy Washer Model # GLTF2940FS0. Get Error Code "E20".
This is an error code for a slow drain or no drain at all problem. It can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code. In addition, replace the drain pump after having found no problem with the drain hose, cleaned the filter, and checked the drain pump impeller but the drain pump just hums or whirs.
Aug 21, 2011 | Frigidaire Washing Machines
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Washer does not drain
Hi msally63,
You may need to clean the Drain Filter, please find my Tip below on the procedure:
ACCESSING, DRAINING & CLEANING THE DRAIN PUMP FILTER...
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Aug 01, 2011 | Washing Machines
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
Kind Regards :-)
JEDEMEYER1
Aug 01, 2011 | Samsung Washing Machines
My washing machine won't drain...help!
Hi aligrogers,
Kind Regards :-)
JEDEMEYER1
Jul 31, 2011 | Washing Machines
Water leaking. A small amount of water leaks when
The usual cause of such leak is a damaged or worn drain pump. Replace it to solve the problem. It can be accessed from the back if it is a belt drive machine or from the front if it is a direct drive. Make sure to unplug the machine before servicing.
Cabinet Removal Procedure (Direct Drive machines)
Remove the console depending on the model of your machine.
  1. If the console is secured by screws, simply remove the screws, lift the console up then flip it to the back of the machine. On some models, the screws are hidden under the console's removable end caps. Pull the end caps to the front of the machine to access the screws. If the console is not held by screws, use a putty knife to release the retaining clips under the front corners of the console. Insert the putty knife blade and push it until the clips are released.
  2. Disconnect the lid switch connector from the body of the machine.
  3. The body of the machine is held on to the back panel by two retaining clips. Use a flat blade screw driver and insert it to the lip of the clip and push it to the back of the machine.
  4. Lift the lid and grab the front of the machine's body. Brace the machine's body with your knee, lift and pull it towards you to remove it. You now have the access to the drain pump.
  5. Reinstall the cabinet in reverse order of the procedure above.
For belt drive washers, remove the access panel on the back of the machine to access the drain pump.
Drain Pump Replacement Procedure
  1. Remove the spring clamps that hold the hoses to the pump. Compress the spring clamps and move it away from the pump.
  2. The pump is held on to the motor by two retaining clips. Pry the clips away to remove the pump from the motor.
  3. Remove the hoses from the pump and install the new pump in reverse order of the procedure above.
Jan 20, 2010 | Kenmore 15864/15862 Top Load Washer
My whirlpool duet front load washing machine stops in mid cycle
F21 = LONG DRAIN ERROR
If the drain time exceeds 8 minutes the water valves turn off. After 4 minutes the “Sd” error will be displayed, then 4 minutes later the F21 error code will be displayed.
Press PAUSE/CANCEL two times to clear.
Procedure:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
5. If the above does not correct the problem, go to step 7.
6. Unplug washer or disconnect power.
7. Replace the pump.
Alternative Procedure:
If the machine cannot be forced to its diagnostic mode then:
1. Disconnect the washer from the power supply and water supply.
2. Remove the top panel by taking out the three screws in the back of the washer. The pressure switch is right on top.
3. Remove the Molex connector from the water level switch / pressure switch.
Refer to the picture below.
4. Reconnect the power supply but not the water supply.
5. Power the machine. The machine will enter diagnostic mode.
6. Power off the machine.
7. Replace the water level switch / pressure switch.
8. Reconnect the water supply.
9. Power on the machine it will work without error
Oct 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHING MACHINE FLASHING F21
EXPLANATION AND RECOMMENDED PROCEDURE
F21 LONG DRAIN
NOTES:After 4 minutes the “Sd” error will be displayed, then
4 minutes later the “F/21” error code will be displayed. Press
PAUSE/CANCEL two times to clear the display.
Possible Causes/Procedure
kinked.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Aug 18, 2009 | Bosch Classixx WFC 2465 Front Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
