Question about Brother ML-100 Typewriter
How to turn off delay when typing - Brother ML-100 Typewriter
  • 43 Answers
There is a button and code on the keyboard that tells you typewriter with line for line or just typewriter.
Posted on May 08, 2014
I have a a Lexmark Wheelwriter 3500 and it has the delayed printing function, well this does not seem to be working correctly it is typing before it should. what can i do to correct this problem?
If it types as you press the kets delay print is turned off, press the print mode key on the r
R. side until Dl prt is on the display. If it just starts typing at a the same position every time you probably have the R. margin set there and auto return on (CODE R).
DickyO
Jul 27, 2011 | Lexmark Wheelwriter 3500 Typewriter
Tip
Dell Latitude Portable (2008 or newer) has jumpy cursor when typing
The Touchpad driver setup has options to keep the cursor from jumping while typing.
  1. Open the Touchpad Properties
  2. Touchpad Settings
  3. Enable the TouchCheck option, set the slider to minimum. (TouchCheck disabled the touchpad while typing. The Slider adjusts the delay. Minimum is .5 second delay, and each notch and additional .5 second delay)
Other options that may cause user problems are Draglock and Tap to Click under Touchpad Settings, and Scrolling and Zoom Settings of Touchpad Properties.
on Jul 12, 2010 | Computers & Internet
2001 jaguar s type my interior lights stay on?
have you moved the switch to leave the interior light on all the time?
have a look at this first,,, if its not that then it could be a door switch sticking on you or the light delay turn off device has gone short circuit on you it has whats called a "tryac" its an electrical switch in the light delay circuit that when it go's pop some times failes in the closed poshion leaving the light on for safty,,,
i hope this has helped you
Oct 26, 2009 | 2000 Jaguar S-Type
Wipers swipe in off position randomly
Known issue with circuit board mounted on wiper motor. Has glitch which causes phantom sweeps. suggest replacing circuit board.
Aug 17, 2009 | 1998 Mercury Villager
Typing delay
You can change the repeat delay times on your keyboard.
Click on the Control Panel then Keyboard icon. In the Speed tab you can change the Repeat delay and the Repeat rate settings to suit your requirements..
Feb 03, 2009 | Dell Inspiron 1501 Notebook
Key delay
go to the control panel>Keyboard. Change the repeat delay and repeat rate. There is a box there where you can test the settings.
Dec 18, 2008 | Computers & Internet
How do i turn off the delayed type on a ibm wheelwriter6
at the very top right of your keyboard there is a "print mode" key
press this key until the note in the left lower coner of the display says "char print"
however in delay print you can correct mistakes before you print - saves on correction tape
Nov 17, 2008 | IBM Wheelwriter 30 Typewriter
Delay on typing words
Plz reinstall your's keyboard driver.
Apr 01, 2008 | Labtec 967307-0403 Keyboard
Dell Vostro 1500
There is a solution on these Dell Models.
Go to Start>RUN and type in MS Config
Go to the startup tab and uncheck the PCMServices.exe
Restart the computer, and it should fix it.
Paul
Mar 13, 2008 | Dell Vostro 1500 Notebook
Delay print
I found the answer to this situation: To turn off delay print function, Push the print mode button on the upper right hand control keyboard.
Thanks for the help!
Kathy
Nov 26, 2007 | IBM Wheelwriter 30 Typewriter
Brother ML-100 Typewriter Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
